01-11-2007, 06:27 PM
#1
Quality of power, signal, and speaker wire?
So, I'm nearing the point where I'll need to order up my cables for my system.
I understand that signal wires should be of high quality, and I'll probably spend some decent money there.
However, when it comes to power wires, and speaker wires, what is everyones opinion? MUST you have brand x "professional quality" wire?
I'm of the opinion that if the wire is the same gauge, is made of good quality copper, and is stranded, there isn't really much difference between the $5 a foot power wire and the $0.30 a foot wire.
Convince me I'm wrong. I just don't think it's necessary to spend oodles of money on wires, particularly power wire.
Thoughts and opinions please?
01-11-2007, 06:31 PM
#2
Cheap brand cables break easily.... But It doesn't mean you have to spend a fortune on wiring..... Do some reading and look up some good brands and you'll find the right cabling..... Welling cable also does the trick at a verry low cost, but they're pretty thick.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
01-11-2007, 06:36 PM
#3
So you're suggesting that the big differentiator is the shielding, and that it's important because without it, the wire is more prone to breaking?
Or are you referring to the actual copper breaking?
01-11-2007, 06:38 PM
#4
I'm referring to the actual copper that is breaking. But yeah, shielding is pretty important too, were it only to keep unwanted noise out of your system....
edit: a solution for badly shielded cable is completely wrap it in aluminum tape....
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
01-11-2007, 07:23 PM
#5
MySQL Error
also the weak points are the connections. the cheaper wires have weak connectors that get loose quicker
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
01-11-2007, 07:30 PM
#6
I crimped my own ring terminals on if that's what you're talking about. Unless you buy one of those amp wiring kits you'll never get cable with terminals already on it. If you just buy the wire by the foot you can get some good deals.
01-11-2007, 07:32 PM
#7
what about prefab RCA's? Those aswell can have weak connections
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
01-11-2007, 07:44 PM
#8
MySQL Error
heh...ic-c30 knew what i was talking about.
M10k
My Car Pc Install
01-11-2007, 07:47 PM
#9
think I might get some credit for this  feel free scott
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
01-11-2007, 07:54 PM
#10
MySQL Error
oh fine!
M10k
My Car Pc Install
01-11-2007, 07:55 PM
#11
hehe, ok back on topic
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
| Thread Tools |
| Display Modes |
Linear Mode
