Quote: Originally Posted by
aaronsagas
hi all newbie here, im here to ask for your help on fitting a sub, i currently have two parsell shelf speakers running of a 500 watt amp, off my car battery, but i also want to use another amp to run a sub i've recently purchased, so i will have to amps both running off the car battery(is this ok?) and i would also like to know, can i use a 2 ohm amp with a 4 ohm sub? and 1 last thing how powerfull amp should i be looking to buy if i have got a 1200 watt sub?
thanks in advance
aaron
You need to run 2 4ohm subs in parallel if your gonna use a 2 ohm amp. And if your using a 1200 watt sub, then a amp with similar wattage.
