Old 03-03-2007, 05:47 PM   #1
rowl3y is an unknown quantity at this point
Exclamation Little Help Need Please WITH SUB RMS AND AMP
Hi there ..
This is my first post here so Hi all..
i just got a new sub as all my old gear got robbed out the car...
The sub i have is - SONY XS-L122P5S
http://cgi.ebay.co.uk/Sony-XSL-122P5...QQcmdZViewItem
but i have a unknow amp is say's its 480 watts on the amp its self
So that must be briged. I have this sub briged bus that sub is only 380 RMS
will this reck my sub up
don;t really wanna kill but i want it to sound heavy bass as it does know when turned up as i have a wack headunit for aldi £40 still really good tho
Alsp is there any info about RMS and that base ware to have car sub's with MAX bass
And 1 last thing...
Is there anyway i can read what watt's car coming out my amp with somthink
thanks
rowl3y is offline   Reply With Quote
Advertisement Sponsored links
Old 03-03-2007, 08:52 PM   #2
getonerd's Avatar
getonerd is on a distinguished road
480 max
240x2 max
it might be 120 rms
thats not a good for a sub maybe some 6x9's
2005 Pontiac G6
Headunit: OEM
Front speakers:OEM
Rear speakers: OEM
Battery: top of line walmart brand(LOL)
Wiring: 1 run of 0 ga
Amp: Ultra Linear UL801
Sub: Lanzar MAX12
Getonerd's Youtube
Getonerd 's car audio files
getonerd is offline   Reply With Quote
Old 03-03-2007, 09:08 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
that will probably wreck your sub because it's not powerfull enough...you'll probably push the sub too hard by turning up the gains to get the sub louder. that'll cause a distorted signal and that is what will blow up your sub.
get a good quality amp and sub and be done with it. I have a rule of thumb of sorts... cheap gear will cost a lot more then good gear. Meaning that cheap gear will break a lot easier/quicker then good components and will require you to replace stuff more often... costing you more in the end.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-03-2007, 11:51 PM   #4
supraman22's Avatar
supraman22 is an unknown quantity at this point
^^ what he said. I know alot of people who underpower thier subs by alot. For example i have a friend that has the amp you are talking about, most likely a dual amp, and then he has RF P2's. Throw the old amp out and go searchin. Match your sub with your amp, rms wise and if you can get ohm's try and match that also. About the best thing you can do is look into stuff, as i have found the best tool sometimes is trial and error. I've been driving for a little over a year and ive had numerous combonations or subs and amps. I'm finally settled though.
Right now i have 2 infinitys, 300 rms each approx., my rockford amp is 300rms approx. Matching is the key.
Are you planning on bridging the sub??
Rockford Fosgate 5002 (subs)
(2) 12" Infinity REF1252
(2) Pioneer TS-A1681R 6.5
(2) Pioneer TS-A4670R 4X6
(2) Polk Audio 2" Tweeters
supraman22 is offline   Reply With Quote
Old 03-04-2007, 03:48 AM   #5
yes im looking to do what ever brige the sub i want to use it to its full power looking at amp now i never new they had RMS i thort it was just sub No wounder Ther sub is so low
So if my sub is 380 RMS 1300 MAX WATTS
Then is say on the box recomed power is 300 RMS continous power
So i need to look for a amp with say 360 RMS does now matter what the max watts is
Can some one tell me a good nice priced amp i can run this sub on as its very very fine
i allways thort u matched the amp 400 watt to the subs 400RMS
But its the amp RMS to the subs RMS
but i don;t understand the ohm
Old 03-04-2007, 11:02 AM   #6
supraman22's Avatar
how much are you wanting to spend on an amp, knowing that, there are probably alot of suggestions people could give you.
pioneer, sony, fosgate, xtant, mtx, all carry amps to match, but there is a wide variation of pricing.
Old 03-04-2007, 02:46 PM   #7
i just wanna ge the best from my sub real so if the sub 380 RMS 4 OMS
What kina amp am i looking for
360 RMS 3 OMS??
i fpound this amp
Boss Audio 760W
320 Watts RMS Bridged into 4 Ohms
http://cgi.ebay.co.uk/ws/eBayISAPI.d...1004&rd=1&rd=1
This not power fully enoight for my sub ?
Old 03-04-2007, 04:54 PM   #8
MySQL Error
scott_fx's Avatar
like suggested before stick with name brands (not boss)
check out the Infinity REF611A it shouldn't be too expensive or if you can get a 2 ohm sub (or dual 4 ohm voice coils) check out the Infinity REF311A. they aren't terribly expensive and should last you
M10k
My Car Pc Install
Old 03-05-2007, 01:11 AM   #9
i see http://cgi.ebay.co.uk/INFINITY-REF61...QQcmdZViewItem
456 watts RMS x 1 channel at 4 ohms and ≤ 1% THD
my sub is on;y 380 RMS this ok
Old 03-05-2007, 01:17 AM   #10
i still don;t really get it what kind of RMS am i looking for my 380 RMS sub
Do i go a little higher or lower some people say hi and some say lower
i wanna keep the sony sub as its really nice
Old 03-05-2007, 01:58 AM   #11
TheQuinsta's Avatar
TheQuinsta is an unknown quantity at this point
Rule of thumb is you go slightly larger than the speaker max so prob round 400 rms but you wanna make sure of it , take it to a well recommended dealer and ask them, if they say "they will cut you a deal on this real good amp goes hard etc etc " go elsewhere. they can also get it right on because your continious power is different from your RMS power
Wassup Manus
TheQuinsta is offline   Reply With Quote
Old 03-05-2007, 12:30 PM   #12
ok i have found a 2000w amp with is 2 x 400RMS 4 oms
boss tho that good ?
Old 03-05-2007, 12:48 PM   #13
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
FFS can you read man?
kevinlekiller is offline   Reply With Quote
Old 03-05-2007, 04:11 PM   #14
i thort BOSs was named make i allways thort boss whay a good make
What about this
http://cgi.ebay.co.uk/4x-400W-MOSFET...QQcmdZViewItem
look little to cheap
Or even thisd look a lot better
JBL GTO601.1 580 WATT MONO AMPLIFIER
http://cgi.ebay.co.uk/JBL-GTO601-1-5...QQcmdZViewItem
Please help me im a noob at this
Please
Old 03-05-2007, 05:06 PM   #15
supraman22's Avatar
being a noob has nothing to do with it. you want slightly more rms. walk yourself into a audio store, best buy for instance, they will most certainly point you in the right direction. you arent really taking any of our advice.
audio stores/web sites > ebay
EDIT: if your bridging it you need to be looking for the 2 ohm, if you have a 2 ohm sub atleast. At 2 ohm you get more power. for example, 400 rms @ 4 ohm --- 600 rms @ 2 ohm
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
if amp outputs 600w, and sub is 500w RMS...good/bad? senseless228 Car Audio 20 09-08-2006 06:00 PM
WTB: 4x > 50 watt RMS amp spazegun2213 Classified Archive 0 09-26-2005 10:58 PM
FS: Rockford T10001bd mono block amp (1000watts RMS at 1ohm) therussman2002 Classified Archive 0 07-26-2005 10:29 AM
I need to some basic information about amps Bust_A_Cap Car Audio 21 08-01-2004 10:31 PM
