I am currently in the process of fabricating/building my CarPC. I pretty much have everything done as far as the computer goes. Its time for me to purchase an amp and whatever else I need to achieve decent sound quality directly from my motherboard. Some background I am using the new Jetway 2GHZ Mini-ATX motherboard with the M2-ATX power supply. The motherboard has Spidf out and you can also change the three 3.5 jacks to work with 6 channel output. I am a long time computer/home theater builder but when it comes to car audio I am pretty much a noob. I mean home theater amps, every speaker has its own input. None of this bridged stuff.
My question is basically what Car amp should I buy if i am going to leave my current 4 factory speakers in my car. Should I upgrade these factory speakers and maybe add two tweeters? If I add tweeters then where should they go so it can still look factory? Should I buy a Sub and a separate amp to power it? Do I really need a sub? I mean I don't want anything crazy just good enough to watch movies in my car. Should I buy an AMP with SPDIF input so I can utilize the SPDIF output on my motherboard? Or should use the 4 channel output feature on the mother board. Or should I just use the 2 channel output using the line out on the motherboard. Also, if I plug the 3.5 to RCA out of just the line out into the AMP. How do I get that to play on all the speakers if I use a 4 channel amp? Or would I only need a 2 channel amp if I am only going to use the line out to RCA, and if i do that how do I connect the 4 factory speakers to a two channel amp? Crazy, because I really build computers all the time and set up home theaters all the time, but have no clue how car audio amps work.
Also, I took out my factory radio and have some questions about these plugs:
I know the one on the left is the factory wire harness, but do I need any of these wires if I am going with no head-unit and wiring my M2-ATX directly to the battery? Also, if I am installing a AMP under my passenger seat what wires in this harness would I need if any? I know they all have a purpose like they are speakers and stuff but I am don't know if I need any of them. I know the AMP on/off switch is wired directly to the M2-ATX psu.
Also, the one on the right. Is the yellow wire the one that is going to my Ignition? Also, is the black wire with it the Ground going to the Ignition? If so I guess I can use that to connect to 5v ignition switch on my M2-ATX.
Any help at all on how to wire my Car audio and what hardware to buy for my CarPC would be greatly appreciated. As you can see I desperately need it.
