Old 01-20-2007, 12:47 AM   #1
ripp18 is an unknown quantity at this point
Wiring a Subwoofer
I have 1 12" Type-R, DVC 4ohm+4ohm and a Kenwood KAC-9102D Amp
The "legal" ways to wire it through parallel or series.
I know it is possible to run this amp/sub combo in a way to get a 4 ohm impedance because i have been told it is by professional installers, but they can't tell me how or they will lose their jobs, etc.
how do i do this?
and if it really isnt possible how do i turn down the 850watt rms this app puts out so i dont super-overpower my sub?
ripp18 is offline   Reply With Quote
Old 01-20-2007, 12:54 AM   #2
XC-C30's Avatar
XC-C30 is on a distinguished road
they can't tell you or they'll lose their jobs? load of crap!!!
wire them in stereo = 4 Ohm (you'll need a 2-channel or dual mono amp, so that's out of the question in your case)
wire them in parallel = 2 Ohm
wire them in series = 8 Ohm
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 01-20-2007, 12:58 AM   #3
well the bestbuy installer told me the thing was possible with this amp, but if not im not spending 80 bucks to have it installed. how would i turn down the power of the amp? 850 rms would blow a type-r wouldnt it?
Old 01-20-2007, 01:00 AM   #4
FLA
gospeed.racer's Avatar
gospeed.racer is on a distinguished road
I wouldnt worry too much about that! Those numbers are just numbers. They use them to sell amps.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 01-20-2007, 01:02 AM   #5
thanks for the help. i was searching the this site and the only other thread aobut this was a bunch of idiots ****ing eachother off with useless information that had nothing to do with the topic hah.
Old 01-20-2007, 01:02 AM   #6
XC-C30's Avatar
kenwood might not be the major brand, but I doubt if these numbers are just a trick...
How much does it put out at 2Ohms and what are the fuse-ratings?
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 01-20-2007, 01:05 AM   #7
um well
Rated Power Output:
4ohms (.5% THD):500watts x 1
2ohms (.9% THD): 850watts x 1
Fuse Ratings:
2 30amp Fuses and 1 40amp fuse
even it is a trick its still a good 350 watts over the max for the sub. its almost enough to power two
Old 01-20-2007, 01:10 AM   #8
XC-C30's Avatar
ok, that will be about 600-700watts at 12v. Those 850watts are probably rated at 14volt or so....
I looked up the specs of the sub.... 500wrms, right? In that case I shouldn't worry about overpowering..... Just be carefull when you tune your amp and the sub will handle the output just fine
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 01-20-2007, 01:15 AM   #9
yea the amp runs at 14.4volts
so i tihnk i got this install under control. anything else i should know able? im just gunna run them in series for a 2ohm load in a sealed box (but only because its in an accord)
Old 01-20-2007, 01:22 AM   #10
XC-C30's Avatar
I'd do some more reading if I were you.... your amp doesn't run at 14.4v... It fluctuates between 12 (can be a little less) and 14.4 (can be little more).
You have to run them PARALLEL. If you run them in series you'll have an 8Ohm load, which will result in app 50% powerloss.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 01-20-2007, 01:29 AM   #11
the parallel is what i meant oops
and the manual for the amp is sitting right in from...it actually says:
"14.4 V (11-16 V allowable)"
Old 01-20-2007, 01:35 AM   #12
XC-C30's Avatar
Focus on the (11 - 16 V allowable). That's the fluctuation I was talking about. That 14.4 V just means they measured the output at 14.4 V instead of 12 V
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 01-20-2007, 01:36 AM   #13
so how does that affect my install?
Old 01-20-2007, 01:40 AM   #14
XC-C30's Avatar
well, the fluctuation results also in a power-fluctuation, meaning: power drops, volume drops/power raises, volume raises. But don't worry, if you're wiring is correct, you won't notice the fluctuation.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 01-20-2007, 01:43 AM   #15
and lastly, do you know of any good installation faqs or guides with running wires and hooking up power to the battery? thats my only problem part...the battery
embarrassed to ask: subwoofer wiring? telekineticfool Car Audio 15 09-14-2009 04:32 PM
Subwoofer Phase IDOXLR8 Car Audio 6 10-28-2006 12:34 AM
Is my subwoofer amp pooched? WoLLy Car Audio 13 04-01-2006 11:16 PM
$20 Orion subwoofer box with 2 Orion Cobalt 10' inch SUBWOOFER SPEAKERS and JBL AMP nycjuni Classified Archive 4 09-19-2005 07:41 AM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
