Old 03-12-2007, 11:05 AM   #1
MadeinBrasil is an unknown quantity at this point
2 Amps to Headphone Jack?
I have an onboard soundcard and im trying to connect it to 2 amps (4channel 460W each). Do you see any problems with splitting the RCA's? Enough voltage/power? I'm a good computer technician, but when it comes to car audio I'm just a noob! Help ASAP please! Thank you
Brasil in 2007...
MadeinBrasil is offline   Reply With Quote
Old 03-12-2007, 11:12 AM   #2
david69leonard's Avatar
david69leonard is an unknown quantity at this point
What kind of MB you using? I know with the M10000 you can set all three of the audio connections to do 5.1 so you wouldnt have to split the RCA's
david69leonard is offline   Reply With Quote
Old 03-12-2007, 11:53 AM   #3
the M10000...how do i set that up? Thank you for your fast reply
Brasil in 2007...
Old 03-12-2007, 12:16 PM   #4
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
http://www.via.com.tw/download/mainb...IA-M_v1.40.pdf
Give this a shot I can only spoon feed half of the way. Search is your friend! Its always good to have a manual on hand also but this should set ya up
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 03-12-2007, 12:36 PM   #5
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
There is a sticky too. "How to get 5.1 out of your via board" or something close.
Old 03-12-2007, 12:47 PM   #6
Thank you very much guys, I am looking into that pdf at the moment! And so I guess what I need is to set it up as a 5.1, correct? If its not set up as a 5.1, will splitting the RCA mess things up? Scary when it comes down to burning your hardware!!
Brasil in 2007...
Old 03-12-2007, 01:00 PM   #7
Thanks for the pdf, it was easy to understand, and I am working on my amps today still! Thank you again
Brasil in 2007...
Amps, watts, volts and ohms dagnasty The FAQ Emporium 1 12-30-2005 12:35 PM
headphone jack misery fluffy2097 Car Audio 4 07-04-2005 07:31 AM
will the opus 150 power my system? I have all the figures intense Power Supplies 13 04-15-2005 03:55 PM
Laptop speakers output even with headphone jack in use ruairi Car Audio 3 03-09-2005 11:24 AM
could I connect a laptop headphone jack to a radio with an Aux in rca plug. Amax Car Audio 2 03-01-2005 06:23 PM
