Old 03-11-2007, 07:55 PM   #1
Niskyspy is an unknown quantity at this point
What sound cards are you running?
I am beginning my research on how to get good sound quality out of CARputer, so I'd like to know how your setup is made and what audio cards you are running.
Thank you
Niskyspy is offline   Reply With Quote
Old 03-11-2007, 08:26 PM   #2
vfinterceptor's Avatar
vfinterceptor is on a distinguished road
Audigy 4.
KXproject drivers.
3.5 to RCA cables out to pioneer amps, Then to MB Quart components and 12" sub.
Sounds good and more volume than I will ever need thank-you-very-much!
Cheers
BJ
vfinterceptor is offline   Reply With Quote
Old 03-12-2007, 08:46 AM   #3
J187's Avatar
J187 is on a distinguished road
http://www.mp3car.com/vbulletin/sear...archid=3426789
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings View Post
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
J187 is offline   Reply With Quote
Old 03-12-2007, 09:31 AM   #4
Megalomaniac's Avatar
Megalomaniac is on a distinguished road
I been googlin around for the alpine 701 processor, cant find much info. What exactly is it .... And where can I buy one?
Megalomaniac is offline   Reply With Quote
Old 03-12-2007, 10:06 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
can't link to searches..
However, you can link to a thread that's located in the Car Audio FAQ that lists off the different external sound cards: http://www.mp3car.com/vbulletin/car-audio-faq/88081-ultimate-usb-firewire-external-soundcard-list.html
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 03-12-2007, 11:29 AM   #6
J187's Avatar
Yeah, I know you can't link searches. But it gets the messages across when people click it and are confused and then go back and read the link where it says "SEAR" and realize that I've done nothing more than run a search with "sound Card" and got hundreds of hits.
Please help.
Old 03-14-2007, 03:30 AM   #7
ankur's Avatar
ankur is an unknown quantity at this point
Audigy 2 NX, replacing with a Philips Aurilium this weekend.
ankur is offline   Reply With Quote
Old 03-14-2007, 12:00 PM   #8
I don't think you're gonna like that one.
I didn't.
Low power output and a very frustrating driver suite. Especially on a 7" touchscreen.
low cost though.......
Cheers
BJ
Old 03-14-2007, 03:12 PM   #9
ankur's Avatar
BJ
Not too concerned about the low power output, have a good amp. The screen size can be troublesome in tweaking i agree, but i dont play with it too much after the initial setup. I am just tired of the Audigy not remembering the settings and i have to exit Centrafuse go into the EAX program and set it up.
If the Philips doesnt work well i can always switch back.
cheers.
Old 03-14-2007, 06:05 PM   #10
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
i'm running a crystal dac for a 'sound card' now but my previous setups were:
sb live 5.1
sb live 5.1 w/kxproject drivers
sb live 5.1 w/kxproject drivers-> audio control 24sx linedriver/xover
alpine pxa-h701
crystal dac -> phaze/butler ldx-23 active x-over
each step has netted an improvement over the previous (still waiting to test the crystal dac but have high hopes for it)
I've always recommended; for a budget system, to look for a sb card that can handle the kxproject drivers and you probably will be happy.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 03-15-2007, 03:48 AM   #11
ankur's Avatar
I would have probably gone with a SB live myself but unfortunately the case i bought didnt have room for any cards. The initial placement of the PC needed a small case, i have since changed the location and now i can get a larger case. I am just holding off on the expense for now, but its something i plan to do later anyway since i want to replace the onboard VGA with a decent video card too.
cheers.
Old 03-15-2007, 07:01 AM   #12
KingofCorona is an unknown quantity at this point
I have an E-MU 0404 card. Works great. The supplied software, patchmix DSP allows for major tweaking. Includes a 4 band para eq. Good signal to noise ratio. Lots of inputs and outputs, including digital.
I have also tried the M-Audio revo card. Good card too. It does 5.1 if you need this option.
05 Acura TL
CarPC 99.99% Done
KingofCorona is offline   Reply With Quote
Old 03-17-2007, 12:59 AM   #13
vipervin is an unknown quantity at this point
I didn't.
Cheers
BJ
i agree. the driver suite was annoying and a pain to adjust without mouse/keyboard.. touchscreen didnt cut it. i eventually just switched back to my on-board audio
vipervin is offline   Reply With Quote
Sound quality of running 3.5mm into RCA and then outputting to subs? AznArkitekt Car Audio 5 10-12-2006 11:25 AM
Need Help Running One Touchscreen Lilliput and Two Clarion Headrest Monitors? VAN~MZD~6 LCD/Display 3 07-18-2006 04:30 PM
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
Car's power capabilities claylong Power Supplies 34 12-04-2002 09:50 AM
log off sounds.... Loftus General MP3Car Discussion 15 10-17-2002 09:23 PM
