Old 03-02-2007, 04:03 PM   #1
ali7up's Avatar
ali7up is an unknown quantity at this point
parallel series help?
i am trying to wire my 4 ohm speakers into a 2 channel amp in parallel series, the speakers run at 100w rms and my amp runs at 100w at 2 ohm, when i am wiring the amps, there are connections for each channel so it goes like this + - + -, when i am wiring do i just use 1(+ -) connection or do i connect the + into one and the - into the other
thanks
ali7up is offline   Reply With Quote
Old 03-02-2007, 04:20 PM   #2
XC-C30's Avatar
XC-C30 is on a distinguished road
you can't run your 4 Ohm speakers @ 2 Ohm, unless you use 2 speakers per channel, which will request a 200watt load. And since your amp is only 100watts @ 2Ohm, you're underpowering your speakers.
speakers in series
speakers in parallel
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 03-02-2007, 04:32 PM   #3
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
Just adding more to what was already said. The problem with underpowering subs could cause a blown sub from distortion. What kind of amp and subs are you running. This information will help us guide you in a direction.
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 03-02-2007, 04:34 PM   #4
ali7up's Avatar
hmmm... is there any other way to run the speakers with the amp, the amp is
50 x 2 at 4 ohm
100 x 2 at 2 ohm
200 x 1 4 ohm bridged
the speakers are 100w rms and 350 w max imp: 4 ohm
Old 03-02-2007, 04:34 PM   #5
XC-C30's Avatar
I think the OP meant just regular speakers like compo's or coaxials.... But other than that.... Yeah, what speakers and amp are you planning to use.
edit: yeah, you can use the amp if you buy 50watt, 4Ohm speakers, or 100watt, 2 Ohm speakers, or buy a second amp just like it and use 1 amp per speaker and bridge the 2 channels. BUT you're gonna have a hard time setting up both amps equal.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 03-02-2007, 04:53 PM   #6
ali7up's Avatar
well thanks for the help i think i am just gonna sell this amp and get one that puts out 100w x 2 at 4 ohm
Old 03-02-2007, 04:57 PM   #7
XC-C30's Avatar
As long as you stay away from fleamarket brands, cause they will never get their rated output! And one other thing: It's better to overpower a little bit (say an amp with 110watt or so per channel) than to underpower. It will give you more headroom and give just a little more punch to your sound.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 03-02-2007, 05:00 PM   #8
ali7up's Avatar
yea i learned that the hard way now i am staying away from anything fleamarket, so between 100 and 110w rms, alrigth
Old 03-02-2007, 05:07 PM   #9
XC-C30's Avatar
I don't know what your budget is, but this is a nice one:
http://www.steg-america.com/models/k_series/k201.htm
Don't know what it costs in the US though. But in europe you're paying €375 for it ($500)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 03-02-2007, 06:01 PM   #10
ali7up's Avatar
whats the highest i can go without over doing the speaker, i have only seen 100 or 125w not so many 105, 110, etc.
edit. my budget i am not trying to spend anything more than $150 per amp
Old 03-02-2007, 06:08 PM   #11
XC-C30's Avatar
And you wanted to stay away from fleamarket brands? I'm sorry to burst your bubble mate.....
What else do you have to power, other than the 2 speakers upfront?
What kind of speakers do you have?
If it are really decens ones you could even put 200watts on it, as long it's a clean signal you're sending to them. And as far as ratings go: some amps are a little underrated, others are a little overrated, and some are WAY under- or overrated. So it really is up to you to seperate them, and for that, you need to know your hobby.....
But I'm willing to help, if you give me just a little more info on what you're looking for exactly....
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 03-02-2007, 06:18 PM   #12
ali7up's Avatar
lol i know but i just want something good not spend 600 on an amp and the speakers i have Infinity Referenc
specs rear:
http://www.cardomain.com/item/INFREF9612I
specs front:
http://www.cardomain.com/item/INFREF6012SI
i just want something that will put out decent quality, if there is nothing then i might fit in a bit more money to get something
Old 03-04-2007, 05:05 PM   #13
XC-C30's Avatar
weird setup really. Normally it should be the other way around. speakers with the smalles rating in the rear deck and speakers with the biggest rating upfront..... I wouldn't overpower those too much, so that means you're gonna need 2 different amps.....
You said you already had 2x50watt amp @ 4Ohm, so I'd use that for those 50watt speakers, and buy a new amp for the 6x9's
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 03-04-2007, 10:24 PM   #14
ali7up's Avatar
do you have experience or know anything about this amp
NINe.2
http://www.edesignaudio.com/edv2/pro...products_id=45
Old 03-05-2007, 09:06 AM   #15
XC-C30's Avatar
Not personally. But I've read good things about it.
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Parallel port relay control in RR using Autoit? momanz Road Runner 5 04-03-2009 10:20 AM
Ohms, Watts, speakers & AMPs - confused kingtut Car Audio 41 07-15-2005 06:40 AM
Electronics Question - Parallel Relay blazinlow General Hardware Discussion 1 11-07-2004 01:39 PM
parallel port LCD problem jethari LCD/Display 5 09-05-2004 10:56 PM
Crystal Fontz parallel LCD CaffeineAddict LCD/Display 0 09-27-2001 02:55 PM
