05-03-2007, 03:12 PM
#16
Vehicle: 1989 Toyota Corolla GTi & Huyndai Sonata 2000
RADIO button is'nt work!
I try to adjust Cantrafuse that radio worked through a radiator. When I press the button of RADIO at me there is a menu but reactions to buttons any are not present. I cannot cause the menu of adjustment of frequency, to thumb through frequencies it is impossible... Centrafuse not start a radiator. Even if the radiator is started, Centrafuse it does not see. But! In version 1.10 all worked!
and....
this - http://forums.fluxmedia.net/showthre...=5903#post5903
Sonata Project [ ##########] 100%
Corolla Project [ ##--------] 20%
05-03-2007, 04:27 PM
#17
MySQL Error
The radiator plugin has not changed in a long time...
Is it creating a error.log file?
david
05-03-2007, 07:05 PM
#18
Vehicle: 1990 VW Corrado
I am really liking this new version...
Anyway... it crashed on me once today while I was seeking through a song.
Quote:
5/1/2007 4:25:44 PM
Unable to open COM1
at centrafuse.SerialStream.Open(String port)
at centrafuse.satradio.satPowerUp(Int32 channel)
5/1/2007 4:45:14 PM
The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx (ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at CFIG.CFIG.loadCFIG()
5/1/2007 4:48:14 PM
5/3/2007 4:25:41 PM
URI formats are not supported.
at System.IO.Path.GetFullPathInternal(String path)
at System.IO.File.Delete(String path)
at web.favorites.removeBtn_Click(Object sender, MouseEventArgs e)
5/3/2007 4:25:44 PM
5/3/2007 4:27:42 PM
The given path's format is not supported.
at System.Security.Util.StringExpressionSet.Canonical izePath(String path, Boolean needFullPath)
at System.Security.Util.StringExpressionSet.AddExpres sions(String[] str, Boolean checkForDuplicates, Boolean needFullPath)
at System.Security.Permissions.FileIOPermission.AddPa thList(FileIOPermissionAccess access, String[] pathListOrig, Boolean checkForDuplicates, Boolean needFullPath, Boolean copyPathList)
at System.Security.Permissions.FileIOPermission..ctor (FileIOPermissionAccess access, String[] pathList, Boolean checkForDuplicates, Boolean needFullPath)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode)
at web.favorites.addfavBtn_Click(Object sender, MouseEventArgs e)
05-04-2007, 07:36 AM
#19
david
Yes, creates, but about a radiator there is not present lines... Here a log created on a house computer (neither the radiator, nor a tuner on it is not present)
Code:
04.05.2007 16:39:26
Date contains a syntactic mistake in expression of inquiry 'EmailDate < #04.04.2007 16:39:25#'.
at System.Data.OleDb.OleDbCommand.ExecuteCommandTextForSingleResult(tagDBPARAMS dbParams, Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteCommandText(Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteCommand(CommandBehavior behavior, Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteReaderInternal(CommandBehavior behavior, String method)
at System.Data.OleDb.OleDbCommand.ExecuteNonQuery()
at Email.Email.getEmails()
04.05.2007 16:39:32
Retrieving the COM class factory for component with CLSID {27CE07CA-A416-4811-A25A-02DF14ABE44C} failed due to the following error: 80040154.
at GPS.GPSForm.AOCeNuTpo99B0sjk61jN0Rqi()
This all
It seems to me that Centrafuse at all tries to start a radiator
05-05-2007, 03:05 PM
#20
Vehicle: 1986/chevy/PU crewcab
bad navi engine
Sorry david,
but the new navi engine isnt as good as the last one.
Today I tried to route. The engine seems to be a little hectic. Standig at a traffic light it recalculates the route 5 times. At the next ligts Im stopping and the arrow moves forward and recalculates again, but I was on the right way.
I use the berlin demo map and this never happens befor with the old engine.
Please punch the destinator-boys and get a bugfix.
Matthias
05-05-2007, 05:21 PM
#21
MySQL Error
Quote: Originally Posted by chevyunger
Sorry david,
Matthias
Hopefully this is the sample maps, they are not for this version of the engine...
Is anyone with full maps having this issue?
I have been using it with the new NA maps for 2 months now and not had this issue...
david
05-06-2007, 02:51 AM
#22
iŽll agree to Matthias. The engine is not as reliable as the one in V.1.11
Driving around for 3 hours yesterday, ajusting my setup.
Many times when the arrow wouldnŽt follow the car when i turn, like sideway arrow on the road.
100 meters beside the road.
And i was having 11 sattelites locked at the time.
Only restarting Centrafuse fixed the problem.
And the thing with night skin at daytime and the other way around.
Starting in 3D is totaly UNuseful.
And "menu/favorits/my favorits/destination" can this be made into "menu/favorits/destination" instead. its a lot of clicks.
martin
ps: its the orig. 6.11 destinator skandinavia maps i use.
Reason: Maps iŽm using
05-06-2007, 05:01 AM
#23
david
I hope so, but it happens with the Berlin sample map and my old D3 maps and never happens with the old engine before.
If its a map-problem, please give us a working sample map with the next update, so we can test and will know that we are purchasing a working product.
05-06-2007, 03:42 PM
#24
Vehicle: 06' Audi A3 2.0 TDI Exclusive Line 170HP
I still have the drop down menu bug on my Jetway 7F2WE-2G-OC
Never been fixed during RC versions.
Remind here :
http://www.mp3car.com/vbulletin/981804-post50.html
05-06-2007, 04:49 PM
#25
MySQL Error
Quote: Originally Posted by coucouillu
I never have been able to reproduce this error... I did reproduce and fix the sizing issue with the video window...
Can you email your config.xml file to support so I can test with your exact settings?
david
05-07-2007, 08:31 AM
#26
Quote: Originally Posted by mrluke
not sure if the email software works with gmail ? as gmail uses pop3 and a SSL , it wont work for me n e way
Yes, gmail wont work with the Email plugin ;<
05-07-2007, 08:46 AM
#27
MySQL Error
this will be fixed in the update... I will also have IMAP support as well
david
05-07-2007, 09:59 AM
#28
great!
05-07-2007, 11:00 AM
#29
Vehicle: Opel Astra G 2001
stll nothing on my problem? sometimes when changing the volume it takes up to 5 seconds before the volume changes. in meanwhile the visualisation on the right freezes, and the track title stops scrolling, untill the volume is changed..
this is very annoying... anyone any idea why this happens?
Greetz
Dj NRG
05-07-2007, 06:25 PM
#30
MySQL Error
Greetz
Dj NRG
I have it on my tasks before the update to redo the volume code... It has caused multiple issues and I have a path to get it all fixed...
david
| Thread Tools |
| Display Modes |
Linear Mode
