The MP3car.com Store
Thread Tools Display Modes
Old 01-13-2007, 06:40 AM   #1
ankur's CarPC Specs
ankur's Avatar
Vehicle: Toyota Innova 2004
My Photos: (0)
Audigy 2 NX - No subwoofer control
Hi all,
I am done with my car pc and setting up the audio now but am having major issues with my choice of soundcard. I have an Audigy 2 NX and am using the outputs to send audio to my Audison SRX5 amp, which are powering Hertz comps in the front, Hertx coax in the rear and a Hertz sub in a ported box. First thing i noticed is that the audigy doesnt give me any sub woofer control. I am sliding the sub woofer slider back and forth but no change in the sub.
I am using headphone to rca cables on the audigy and then Audison interconnects to the amp. I know i have connected the sub outout to the amp and not the center as some songs get the sub really going and most dont.
Please suggest what i should try.
thanks.
ankur is offline   Reply With Quote
Sponsored Links
Old 01-13-2007, 07:59 AM   #2
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
First are you at least getting output to the sub? IF you are, are you sure its the sub channels and nto the center channel?
I have posted this several times for others on the creative cards let me see if I can track it down
Turn on "bass redirection". then you should be fine.
...goes off to find previous posts about this...
durwood is offline   Reply With Quote
Old 01-13-2007, 08:02 AM   #3
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Here it was:
http://www.mp3car.com/vbulletin/show...ss+redirection
Old 01-13-2007, 08:16 AM   #4
ankur's CarPC Specs
ankur's Avatar
My Photos: (0)
Hi,
I did turn on redirection but i dont see the sliders having any effect on the sound. I know i have the right channel connected as with some songs i do get the sub thumping.
I will re check.
Just a thought, do i need a line driver ? I think the Audigy does put out 2v am i right ?
cheers.
Old 01-13-2007, 08:23 AM   #5
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Yes the output voltage should be plenty on the audigy (i think you are correct about 2V)
Did you read part 4 of my other post? Try adjusting the volume slider for the sub and center to make sure you only have the sub output.
Also, do you have another LPF crossover on you amp that might be turned on by accident?
Old 01-13-2007, 08:31 AM   #6
ankur's CarPC Specs
ankur's Avatar
My Photos: (0)
Will try the 2 sliders and post back
Old 01-14-2007, 03:10 AM   #7
ankur's CarPC Specs
ankur's Avatar
My Photos: (0)
Ok the problem was that i hadnt installed the software from the CD but downloaded the drivers from the site. I figured all the important bits will be in the package, i was wrong. The surround mixer was not a part of the download and now that i installed from the CD, the surround mixer works . I am able to move the sub slider and actually feel the subreacting.
I guess now i will have to get the gain reset again based on the ability of the slider.
A big issue i noticed was that the crossover frequency doesnt give an indication of the value. You have to do a lot of trial and error before you get the desired effect.
Sponsored Links
vB code is On
Trackbacks are Off
Looking for front/rear fading and sub level control, Audigy? StLB5 Newbie 15 07-01-2006 11:12 AM
Audigy 2 NX speaker controls? mr92 Software & Software Development 0 07-19-2005 03:59 PM
SB Audigy 2 NX or Live 24-Bit External Berg997 General Hardware Discussion 1 05-17-2005 02:13 PM
Audigy 2 nx -- not that much juice? Jeepman General Hardware Discussion 4 05-15-2005 12:35 AM
Radio extreme and Audigy 2 NX DJKhan85 General Hardware Discussion 3 11-07-2004 09:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
