The MP3car.com Store
Thread Tools Display Modes
Old 03-22-2007, 01:39 AM   #1
red_parchel's Avatar
Vehicle: 2000 Chevy Blazer 4door 4x4
My Photos: (11)
Powering amps and car pc
OK, well my "power issues" have bee discussed over here http://www.mp3car.com/vbulletin/showthread.php?t=81446 a while back, but now i'm throwing a PC into the mix, i've got 2 orion hcca amps (2500D-driving subs & 4004-driving components) i've got two 4awg wires going into the 2500D(as per the manual) and one 4awg wire going into the 4004(as per the manual), I need to get power for my pc as well, my question is this can/should i put a distribution block on one of the 4awg wires and take a "lil" juice off of that?
and which wire should i "tap"? i know the power all comes from the same place ... so does it make a difference? other option run another power line back from the battery ..
pc isnt TOO much of a power hog: 1.5ghz via c7, one 3.5" sata hdd, usb touch screen and a OPUS 120 watt PSU
thoughts? experience? pc shuts off when bass hits?
thanks Red
Carputer Status:
MobileOne: Gentoo reinstall/optimization - coming soon!
MobileTwo: ubuntu quick fix while MobileOne's out of service
--worklog--GeekBlog--
Audio: stage 2 nearing completion
red_parchel is offline   Reply With Quote
Sponsored Links
Old 03-22-2007, 01:48 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
When possible always run another line. I am unfamiliar with the current your amps draw, but if the manual says minimum dual 4awg, then the answer is no. If it says reccommended dual 4awg to 6awg wire, then you should be ok.
If you already have 3 huge holes in your firewall, what is 1 more little one?!
And the PC wont draw that much, but it is just neater. I doubt you would want to replace those multiple big wires with an even thicker single wire to a distro block because that would get overly expensive.
I say just run a little wire direct from the battery.
Old 03-22-2007, 01:27 PM   #3
My Photos: (11)
haha, my B&D FireStorm cordless drill isn't too great at punching holes in the firewall ... HAHA - [background] I'm at college without all the tools of the home garage until may[/background]
how little is wire everyones running? 8awg? 16? smaller?
Carputer Status:
Old 03-22-2007, 03:15 PM   #4
2k1Toaster's Avatar
My Photos: (1)
8-10awg is standard. I use 4awg for my via.
Old 03-22-2007, 05:57 PM   #5
klp45's CarPC Specs
klp45's Avatar
My Photos: (0)
Running 12awg to my m10000
'98 Acura TL 3.2 >Epia M10000 >512ram >200gb >XP pro>Lilli 619> Opus 120
TESTING as of 6/22/08 - Intel D945GCLF, 2GB RAM, 80gb HDD, XP pro SP1, same Lilli & Opus 120
klp45 is offline   Reply With Quote
Old 03-22-2007, 06:22 PM   #6
EricE's CarPC Specs
Vehicle: '94 Land Cruiser
My Photos: (0)
For my M10K, I hooked into my 0 guage I ran for my amps. No issues at all. But then 0 is big stuff. Personaly I would hook into one (or both) of those runs of 4awg and run it off of that. But that is just me. I tend to cludge things up untill is causes problems and then spend ungodly amounts of time trying to fix the problems. If you want to avoid that, run a new wire for your PC.
EricE is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Why not Home PC speakers for the car? RedGTiVR6 The FAQ Emporium 22 03-05-2008 03:35 PM
best way o connect ar pc to amps? steveb Car Audio 4 01-14-2007 02:17 PM
FS - Assorted Car Pc Parts OriginalNick2 Classified Archive 9 06-23-2006 06:41 PM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 12:42 PM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 07:59 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
