Old 03-01-2007, 03:37 PM   #1
Kurack is an unknown quantity at this point
Am i missing anything in this diagram?
Here is what I came up with so far...I'm going to get started on this in the next day or so...Thoughts? its a rookie diagram for sure
The sound card is the Live! 24bit external, which is powered from USB, no need to go external power for that.
Kurack is offline   Reply With Quote
Old 03-01-2007, 03:47 PM   #2
spoonraker is an unknown quantity at this point
Looks good except I don't know why you are putting your touchscreen on a switched power source. Unless your touchscreen doesn't have a power button or you won't have access to it after you install it, there is no reason to switch that power source. Also the cigarette lighter should already be fused.
spoonraker is offline   Reply With Quote
Old 03-01-2007, 03:53 PM   #3
david69leonard's Avatar
david69leonard is an unknown quantity at this point
i would throw in a power cap for ur amps... other than that looks good to me!
david69leonard is offline   Reply With Quote
Old 03-01-2007, 04:01 PM   #4
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I'd put it on a switched source. It's a nuisance to always have to turn your screen on. Why not let your car do it. Set your screen to auto on and when the ignition turns on, screen turns on. I would recommend another method too, but its more complex and you are fine.
I wouldn't worry about CAPs at the moment. They are one of those additions for when you have money burning a hole in your pocket and you don;t knwo what to do with it. Better to opt for a Big 3 upgrade instead.
Kudos for doing a diagram. it will help you keep thigns organized.
System always under construction
durwood is offline   Reply With Quote
Old 03-01-2007, 04:35 PM   #5
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
exactly the first two replies are steering you wrong
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-01-2007, 05:09 PM   #6
nkotch's Avatar
nkotch is on a distinguished road
I agree. In my old car I had my screen running off a switched output of the OPUS unit. My screen doesn't have auto on but when the computer turns off I know that screen will go off also. I've accidently left the screen on before. One day you'll be in a rush and forget to turn it off.
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
Old 03-01-2007, 06:37 PM   #7
one question though, should I have a switch up by the driver seat to turn the carPC on/off also? What if i want to drive the car around but have the carpc off?
Old 03-01-2007, 06:49 PM   #8
MySQL Error
scott_fx's Avatar
that's totally up to you. it could be handy for a reboot, but it's not needed.
M10k
My Car Pc Install
Old 03-02-2007, 08:46 PM   #9
pancit175 is on a distinguished road
I agree, If you power your screen off of your power supply, given that you get the right PSU then you'll have a regulated power source giving you cleaner power to the screen
And a switch for main power for your computer may not be a bad idea, given you need to shutdown the pc after it froze. But when using switches, it may be best to use a relay, depending on the amount of current running through the wires.
PROGRESS:
pancit175 is offline   Reply With Quote
AutoPage 860 + 2000 Honda Civic Wiring diagram Help! pcmofo Hardware Development 4 01-14-2007 07:19 PM
missing lilliput cables dstryr99 LCD/Display 6 09-25-2006 07:10 PM
CarPC wiring diagram Tommy General MP3Car Discussion 5 08-14-2005 08:03 PM
cant change skins??? Hell-Stopper FrodoPlayer 19 11-05-2004 11:10 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
