Old 03-01-2007, 11:27 AM   #1
Kurack is an unknown quantity at this point
Wiring up crossover devices ??
I'm a newb. I got these, ROCKFORD FOSGATE T162S which come with tweeters and two crossover devices. My understanding is that these devices know to take high tunes and push them to the tweets, and lower tunes to the components.
That being said, on one side of the crossover device i bring in the normal speaker wires, on the other side should be 4 outputs, 2 for the component and 2 for the tweet, yes?
Where should these crossovers be located as far as physically from the amp? closer to amp or closer to speakers?
Kurack is offline   Reply With Quote
Old 03-01-2007, 12:24 PM   #2
Siezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to all
Correct
It's a matter of preference really, and I've seen it done both ways. Keep in mind, if you put the crossovers close to the amp, you'll have twice as much wire to run to where your speakers are located (4 wires instead of 2). Typically most people put the crossovers as close the the components as possible to minimize the wiring.
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
Control devices via LPT and Bluetooth Towar Software & Software Development 10 08-25-2008 12:51 PM
Too many USB devices Dragonknell911 General Hardware Discussion 29 02-18-2006 04:50 PM
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
if you designed a vehicle's interior and wiring, how would you do it? stapan General MP3Car Discussion 7 12-26-2005 02:56 PM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
