Old 01-12-2007, 05:32 PM   #1
sheepy is an unknown quantity at this point
***Airspace help***
Hi there guys. i have just brought two alpine type r 12" subs. I just need a little help with the enclosure. I will be mounting the two subs backwards as well. I have uploaded a copy of a section of the manual with all the enclosure stuff.....please help i don't understand it.
I know that the recommended space is 0.85ft3 but im dont know if i sould be adding the rear mounted displacement to this. If someone could clear this up i would be very grateful. Cheers guys!
Come on Peugeot....I want to fill you with noise!
sheepy is offline   Reply With Quote
Old 01-13-2007, 09:10 AM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I think from what I see use the "reverse mount" added airspace to their recommended airspace.
System always under construction
durwood is offline   Reply With Quote
Old 01-13-2007, 02:41 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
i think that is the air space you gain when you reverse mount the sub. so subtract .073 from .85 and that'll give you the enclosure size... or don't worry about it since the recommended airspace is .7-1 cu/ft3 sealed
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 01-14-2007, 03:13 PM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
maybe you should look at a program to determine all of this...http://www.linearteam.dk/
to determine what amount of air space you need, you need to figure out how much air space the sub takes up. From there, you need to determine the sub enclosure volume for a normally mounted sub, then subtract the space that the sub takes up.
In all reality, on most subs, the type Rs included, this whole process is neglegable. If you had some beefy sub (think SPL sub) then it would be a different story...
the thing is, while you subtract the amount of air space that the basket takes up...you need to add back the space that's added by the volume of the cone...
so in all reality...for most enclosures, we're talking about very small differences.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-15-2007, 04:33 AM   #5
So then it will need 0.12ft3 of airspace???? Are u sure!!!
Old 01-15-2007, 04:57 AM   #6
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
no. 0.85 - 0.073 = 0.777cu/ft3. you missed a 0
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 01-15-2007, 05:16 AM   #7
LOL opps....cheers dude!
