Old 03-04-2007, 10:27 PM   #1
oddcrap is an unknown quantity at this point
[HELP] RCA to my mustang or zune playable
Hi,
I have a 2004 mustang, and I'm trying to figure out a way to find out a way to stream (NOT FM TRANSMITTER) my music from my zune into my current audio device without having to tear out the stock radio. Does anyone have any ideas? I want to keep the look stock, and clean. I fear if I put in a aftermarket radio it will destroy the overall look of the interior.
PS: There is no RCA plug so I can't buy an adaptor.
oddcrap is offline   Reply With Quote
Old 03-04-2007, 10:37 PM   #2
supraman22's Avatar
supraman22 is an unknown quantity at this point
As far as i know there is no way of doing that. If you bought an after market cd player you can buy ipod ready (compatible with the zune, just have to buy a cord) ones that have aux inputs on either the front or back. Other than that i think the only way of having one is the fm transmitter, and from my experiences with one, it quiets your music down quite a bit. Which is unfortunate.
Rockford Fosgate 5002 (subs)
(2) 12" Infinity REF1252
(2) Pioneer TS-A1681R 6.5
(2) Pioneer TS-A4670R 4X6
(2) Polk Audio 2" Tweeters
supraman22 is offline   Reply With Quote
Old 03-04-2007, 10:40 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
There are wired and wireless FM transmitters. Wired ones are pretty cheap ($50).
Another option is to get a source switching thing basically it takes in 2 sets of RCA's and depending on what is selected, it spits out only 1 of them. So you would connect your HU to in1 and mp3 player to in2 and then have a switch upfront to select between the 2.
Old 03-04-2007, 11:49 PM   #4
Siezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to allSiezmik is a name known to all
You don't need to have RCA outputs to get an adapter. Check with P.I.E. (http://www.pie.net), there's a good chance they'll have an auxillary input converter that will match up with your stock head unit.
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
StreetDeck DOES support Zune! terrygold StreetDeck 6 12-21-2006 02:02 AM
minimum distance between power & rca wires michaelrj9 Car Audio 11 08-30-2005 02:02 PM
