Old 02-14-2007, 03:53 PM   #1
carabuser's Avatar
One of the component speaker blew. Need advice on replacement
As the title says, one of my component speakers blew a couple of months ago, so now I want to replace it. They were a set of 6.5" Kicker components. I will be replacing it with a traditional 2 or 3-way 6.5" speaker setup. Now my question is this: the tweeters used with the component setup are perfectly fine, so how would I go about connecting them to the new speakers? Should I just connect them in parallel?
2000 Maxima CarPC
Current Status: Rebuilding
Specs
- 1.5Ghz Toshiba Laptop
- Indash Motorized 7" VGA TS
- DeLorme GPS
- Power Inverter
- Pioneer HU
carabuser is offline   Reply With Quote
Old 02-14-2007, 03:56 PM   #2
XC-C30's Avatar
Not a good idea. If I were you, I'd buy a pear of kickbass speakers and a set of filters.... If you but a 2-way or 3-way, the high frequencies are gonna mess up your sound because of the 4(!) tweeters. By the way, the inline-filter that comes with a 2-way isn't designed to handle the load you're gonna put through it by connecting an extra set of tweeters to them.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 02-14-2007, 04:00 PM   #3
carabuser's Avatar
Would you consider using a set of old filters that came with the old component system? Although I have a feeling it will kill the high frequencies of the new speakers. Right?
2000 Maxima CarPC
Specs
- DeLorme GPS
- Power Inverter
- Pioneer HU
Old 02-14-2007, 04:05 PM   #4
XC-C30's Avatar
most filters are especially designed to fit the tweeter and kickbass that are being combined in the set-up, so using an old pair of filters that came with a totally different set isn't going to help your sound-quality-wise...... The load a certain filter can handle is verry different.... Best thing for you to do is design a filter for the components you're going to use. You could go with a prefab filter that's designed for an allround use, but I would recomend against it strongly, because of the loss of sound-quality most of the times.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 02-14-2007, 05:58 PM   #5
carabuser's Avatar
Thanks, IC-C30. I guess I'll have to look at other options when choosing a new speaker system
2000 Maxima CarPC
Specs
- DeLorme GPS
- Power Inverter
- Pioneer HU
Old 02-15-2007, 06:21 AM   #6
XC-C30's Avatar
are you all that concerned about high SQ? otherwise a cheap active x-over could save you. just buy a set of kickbass speakers and such an x-over. I think you can get it for like $50 or something.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Component speaker recommendations Slimline Car Audio 30 11-07-2006 10:49 AM
1995 maxima speaker advice DrStein99 Car Audio 5 02-08-2006 11:13 PM
replacement horn to vent my rage advice needed c4shm0ney Off Topic 24 07-13-2005 09:36 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 12:25 AM
Blew fuse in inverter, can’t find a replacement. pioneer Power Supplies 2 08-23-2004 09:36 AM
