ive been thinking about the best way to connect my car pc to my amps as im not yet ready to loose my headunit as im still in the trial stages of the car pc
i have an alpine dvd headunit (no screen) which is attached to a lilliput.
basically the two options i have for interfacing the car pc audio are:
1, use rca spliters to splice in the sound from the car pc i.e. 2 rca cabled become 1 that then go ino the amp. (is this even possible without damaging anything?)
this method requires much shoter cables from the car pc meaning better quality sound and would also mean that the car pcs on board surrond sound controller could have its outputs directed to the sub and rear speakers individually (not that i will be using it for dvds very much)
2. get this cable for my alpine
http://www.caraudiodirect.co.uk/alpi...1b-p-3138.html
this allows me to connect an extra aux device though the headunit. i think there are a few advantages to this, no splitters involved, master control of the volume from the headunit (likly to be more responsie i think that car pc volume) can name the aux display to car pc and easy to switch from car pc sound to cd player dvd sound etc using the headunit
the disadvantage is i will have to run a cable from the car pc back to the headunit and the signal will have to travel along that to the headunit then from the headunit back to the amps which could cause noise etc.
i think number 2 is the better option but i do have one more question.
if i went for option number two
would it be beter to run an RCA lead from the trunk to headunit and then plug that into the adapter and the adapter into the headunit.
or would it be better too, in the trunk plug the adapter into a disc changer extension cable and then run the extension cable to the headunit ?
thankyou
