Old 01-14-2007, 10:26 AM   #1
vwwhizz's Avatar
vwwhizz is an unknown quantity at this point
no headunit
hi all....im in the process of building an install..2 15" subs 2 amps and 6x9's up front...im planning on just using my ipod instead of an head unit...is there anyway i can do this...is there such a thing as a volume control box?
vwwhizz is offline   Reply With Quote
Old 01-15-2007, 05:26 AM   #2
Desmaano's Avatar
Desmaano is an unknown quantity at this point
What about the volume control on you're iPod? That controls the voltage of the output signal from you're jack-plug.
Mayby use an jack-plug into two tulip-plugs and put them in the Amplifier.
Should work fine I think. But I haven't done it before so correct me if i'm wrong.
Desmaano
Desmaano is offline   Reply With Quote
Old 01-15-2007, 05:11 PM   #3
vwwhizz's Avatar
ttt
Old 01-15-2007, 05:15 PM   #4
Jahntassa's Avatar
Jahntassa is on a distinguished road
Sure, get an equalizer to do it.
Jahntassa is offline   Reply With Quote
Old 01-15-2007, 05:16 PM   #5
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Where does the carPC go?
Just plug your iPod into an amp that powers your speakers (not subs and crap, actual speakers) and use the ipod to control the volume. Simple.
Old 01-15-2007, 06:12 PM   #6
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
or if you're going out from the line out jack (for improved sound quality) you can get a logarithmic stepped attenuator. the unit i have is from here:
http://www.twistedpearaudio.com/
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
stock headunit + aftermarket amp possible? theheel Car Audio 10 09-11-2006 03:12 AM
Headunit or not to headunit EPIA 13000 Philhop Car Audio 10 06-09-2006 07:45 AM
Do I need a soundcard if I'm using a headunit? rudeboymcc General Hardware Discussion 4 04-14-2006 04:14 PM
New Headunit: Eclipse CD5000. Is there a way to "HIDE" it? (non removable face) mattress Car Audio 1 04-04-2006 04:00 PM
radio receipt headunit Tijs67 Car Audio 0 07-22-2005 08:05 AM
