The MP3car.com Store
Thread Tools Display Modes
Old 02-07-2007, 04:42 PM   #1
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
PC audio extreme,competition/studio level...
alright, I've been active on the audio software thread & the usb vs optical thread & I've been cluttering them up enough with my off topic posts, so for this one I figured I'd just start a thread...
I guess the average guy who clicks on this thread is going to just think this is nutz, but there are a few here who understand what I really want to achieve
the end goal of my project is to have all audio in my new car originate from the pc... I will have no head unit... I also don't have any room for a separate processor control display, so I've been shying away from using an alpine processor which was the original consideration...
I then considered doing all audio processing on the PC, my plan was a dual PC setup that used the rear PC as kinda an audio server, doing all processing through console & vst plug ins ... outputted thru some form of DA conversion.... while this is still a viable option for me, in my research to find the equipment to do audio on the PC & through a mention by red, I found something pretty cool...
a rack mount pro audio processor that does everything that would ever be needed to tune a car... it has 8 outputs & oh well,here :
Product Description
The DB Drive Rack 480 stands at the heart of the Drive RackŪ system. The dbx Drive Rack 480 includes 4 inputs and 8 outputs which can be tailored for any configuration. By including every form of processing necessary to drive the signal from the mixer to the power amps, such as pre-crossover EQ, notch filters, speaker delay, multiple crossovers, speaker compensation equalizer, driver alignment delay, and compression/limiting, the 480 is truly the only box you’ll need for any sound system application. Two real time analyzers can be run simultaneously with RTA source inputs capable of being remotely switched on the fly. The 480 is fully programmable from the front panel, with the 480R remote control, or through a computer via the GUI port.
dbx Drive Rack 480 Features
4 Inputs and Outputs with routing
31 band graphic or 9 band parametric equalizer on every input (pre-crossover)
Dual Real Time Audio Analyzers
Butterworth, Bessel or Linkwitz-Riley crossover filters
27 Different Crossover Configurations
Time Alignment and Transducer Alignment Delays
Compressor/Limiter on every output
Speaker Compensation EQ (post crossover)
Multi-level Security System
Separate House and Show EQ with individual lockout
Triple redundant back up of all parameters when running network, 480R and PC GUI
TYPE IV™ Conversion System
Electronically balanced/RF filtered XLR Inputs and Outputs
Proprietary RS-485 Control Network
RS-232 PC Interface for computer display and configuration
Technical Details
Specifications
Inputs
Number of Inputs: 4 (Inputs 3 or 4 can be selected as an RTA Mic input)
Connectors: Female XLR
Type: Electronically balanced/RF filtered
Impedance: >40kOhms
Maximum Input Level: Hardware selectable for +30, +22, +14, dBu
Maximum Input RTA Level: -10 dBu
CMRR:
>40 dB typical
>55 dB at 1kHz
Input Gain Range RTA: 10 dB to 70 dB w/60 dB typical
Outputs
Number of Outputs: 8
Connectors: Male XLR
Type: Electronically balanced, RF filtered
Impedance: 120 Ohms
Output Transformers: Optional
Maximum Output Level:
+25.5 dBu into 1kOhm
+22dBu into 60 Ohms
A/D Performance
Type: dbx Type IV™ Conversion System
Dynamic Range (line):
>112 dB unweighted
115 dB A-weighted
Type IV™ Dynamic Range:
127 dB with transient material, A-weighted, 22kHz BW
125 dB with transient material, unweighted, 22kHz BW
119 dB typical with program material, A-weighted, 22kHz BW
Sample Rate: 48kHz
A/D Wordlength: 24 bits
D/A Performance
Dynamic Range:
112 dB unweighted
115 dB A-weighted
Sample Rate: 48kHz
D/A Wordlength: 24 bits
System Performance
Internal Wordlength: 48 bits
THD + Noise: 0.003% typical at +4dBu, 1kHz, 0dB input gain
Frequency Response: 20Hz- 20kHz, +/-0.5dB
Interchannel Crosstalk: <-85dB at 1kHz, 0dB input gain
Pre EQ
Type: One 31-band Graphic EQ per input channel, or 9 band Parametric EQ per input channel
RTA can be substituted for EQ in channels 3 and 4
Range: +/-12 dB range
Notch Filters
Number: 1-5 per input channel not to exceed 10 for all input channels
Pre Delay
Length: 680ms/channel
Crossover: Type: 1x2, 1x3, 1x4, 1x5, 1x6, 2x3, 2x4, 2x5, 2x6, 2x7, 2x8, 3x4, 3x5, 3x6, 3x7, 3x8, 4x6, 4x8
Filter Type: Butterworth, Bessel, or Linkwitz-Riley
Slope:
6, 12, 18 or 24 dB/octave for Butterworth or Bessel filters
12, 24, 36 or 48 dB/octave for Linkwitz-Riley filters
Post EQ
Type: Parametric
Number: 4 EQ bands per output channel
Range: +/-15 dB range
Dynamics
Type: Compressor/Limiter with PeakStopPlus™
Attack/Release: Program Dependent
Linking: All 8 bands are linkable
Post Delay (Driver Alignment)
Length: 170 ms per output channel
Pink Noise Generator
Position: Pink noise inserted on selected input(s)
Phase Compensation
Number: One per output channel
Amount: 0-180 degrees phase shift
Output Polarity: Reversible
Miscellaneous
Network: Proprietary RS-485 Backbone
GUI: RS-232 interface for computer display and configuration
RTA Microphone: Optional
ROM Upgrade: Flash upgradeable through RS-232
Power Requirements
Watts: 100-240V - 50/60 Hz; 35 Watts
Dimensions:
Height- 3.5"
Width- 19"
Depth 12.15"
Weight: 11lbs.
my thinking is, that if I'm going to go out & build a pc for this, & then add the harware & software necisary, including high end hardware anyway, the cost may not be way cheaper than a unit like this anyway.... this thing is like $2,500
the software for this is totally cool, you can do anything through it's gui & never have to touch the unit in the trunk past initial setup.....
this is professional studio grade stuff, so the quality is there, & interface is ideal.... it even has real time analyzer funtions built in... the possibilities are pretty cool with this thing... I could call up the rta in roadrunner & embead it as the visualization, talk about a cool visualization
in the end, what difference is it to me weather my audio is being processed by a core 2 duo slave unit with da converters running console, or weather it's all being done with this stand alone unit... somehow I think the rackmount will be more reliable & less fussy, not to mention booting in maybe 5 seconds
heres a screenshot from the software:
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Sponsored Links
Old 02-07-2007, 05:05 PM   #2
turbocad6's Avatar
My Photos: (71)
I guess I'm just looking for thoughts or opinions on a setup like this.... any input is good input....
aside from the price & the space required, anyone see any drawbacks that I might not see?
the more I think about this, the more I think this might just be the ultimate solution
Old 02-07-2007, 05:38 PM   #3
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
I think it looks awesome. Scares me though... Just the price tag. I could never afford it, nor need it!
But it is definately a cool piece of machinery.
Old 02-07-2007, 05:43 PM   #4
turbocad6's Avatar
My Photos: (71)
yeah, I just put a snipe bid in on one on ebay
crazy stuff I guess... this is just such a sweet piece... I'll know in a little while weather I win that one or not... it's cheap & the sellers a bit shady, but I would only do a cash pickup or he can go screw himself..., he's not to far from me really... if I get this one it'll be relatively cheap
Old 02-07-2007, 05:48 PM   #5
2k1Toaster's Avatar
My Photos: (1)
a snipe bid means you will know in like 7 seconds!
Old 02-07-2007, 05:48 PM   #6
PSYKO_Inc's CarPC Specs
PSYKO_Inc's Avatar
Vehicle: 1997 Chevrolet S-10
My Photos: (0)
I don't really have anything useful to add to the thread, but I gotta say it's a damn good concept. I'm definitely looking forward to see what happens with this. Is this going in the Caddy?
-Jay
1997 Chevy S-10, ext. cab
CarPC Progress: 75% - Functional, but not quite finished.
Check out my progress.
PSYKO_Inc is offline   Reply With Quote
Old 02-07-2007, 05:53 PM   #7
turbocad6's Avatar
My Photos: (71)
yeah, in the caddy, I just won it $1275.... damn cheap...... now to see if it's bull**** or not.... I'm going to go out there & pick it up or no deal...
wow, this should be an interesting install
Old 02-07-2007, 05:55 PM   #8
2k1Toaster's Avatar
My Photos: (1)
Congrats on sniping!
Old 02-07-2007, 07:17 PM   #9
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
Very ambitious! Hope it works out well for you.
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 02-07-2007, 07:47 PM   #10
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
haha way to snipe! Awesome! There are no drawbacks from what I know. If you have the space in the trunk, use it. Altering the power supply should not be too hard. Ther is one definite advantage this has over software...less risk of blowing up drivers because something went haywire in the software or computer. I'm Jealous!
durwood is offline   Reply With Quote
Sponsored Links
Old 02-07-2007, 09:19 PM   #11
Dennis5587's CarPC Specs
Dennis5587's Avatar
Vehicle: 2006/Mazda/3
My Photos: (0)
MY GOD... where you putting that thing?
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 02-07-2007, 09:47 PM   #12
turbocad6's Avatar
My Photos: (71)
this is kinda ambitious, but really it's the easy way out for me
I see a lot of definite advantages,
total & complete solution for all software/hardware out of the box, no questions it just works ....
just feed this from one (tube maybe) usb dac using asio driver, done.... the PC just spits out raw unaltered unprocessed bit perfect sound, no excessive load to the host PC at all... don't need any drivers even but the asio...
all control is on the PC though & is integrated into one program & is a professionally designed pro studio system that's integrated by dbx directly into there hardware..... every adjustment is a module & a separate pop open window that can be dragged into a rack.... the skinning possibilities with roadrunner & this are pretty sweet... when I call up eq 1 could pull up 4 31 band eq's at a time, cycle through, well you get the drift, Lotta room to play there
just playing with the software this is so cool, you can adjust & manipulate every aspect of everything.... multiple notch filters in any order filter... it's just so cool
the reliability & stability of this compared to a PC is another huge plus for this design....
the core2duo laptop with the hardware that would have been the alternative to this make the cost of this negligible really.... comparing the 2 at around the same price just made this choice so obvious to me for myself
overall this is a guaranteed drop in awsome system to begin with, all configured & working properly it is definitely the easiest way to get what I really want.... & the tuning, man, I can tune to my hearts content, all on professional studio equipment, man this is going to be sweet
the only drawback I do see is I was kinda looking forward to being one of the firsts to do a real competition system on the PC alone, but bottom line is that would have been a longer up hill battle with more than likely less overall results..... I've got enough of those in my life right now, & easy guaranteed just sounds so good to me right now
in the end all I want is a kick *** system all controlled through the pc, this should be a great start
I will still follow the PC based threads though, & I'm sure I'll do another system somewhere with that soon enough too.... I,ve got 2 other builds coming up soon that could wind up that way....
I got an email from the auction wife, she's going to relay to her husband.... hope I really get this unit at what it's supposed to be... if not, they can be had for under $2,000 anyway used.... I gotta have one of these
Old 02-07-2007, 09:49 PM   #13
turbocad6's Avatar
My Photos: (71)
it's only 3 1/2 " high..... it'll go in the trunk..... I'll probably take it apart, but I doubt I can make it much smaller... don't worry, I'll get it in there somehow
Old 02-07-2007, 10:06 PM   #14
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
how are you going to control the volume?
i agree..this is definately the way to go, and now you can get a dac with balanced outputs too :-)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 02-07-2007, 10:10 PM   #15
My Photos: (0)
Very sweet unit!
I only see 4 channel input, no optical input. Do you plan on listening to multichannel audio? Any options for Dolby decoding add-ons with this model?
bblitz is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
PC audio only when HU is on NeX Car Audio 17 03-16-2006 02:56 AM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 04:04 PM
How much line level does the Epia M Audio have? orangewhip Car Audio 2 05-20-2005 07:56 PM
Car PC Audio Design sza Car Audio 4 10-27-2004 09:08 AM
Experienced PC guys needs Car Audio Primer SwapMeet Newbie 6 02-10-2004 04:33 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
