Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 06-07-2007, 02:59 AM   #31
Cheekz185 will become famous soon enough
WOW all i can really say is great work david. I will be honest though. Since I have had RR i have been pretty happy with it. I stopped testing centrafuse a little while back and I found it to be unresponsive on my system. It kept freezing up (this was a while ago). But today I decided i was goign to install Centrafuse again in the carPC. And it is SOOOO much better. Seriously what a drastic improvement. I feel that it runs sooo much better then before. I am stil testing it out and I really am enjoying it.
But I have some minor issues.
-When I add iGuidance as an application, it worked fine but for some reason it assigned iguidance to every BLANK button. I had to remove iguidance from the buttons and just leave it on one.
-Finally I am trying to test destinator with the NY maps. I have a sirfIII GPS receiver and it cant lock on to any SATS. I have the com set correctly. I have tried switching from SIRF to NMEA and also tried changing the BAUD but it still doesnt work. Also, just out of curiosity, in the NY map is it the entire map? Because it cant even find my zip code, my GF zip code nor our STREETS... No big deal cuz I am still using iGuidance....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 06-07-2007, 12:25 PM   #32
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
the sample map of New York is not the full map...
There was a GPS issue in 1.14 that has been fixed...
I am looking into your issue with the blank buttons, was this with a standard external application? After you added it from Settings?
david
veetid is offline   Reply With Quote
Old 06-07-2007, 12:30 PM   #33
david
It happened when i added iguidance 3.0. And it basically put iguidance in all of the buttons that were empty. I haven't tried adding annother application.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 06-08-2007, 11:13 AM   #34
VENDOR - Centrafuse
veetid's Avatar
I cannot reproduce this just adding an external application... could you give me steps to reproduce this issue with adding to all blank buttons?
david
Old 06-08-2007, 12:08 PM   #35
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
Its a corrupt XML file I reckon
Mine did this first time I added an External app.
Just open the buttons.xml file and the errors will most likely be obvious
HTH
ShawJohn is offline   Reply With Quote
Old 06-11-2007, 10:29 AM   #36
t_bear is on a distinguished road
Question
Quote: Originally Posted by t_bear View Post
GPS not recieving any data?...
This latest release is the only one I've had trouble with getting gps data. I'm using a haicom reciever, and the test prog that comes with the gps shows that there's gps data coming on com3. I've checked and doublechecked my port and baud settings. But still the destinator doesn't get any data (yes I did close the test prog before starting centrafuse.. so there's no other prog using the com port). I'm not using any gps port splitter sw.
I haven't activated centrafuse (haven't had a internet connection on my carputer yet).. is this required before destinator starts using the gps signal?, or do you have any other pointers?
[edit]
Centrafuse is not displaying any error messages or statuses that indicates any problems communicating with the gps
Best regards
T-Bear
Has the gps issue been fixed?.. is there an updated version I can use... so I can test the gps features before I buy?
t_bear is offline   Reply With Quote
Old 06-11-2007, 11:17 AM   #37
VENDOR - Centrafuse
veetid's Avatar
If your GPS worked in 1.13 then the issue you are having has been fixed...
I plan to release a version today or early tomorrow...
david
Old 06-11-2007, 12:41 PM   #38
david
Aahh.. looking forward to it
Old 06-11-2007, 06:41 PM   #39
nadforever is on a distinguished road
ok never gotten this on any version i have tried i dont think but gettin it on a brand new install of 1.14 on a brand new isntall of windows xp as well. but if i keep hitting the eject button next to the hard drive section in media it shoudl go to a nothign playlist and all music and videos stop. but i get all the way down to 0 and there is still a playlist playing!!! how is that possible. that and some times it dosnt save thecurrent playlist that was playing when i exit CF and go back in like it used too. and go right back to the exact song i was playing last time.
nadforever is offline   Reply With Quote
Old 06-12-2007, 03:29 PM   #40
Raw Wave
ShawJohn's Avatar
Well I set CF up on house PC and then copy to CarPC and guess what? I can't activate it as its now tagged to my house PC.
Well its either than or my reinstall of XP after Vista which has casued it.
Also:
Using Silabs radio, it works fine till I switch channels then I get the new channel playing twice, sort of repeated, I pressume this is down to the Radio buffer?!?!
EDIT: This double radio issue stopped when Radio Buffering is turned off
Old 06-12-2007, 06:35 PM   #41
Raw Wave
justintime's Avatar
justintime is on a distinguished road
I too noticed that CF needs to be associated with a specific PC. So, if I can only open CF in my CarPC, how am I meant to develop the skins? How are people meant to develop using the SDK? In their CarPCs? I don't get it.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 06-12-2007, 06:51 PM   #42
had the activation screen come back up again for my cf like a week after i already activated it????
Old 06-13-2007, 01:55 AM   #43
DaKyy's Avatar
DaKyy is on a distinguished road
I also have internet connectivity problems after hibernate - if I was connected before hibernate.
However, I ran into different problem during I found out that... The mute button seems to be toggled, yet the music is still playing and nothing happens whit the mute button. Restarting CF didn't do anything. I haven't tried to shutdown cf, reboot and then restart it but I think that would do it.
Not a huge issue for me, because I hardly ever use the mute, but just thought I'd report it.
Volvo 480 Restoration Project
DaKyy is offline   Reply With Quote
Old 06-13-2007, 03:01 AM   #44
VENDOR - Centrafuse
veetid's Avatar
The activation has been updated too allow two activations, so it can be installed on a desktop/laptop and your car...
the reason the activation screen showed back up is most likely because of this update, you should be able to activate again now and use two...
david
Old 06-14-2007, 01:43 AM   #45
has anybody had this problem first i had ffdshow's audio decoder disabled and everything always worked fine but then i went to play an downloaded HDTV content music video and the audio wouldnt play so i decided to try and enable ffdshow's decorder and that jstu freezes up CF on start up gets stuck on initilizing audio, same thign happend when i whoudl scroll to that video and it woudl also freeze up. any idea's
Centrafuse 1.11 Bugs veetid CF Bug Reports 32 04-16-2007 11:28 AM
Centrafuse 1.1 Bugs veetid CF Bug Reports 73 03-13-2007 09:11 PM
Centrafuse RC5 Bugs veetid CF Bug Reports 161 02-26-2007 06:00 PM
Centrafuse RC4.3 Bugs veetid CF Bug Reports 28 12-10-2006 02:48 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
