Old 02-27-2007, 04:23 PM   #1
CaptainTrap is an unknown quantity at this point
ohms question
My setup is the following:
Audio
-Infinity 7541a Reference Series 111w RMS 4 Channel at 4ohms
-Infinity Kappa Perfect6.1 Components 100wRMS 4ohms
-Infinity Kappa 6x9mids 110w RMS 2ohms
Will running the mids at 2ohms and components at 4ohms be a problem?
CaptainTrap is offline   Reply With Quote
Old 02-27-2007, 07:10 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
shouldn't be, it'll just draw your soundstage back behind your head (most likely) and also will be a dirtier signal back there too
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 02-27-2007, 07:41 PM   #3
yeah, the 2ohm speakers will be in the rear. How much worse do you think the sound quality will really be? My main concern is that i dont cause any damage to the speakers running a different ohm than the amp is set to. Thanks!
Old 02-27-2007, 07:56 PM   #4
psyrex's Avatar
psyrex is on a distinguished road
There's no "set to". the 111W 4ohms means when you connect a 4 ohm load on it, the amp can only send out a max of 111W safely. If you look at the specs on that amp, it also says 139W 2ohms, which means 139 watts if you connect a 2 ohm load on it. Since they will be on different channels, it's okay to mix the impedances, you'll just have different amplification levels on the different channels.
Gen 1: Pentium 3 1GHz - ATX - 2005
Gen 2: Pentium M 1.6GHz - ITX - 2006
Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
...it never ends
psyrex is offline   Reply With Quote
Old 02-27-2007, 08:55 PM   #5
oh now i understand, thank you for clearing that up.
I havent inspected my closely yet and was under the impression that it had a switch to choose between 2ohms and 4ohms. a noob misunderstanding i will admit. Thank you.
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
Ohms, Watts, speakers & AMPs - confused kingtut Car Audio 41 07-15-2005 06:40 AM
speaker connection question modh1984 Car Audio 1 05-24-2005 01:27 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
