Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 01-20-2008, 06:04 PM   #1
pijo1971's Avatar
pijo1971 is on a distinguished road
Problem wiht destinator when you plan a trip
Hello,
probably I've found a bug using destinator with CF.
The bug occours when you trying to plan a trip and the destination city name is composed with more words.
For example, if you want to go to "SELVA DI VAL GARDENA" in Italy, it match with SELVA (VENETO VICENZA), but the two place are different!
By The way, if you use the CAP code the match is exactly.
Have you ever had this problem?
Bye bye,
Pijo.
CarPC in Progress [||||||||-] 90%
Visit my Project
pijo1971 is offline   Reply With Quote
Old 01-20-2008, 11:37 PM   #2
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
is this adding a location to the trip? Is it inside the Trip Folder created, hitting "+", and using a new location? does the right name show up in the Trip Folder?
david
veetid is offline   Reply With Quote
Old 01-21-2008, 07:50 AM   #3
pijo1971's Avatar
hi,
this is what I've done:
In the "NAVIGATION MENU" where appear "SELECT ADDRESS SEARCH METHOD" I've choosed "City/Address".
Than I've entered the string "SELVA DI VAL GARDENA".
In the list box it's appeared the exactly name city that I've input, so I've clicked "SELVA DI VAL GARDENA" in the list box and after that I've click "GO".
The application has calculated the route, but the route has want to driven me to "SELVA (VENETO VICENZA)" and not "SELVA DI VAL GARDENA".
Note: SELVA (VENETO VICENZA) is another city proposed in the list box.
I hope that is more clear. This evening I'll try to show you some screenshots.
bye,
pijo.
Visit my Project
Old 01-21-2008, 11:40 AM   #4
VENDOR - Centrafuse
veetid's Avatar
can you reproduce with other locations?
can you copy the information out of the wce.txt file in your map folder...
david
Old 01-21-2008, 06:23 PM   #5
pijo1971's Avatar
Hi,
this is my WCE.txt file
Quote:
Italia:
Italy
Version 2006.Q1.4160 - map of NavTeq. MG V1.4, HLG 3, Toll roads, TMC. WES2. D01. Mp122. Signed map
I've reproduced the problem with another city.
The place that I want to reach is CASTELLETTO SOPRA TICINO.
As you can see I've put the name and than I've click on GO.
but the routing wants to drive me to CASTELLETTO (TRENTINO ALTO-ADIGE)
Instead, if you plan to go to CASTELLETTO SOPRA TICINO using the CAP CODE (28053)
Now the routing is correct (I think that the little error in posistion depend on the default street)
I hope you can solved early my problem.
Bye bye,
pijo
Visit my Project
Old 01-21-2008, 10:27 PM   #6
VENDOR - Centrafuse
veetid's Avatar
must be in the return from the Destinator SDK...
if you go into the street and actually select a street, does that function or cause the same issue?
I will try to output the street ID's for both and compare...
david
Old 01-22-2008, 06:44 PM   #7
pijo1971's Avatar
Yes
Suppose to setting CASTELLETTO SOPRA TICINO, VIA VERNOME (using City/Street method)
The streets box show the correct street
But when you click GO, the route is calculated to drive me ad CASTELLETTO (EMILIA ROMAGNA,BOLOGNA).
Now, suppose to setting 28053, VIA VERNOME (using CAP CODE/Street)
The streets box still to show the correct street.
And this way the route drive me to the correct destination.
bye, bye,
pijo
Visit my Project
Old 01-24-2008, 06:39 PM   #8
pijo1971's Avatar
hi,
have you had success to reproduce the problem? is it only a problem of my setup or is it a general problem?
bye,
pijo
Visit my Project
Old 01-24-2008, 07:34 PM   #9
VENDOR - Centrafuse
veetid's Avatar
I have not yet, but I plan to look into it... I have it listed to check out...
david
Old 01-25-2008, 02:37 AM   #10
pijo1971's Avatar
Ok,
thank you.
bye,
pijo.
Visit my Project
Old 03-13-2008, 07:32 PM   #11
pijo1971's Avatar
hello,
have you found something about this issue?
thank you,
pijo
Visit my Project
Old 01-30-2009, 05:26 AM   #12
pijo1971's Avatar
hello,
I've tryed the new version of centrafuse, but this problem still persits.
Any news about the resolution?
Bye,
pijo.
Visit my Project
USB hub problem always disconnecting / connecting fire General Hardware Discussion 10 09-25-2009 03:30 PM
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 10:28 AM
Took a long trip over the weekend and found a problem with GPS Austin DigitalMods (Scripts / API) 2 12-02-2006 04:06 PM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
Problem with tank battery - any good Plan B? Mastiff Power Supplies 3 06-14-2004 10:10 PM
