Old 03-05-2007, 09:33 PM   #1
skiWVUxtm is on a distinguished road
Power wire and distribution block setup
Just checking if I'm on the right track for my setup:
From the battery positive terminal I'm running 4 awg wire, with an inline fuse within 18" of the battery, to a fused distribution block in the truck (more like the middle of the vehicle). From the distribution block I'll be running two 8 awg wires, one to my eD NINe.4 amplifier and the other to my PSU though initially I'll only be setting up the amplifier (will add the PC setup later). The amplifier will be powering two front speakers (Infinity Kappa 680.7cs) and a sub (Infinity Reference 850w). I'll be using 12 awg wire to connect both the speakers and sub. Since I won't be setting up the PSU/PC quite yet I'll just hook up the amplifier to my stock headunit for the time being. That should be it for my audio setup...
Couple questions:
1. Do I need to run 4 awg wire from the battery negative terminal to the vehicle's body (along with the grounds from the amplifier and PSU)?
2. Should the ground wire from the amplifier and PSU both be attached to the same grounding point on the vehicle's body or does it really matter? The reason I ask is because the PSU/PC setup will most likely be in my center console (in place of my CD changer).
3. Is it fine to connect both the speakers and sub using the 12 awg wire?
Any other feedback/suggestions would be greatly appreciated =)
Thanks!
- TL
skiWVUxtm is offline   Reply With Quote
Old 03-05-2007, 10:19 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
1. No.
2. That's a matter of debate. I have a distro block for both power and ground, so all my grounds will be to the same point.
3. I'll let someone else weigh in on this, as I don't know.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 03-05-2007, 10:22 PM   #3
lbridges is an unknown quantity at this point
Well, I'm a noob on carputers (been lurking for months here and self-teaching Photoshop, Flash, etc), but I've done car audio for many, many years.
Q1: This is one leg of what is/was known as the "big 3". The other being batt+ to alternator, and batt- to engine block. If you do the batt+ to alternator wire, don't overlook fusing (using a fuse or fusible link).
Q2: Becomes an issue only if you find yourself with ground loop problems. However, a rule of thumb is that anything in the audio stream should be connected to a common ground point to help avoid ground loops (and attendant alternator whine).
Q3: 12 gauge is fine for your proposed sub, 12 is overkill for the main speakers, but won't hurt anything (16 would be OK).
lbridges is offline   Reply With Quote
Old 03-05-2007, 11:52 PM   #4
@DarquePervert
Thanks for the info. I was thinking about doing the distro block for my grounding but since the PSU and amplifier aren't near each other I didn't want those wires going long distance (trying to keep them as short as possible).
@lbridges
1. So it sounds like this isn't necessary but it could help with reducing voltage drops and less strain on the vehicle's charging system (via Big 3 thread).
2. Hopefully I won't have the ground loop issues but if that is the case then it sounds like I will have to rethink the location of my amplifier and PSU. I guess if this is the case then I could get the distro block and ground everything in one central location.
3. Ok, I was just wondering. Maybe I'll hold onto the extra 12 awg and get some 16 awg which might be a little easier to feed around the vehicle.
Thanks much!
- TL
Old 03-06-2007, 08:32 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
you actually want smaller gauge wire for your highs and mids.
it has to do with slowing down the electron flow so that your audio signal will not travel quicker to your mids/highs than it will to your subs.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 03-06-2007, 09:21 AM   #6
J187's Avatar
J187 is on a distinguished road
All though upgrading the ground strap from neg to chassis IS part of the "Big 3" I'm concerned by your post that you are considering just running a ground wire to the chassis without realizing that you are supposed to be changing the one that already exists, not just adding another. Also, unless its just something you want to do, you may want to verify that you have a ground problem w/ you vehicle before going to all that effort. YOu may not need the big 3 after all.
Ground all of your audio sources that are in the same audio loop to the same location. Other sources that have nothing to do w/ the loop can be grounded in isolation. An example of loop would be radio to amp. Ground the amps with the shortest possible wire OF THE SAME AWG AS YOUR POWER INPUT WIRE TO THAT AMP to the nearest, THICK metal structure. Use a gritty sand paper and sand the metal area if painted or treated with anything, and after connecting the ground wire, spray over it w/ an anti corrosive primer or paint. Using a smaller AWG wire for your interior mains is actually sound advice (sorry, pun intended). 12awg is right for the sub, but even 16 would be fine for your infinity speakers, 14 if you insist, but no bigger.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings View Post
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
J187 is offline   Reply With Quote
Old 03-06-2007, 09:11 PM   #7
Great, thanks for the info!
Yes, thank you as I was confused about running an additional wire from the negative terminal to the chassis. If I run into any ground loop problems then I'll revisit this "Big 3" for replacing those wires. Thanks for your help and clarification.
power distribution block question dyeinbreed Car Audio 0 10-03-2006 11:20 AM
Just bought a new amp, distribution block and wiring. Now I have questions. Maheriano Car Audio 63 08-29-2006 04:27 PM
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 01:38 PM
Which side of the distribution block should the inline fuse be? Maheriano Car Audio 11 06-16-2006 12:19 PM
What size fuse should I use on distribution block going to Opus power supply? smoldyr Power Supplies 5 01-08-2004 12:38 AM
