Old 03-04-2007, 02:07 PM   #1
Kurack is an unknown quantity at this point
What am i doing wrong, m2-atx wiring to amplifier
I have my carpc hooked up to 12v power and negative and also the accesory switch...the pc turns on everything is great.
I have a rockford fosgate amp hooked up to 12v and negative. How do i get the amp turned on? Im using the wiring from the zoompc case. I have the jumper with wires on J6 and on the other end one cable goes to the REM part of the amp and the other wire to negative <?>
I want to test my speakers and before i make everything nice i want power to the amps to test the speakers...what it the best way to get the REM part of the M2 to power up my amp?
When the car is running i am showing 13v going to the remote on the amp, the same(ish) to the power on the amp....but the amp isnt running. Is there something I am missing? Why isnt the amp turning on? The fuses on the amp are fine.
ok i got it working somewhat...my problem is the carPC runs always now...i dont even have the ignition wire hooked up! Why when there is 12v power present it turns the carPC on. When i turn my car off the carPC continues to run.
Kurack is offline   Reply With Quote
Old 03-04-2007, 04:24 PM   #2
volum3rider is on a distinguished road
Are your jumpers for the m2-atx set correctly for what you want it to do in terms of startup and shutdown and is it configured in Windows for your computer to hibernate/standby. Also, the positive of the amp turn on jumper is the only one that you need for your amps to turn on.
volum3rider is offline   Reply With Quote
Old 03-07-2007, 07:02 PM   #3
pancit175 is on a distinguished road
your remote wire out of the m2-atx may be bad. I've had that problem while before I changed to the DSATX. The problem thats was happening with my m2-atx was the fact that it was putting out +12V but after I tested it further, the current was not powerfull enough for a relay, which only requires about 200mA if even that much. So you may have a bad psu. I just ended up using a timed delayed relay triggered by the IGN wire, instead of relying on the remote wire.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 03-12-2007, 09:39 AM   #4
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
care to share which one u purchased. I'm having the same problem.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 03-12-2007, 12:02 PM   #5
XC-C30's Avatar
XC-C30 is on a distinguished road
he bought the DSATX...
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 03-12-2007, 02:37 PM   #6
Terminal flasher
i know he did but he also said he bought a timed relay.. thats what i'm interested in.
03 Acura RSX Coupe
Old 03-14-2007, 08:44 PM   #7
I forgot which one I had used, I just had one lying around at the time. I believe the part number is 555t from DEI, dont quote me on that. There are a lot of those things around with analogue adjustments or programmable, some more complicated than others.
I just looked now and if you go to www.soundgate.com ->Trigger Devices -> Amp Turn-On Delay #TRIGDLYA
Look for something similar to that...
PROGRESS:
Need Help - BMW's Signal Differential Speaker Wiring, Amps and SVEN4 lloydy Car Audio 8 02-14-2006 07:43 PM
'95 windstar amplifier wiring question Vchat20 Car Audio 1 03-04-2005 08:13 PM
500watts amplifier wiring Magsino Car Audio 8 01-03-2005 03:40 PM
Need some help with sending audio to stock amp orangewhip General Hardware Discussion 12 09-04-2003 02:21 PM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 03:11 AM
