The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 01-30-2008, 06:00 PM   #1
My Photos: (0)
Problem Connecting to ELM 327
Let me start by saying, I just switched to Centrafuse and I love it. It does pretty much everything I've ever wanted in a front end, and is incredibly stable.
Okay, on to the bug report. I recently purchased an OBDII Elm-327 scanner off ebay. This unit was mentioned in another thread, mostly in regards to its low price:
http://cgi.ebay.com/ebaymotors/Elm32...3756.m20.l1116
I installed it today, and it works great with Scantool 1.13. Synchs great, updates quickly, no problems. It did not however work with the OBDII plugin for Centrafuse.
I have a normal version of XP(SP2) installed and updated. The OBDII scanner is using COM port 4, 9600 baud. My GPS receiver is using COM port 3. Again, no problems using scantool, and it connects in Centrafuse giving me the green light, but displays no data. I have not yet tried disabling all the values except speed, but that's next. In any case, here's my error log.
Any help would be appreciated. If this fix is coming in a future update, I'll happily wait. I may embed scantool in the meantime. Thanks for taking a look.
Scoop is offline   Reply With Quote
Sponsored Links
Old 01-30-2008, 06:35 PM   #2
MySQL Error
veetid's Avatar
My Photos: (0)
what version of Centrafuse are you running? There might be a newer OBDII version in the 1.47 update, this is newer than the download page...
also try the different ELM settings in OBDII setup, or device types I mean...
david
veetid is offline   Reply With Quote
Old 01-30-2008, 09:10 PM   #3
My Photos: (0)
I did update to 1.47, so that's not it. Also, I tried switching it to the other types of OBDII devices. 323 at least also shows that it connects, but still no data. I don't think the other ones connect at all, but I'd have to test again to give you the point by point breakdown.
The wife has the car tomorrow, so the earliest I'll be able to test it will be tomorrow night.
Thanks for getting back to me so quickly David. One more reason I went with Centrafuse!
Old 01-31-2008, 06:32 PM   #4
MySQL Error
veetid's Avatar
My Photos: (0)
there is a log feature in OBDII settings, turn this on, let it run, and post the log... it is in the local application data folder under Centrafuse...
david
Old 01-31-2008, 08:07 PM   #5
My Photos: (0)
Is that different than the log I posted in my original post in this thread? That was the log in the OBDII folder.
Old 02-02-2008, 09:30 AM   #6
My Photos: (0)
Thumbs up
I got it working. Just like it was suggested in the other thread about OBDII scanners and Centrafuse, I disabled all the fields except for speed and restarted the computer. Worked like a charm. I went back and re-enabled them one by one, and most of them work. The ones that don't work include fuel system pressure, OBDII type, and a couple others. If anyone is interested, I could compile a list. FYI, I have a late model Subaru Legacy.
I'm happy with the fields that do work, and the update rate. Nice job on the plugin, and thanks for the support.
Sponsored Links
vB code is On
Trackbacks are Off
elm pro 327 vs picasso2003 sven1973 Engine Management, OBD-II, Engine Diagnostics, etc. 16 02-10-2007 05:23 AM
ELM 323 or 327? Hoohar Engine Management, OBD-II, Engine Diagnostics, etc. 5 01-24-2007 02:19 PM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 11:50 AM
problem connecting aco PhoneControl 3 10-16-2005 04:10 PM
5'' Displays connecting Problem JRA LCD/Display 8 09-26-2005 02:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
