Old 02-05-2007, 03:26 PM   #1
toofastGTiVR6 is an unknown quantity at this point
Exclamation overcurrent in my amp, how do i fix it?
i have a problem. the overcurrent led indicator came on my sony mobile ES amp. i know about this problem but i have no idea how to fix it! my setup was running fine before it happened and one day when i sat in my car it just stopped. can anyone give me some suggestion or better yet tell me how to fix it for sure? thanks
toofastGTiVR6 is offline   Reply With Quote
Advertisement Sponsored links
Old 02-05-2007, 08:41 PM   #2
pancit175 is on a distinguished road
Have you checked out your User's Manual to find out what it says may be the cause of your proplem. There are many different types of problems that may be going on with your amp, for example:
1. You may have your speakers that are hooked up incorectly to that amp.
2. You're speakers/wires may have shorted out.
3. You're amp may be going out internally.
If you're problem is 1 or 2 then Does this still happen while your speakers lines are disconnected from the amp?
Although, if you're problem is #3 then there isnt much you can do but get a new amp, because it might not be easy to repair the amp.
But keep in mind that this forum is dedicated to carpc's, so you might be better off directing the remainder of your questions to the original manufacture of your product or to a dedicated car audio website->
Quote: Originally Posted by Red GTi VR6
this forum is dedicated to CarPCs and installing them.
The car audio forum is dedicated to integrating your car audio system with your CarPC.
For specific questions such as the one you have I would recomend checking out car audio specific forums:
http://www.elitecaraudio.com
http://www.carsound.com
http://www.caraudioforum.com
http://forum.sounddomain.com
http://www.realcaraudio.com
http://www.carstereo.com
http://www.caraudiomag.com
http://www.termpro.com
http://www.the12volt.com
http://www.talkaudio.co.uk
http://www.caraudiosecurity.com
et. al.
there is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
Good luck.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 02-05-2007, 09:14 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
you know, i wonder if it could have something to do with corrosion on the grounds. if there is more resistance in the wire then the amp will be asking for more current. but...pancit's 3 points are valid as well, i'd check all of them until you find your answer (a shorted voice coil sounds about right, or maybe a grounded speaker wire too)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 02-05-2007, 09:41 PM   #4
Fusion Brain Creator
greenman100 is on a distinguished road
no.
greenman100 is offline   Reply With Quote
Old 02-05-2007, 09:46 PM   #5
MySQL Error
scott_fx's Avatar
"no" to what? if you have more resistance in the wire the amp will require more amperage to sustain the same power.
M10k
My Car Pc Install
Old 02-05-2007, 10:12 PM   #6
DJiK's Avatar
DJiK will become famous soon enough
Quote: Originally Posted by greenman100 View Post
no.
Scott referring to the resistance on the voltage inputs, not the resistance of a speaker/sub.
You're wrong / misunderstanding.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 02-05-2007, 11:32 PM   #7
MySQL Error
scott_fx's Avatar
yeah, i guess it's just a miss understanding, it's partly my fault that i didn't specify power ground not speaker ground
anyways, I still would go with pancit's suggestions first then, assuming the overcurrent light doesn't only apply to the output of the amp, then check the grounds
M10k
My Car Pc Install
Engine Noise due to ground loop or amp? matt11601 Car Audio 30 08-26-2009 09:38 PM
Can I run this amp with this sub, how do ohms work, help/recommendations... mikeym Car Audio 37 02-12-2007 12:10 PM
Punch 160.4 Amp wont Power unless REM cable is touching Amp casing. Sero Newbie 2 02-26-2006 11:32 PM
How do you hook up an amp or preamp(are those the same thing?) ? masch Newbie 1 11-17-2003 04:21 PM
