The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 08-26-2007, 03:33 AM   #1
My Photos: (0)
SIRF doesn't work after resume from hibernate
Hi @all!
I've a problem with my gps mouse. It's a SIRF device.
Normaly i've 8 - 12 satellites, but after hibernate i would show me only 1 or 2 satellites, so i can't navigate.
If i change the settings no NMEA, i allways have 8 - 12 satellites, also after a resume of my system.
Aktualy my way to work with the SIRF protocoll.
I resume my system, go to settings, change SIRF to NMEA, switch no the Navigation Application and i can see many satellites, so i go back and switch to SIRF and it will work with SIFT, too (until to the next resume after hibernate).
I tryed it with xport and some other tools like this, but i allways get the same results:
With NMEA it works, with SIRF i must allways change the settings to NMEA and following back to SIRF.
I thinks its a bug of CF.
Have anyone the same problem?
Thanks!
tHaHooL is offline   Reply With Quote
Sponsored Links
Old 08-27-2007, 10:41 AM   #2
MySQL Error
veetid's Avatar
My Photos: (0)
I will report this to Destinator...
david
veetid is offline   Reply With Quote
Old 01-25-2008, 12:59 PM   #3
Vehicle: 2007 Peugeot 207
My Photos: (0)
I'm having a similar problem, but with both SIRF and NMEA.
I have to close CF after resuming from hibernation, start SIRFDemo and click "Open data source" and "synchronize port and baud rate" (not sure if the synch. is neccesary). After doing that I can open CF and it instantly starts navigating.
kfuglsang is offline   Reply With Quote
Old 01-25-2008, 01:06 PM   #4
MySQL Error
veetid's Avatar
My Photos: (0)
does your GPS mouse work with any software on resume from hibernation?
you can try to set in System\config.xml the flag RELOADCOMPORTS to True, this will cause Destinator to reinit device on resume, but if the device is not running on resume at all it might not work...
if closing Centrafuse and reloading on resume does not work this most like will not either, but try...
david
Old 01-25-2008, 02:49 PM   #5
My Photos: (0)
It used to work fine with previous versions of Centrafuse.
I'm not sure how to test if it works with other programs after hibernation, but I will definitely try the RELOADCOMPORTS-setting - it sounds like a possible solution.
Old 02-04-2008, 12:18 PM   #6
My Photos: (0)
I just tried setting the RELOADCOMPORTS to True. It didn't seem to help.
When I close Centrafuse, open SIRFDemo and select Open Data Source -> Synchronize Port & Baud Rate (works with the Initialize Data Source as well) -> close SIRFDemo -> Start Centrafuse it's spot on.
After putting it into hibernation and waking it up again the light is on in the GPS unit but Centrafuse reports 0 (or other times 2) sattelites.
Sponsored Links
vB code is On
Trackbacks are Off
HORM and RR : How does it work ? Konrad Road Runner 8 01-23-2008 07:29 AM
Hibernate best way to resume? plz help Lyzdog Power Supplies 3 02-25-2006 08:04 PM
Resume after hibernate scrutinized ldave PowerVoice 6 02-09-2006 11:04 PM
Windows freezing on resume from hibernate? fewman General Hardware Discussion 2 01-26-2006 11:34 AM
M9000 display size on resume from hibernate GingerPrince Software & Software Development 2 05-03-2003 09:30 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
