Old 03-06-2007, 07:54 PM   #1
Kurack is an unknown quantity at this point
Question about component crossovers
I have the Rockford Fosgate T162S component speakers that come with tweets and the crossover devices. I always though the crossover devices took one input (+ / -) from the front channel on your amp and then had two outputs, one for the component speaker (+ / -) and one for the tweeter (+ / -). I noticed on my crossovers I have 2 inputs, one for the component and one for the tweet and 2 outputs.
Should I be running another speaker wire from my amp to the crossover?
Kurack is offline   Reply With Quote
Old 03-06-2007, 08:26 PM   #2
XC-C30's Avatar
XC-C30 is on a distinguished road
look at the manual. you only need the input where it says "mid". the other input is for bi-amping.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 03-06-2007, 08:27 PM   #3
ok...will do.
For what its worth, I have the following inputs:
+ TW -
+ MID -
and the following outputs:
+ TW -
+ MID -
Attached is a picture. So i just go input to MID and output to MID and TW
edit: ok I just RTFM...your dead on my friend. I just need to make sure the jumper on the xover is set to normal mode...no doubt this is the default.
Old 03-07-2007, 01:04 AM   #4
acollaro's Avatar
acollaro is an unknown quantity at this point
Maybe I am not following correctly , but if your only using one amp you don't have to hook up the TW +.
acollaro is offline   Reply With Quote
Old 03-07-2007, 08:48 AM   #5
J187's Avatar
J187 is on a distinguished road
Acollaro - if you are only using one amp FOR THAT COMPONENT SET, then you only need the single amp input, in the case of Rockford, it is the Mid input. Take a regular set of components. You have a midrange/midbass speaker and you have a tweeter. Tweeters play the high frequencies, while the driver plays the rest. Ordinarily, the frequencies are divided in the Crossover and sent to each speaker accordingly, however, in this process, a lot of the efficiency is lost in the complex coiling of conductors. Also, whatever settings are made on the amp, apply to both speakers before division takes place. Bi AMPing uses one amp for highs and one for mid's. IN passive xovers that allow for biamping, there is considerably less coiling involved and higher efficiency results. Also, a greater level of control can be acheived. NOW, sounds good, but before you run out and start biamping everything on the planet there are drawbacks, such as cost and cost and cost and others, and also there are specifics involved as to type of speakers, amps, setup in the car, other equipment, etc, etc. It doesn't work for everyone.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings View Post
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
J187 is offline   Reply With Quote
Old 03-07-2007, 09:51 AM   #6
DavC is on a distinguished road
ok, here come's a (possibly) stupid question.
if your speakers are biwired (one channel for the tweeter, and another for the woofer), then why would you have a crossover at all?
seems silly splitting the freq's, then sticking them back together, only to then split them up again? (or am i missing something?)
DavC is offline   Reply With Quote
Old 03-07-2007, 10:20 AM   #7
Dennis5587's Avatar
Dennis5587 is on a distinguished road
bi-amping is just using two amps, those amps might now have the X-overs set up, meaning you'd still need to slpit the signal
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 03-07-2007, 01:10 PM   #8
J187's Avatar
That seems ambiguous to me. There is no reason why you couldn't set the crossover on each amp to hi pass and low pass and select a frequency range that works.
The primary reason for continuing to use the crossover is that factory made components come with crossovers designed to deliver EXACTLY what each speaker "wants". That means the proper frequency band, but it also means other things, primarily attenuation slope. Different drivers perform different at different slopes. The factor that built your speaker knows the exact frequency range and the exact slope that makes that speaker perform at a maximum level. You COULD, with a good enough amp xover, emulate that same setup by finding the proper slope and cutoff points and wind up, after HOURS and HOURS of work and headaches, with a proper delivery for maximum performance. BUT, why the hell would you do that when the company is nice enough to provide you with the work already done? Remember, passive xovers included with good components are better for the most part than those included on most consumer amps. I am not against xing over twice, but I disagree with xing over more than twice. IE Headunit xover set, amp xover set and passive xover for comps. Thats why I prefer HUs that allow for the setting to xover to Defeat.
Please help.
Old 03-07-2007, 03:27 PM   #9
cheers.
Old 03-07-2007, 05:42 PM   #10
J187's Avatar
And Davc, THAT was a good question. Certainly nothing silly there. A rather shrewd observation actually.
Please help.
Old 03-07-2007, 06:25 PM   #11
well thank-you lol
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
crossover question yonu Car Audio 2 06-11-2005 05:06 PM
Question about crossovers, etc. jchahn Car Audio 4 06-09-2005 06:36 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
Question for Developers - Help find WMP bug workaround GingerPrince Software & Software Development 4 01-14-2004 02:52 AM
