Old 02-28-2007, 02:38 PM   #1
mistakang is an unknown quantity at this point
04 Grand prix radio stopped working
Hello, does anyone know the location of the stock amplifier on an 04 Grand Prix GT? My radio stopped working one day & I have checked the 2 radio fuses that I can find. Is ther an additional fuse for the "door chime module" or the on-board amp?
The display works and the radio collects & displays the station/song info data, but there is no audio coming out. Please help, I'm going on 5 months without tunes!
Thnks
Mistakang
mistakang is offline   Reply With Quote
Old 02-28-2007, 02:45 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Thnks
Mistakang
Mp3car.com == CarPC
Might want to go to a forum specific to your car. You might find some answers but not as quickly as you would elsewhere.
And if it is an "onboard" amp meaning in the HU itself, then the fuse on the back of it is the one.
Old 02-28-2007, 04:22 PM   #3
cbevis is an unknown quantity at this point
Thnks
Mistakang
stock amplifier eh? If you've got a premium sound system in the car then there would be a small amplifier inside your consol somewhere...probably in the general direction of below and to the back from your stereo. The fuse for that kind of amplifier is the same as one of the two fuse you already checked so in that regard, you're S.O.L.
OEM HU's are a pain in the ***...there's no real good way to fix stuff that goes wrong with them. Because they're mass produced only slightly slower than bunnies you end up getting a few bad eggs. They also opporate at lower power ouputs so when they start to wear out they shut off pretty quick. I'm guessing your deck is probably on it's last leg...
cbevis is offline   Reply With Quote
Old 03-01-2007, 09:51 AM   #4
Blantrip is an unknown quantity at this point
Your stock amp. is located in the truck between the speakers
Blantrip is offline   Reply With Quote
Old 03-01-2007, 10:00 AM   #5
david69leonard's Avatar
david69leonard is an unknown quantity at this point
i would just throw the stock HU away and install a TS and PC... Problem solved
david69leonard is offline   Reply With Quote
Old 03-01-2007, 03:21 PM   #6
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
Not me I'd hit it with a hammer while it is still in the car cause that would just freak the out of anybody watching plus since there isnt a p.c. in there you would have a reason to put one in.
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 03-01-2007, 04:54 PM   #7
MrJamieR's Avatar
MrJamieR is an unknown quantity at this point
Carputer Haiku (thanks Ian Hughes)
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
MrJamieR is offline   Reply With Quote
CIMR-100 stopped working?? unrealer33 General Hardware Discussion 5 07-01-2003 06:10 PM
motorized screen stopped working :( corsamel LCD/Display 0 11-26-2002 11:52 AM
Help!! My Dennis K setup has stopped working Glyn LCD/Display 1 08-30-2002 04:20 PM
it just stopped working. cruzc_99 General Hardware Discussion 5 02-05-2002 10:48 AM
COM port stopped working... need help! chris General Hardware Discussion 5 02-17-2001 12:39 AM
