The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 02-01-2008, 02:24 AM   #1
My Photos: (0)
small problem with satnav volume
The music volume lowers, sat nav speaks, then volume shoots back up to max for a slit second before returning to normal volume. quite annoying if the music wasnt very load to start with.
Is it just me or anybody else have the same problem?
sanjaym is offline   Reply With Quote
Sponsored Links
Old 02-01-2008, 11:02 AM   #2
MySQL Error
veetid's Avatar
My Photos: (0)
do you have use pre as master or use front speaker options turned on in settings? reports these are causing this issue, I am looking into it... if so try to disable these and see if it stops...
david
veetid is offline   Reply With Quote
Old 02-01-2008, 04:59 PM   #3
My Photos: (0)
Yes i am using pre as master. Will try changing it and see if it helps. This might explain why the ATT isnt working either.
At the moment i can change the satnav vol using settings.ini, but have no control over how much the music turns down. Maybe this should be looked at and an option to set it. Some people may want it turned down all the way, wheras i would like to turn it down maybe 20% while the sat nav speaks.
I have found that the volume that the music returns to for a split second is the ATT volume. So it goes from Normal -> Lower (satnav speaks) -> att vol -> Normal Vol
It should go from normal to att volume for sat nav and then smoothly back to normal
Old 02-01-2008, 09:19 PM   #4
MySQL Error
veetid's Avatar
My Photos: (0)
in the config.xml there is ATTVOLUME flag which lets you set this volume, I also have added an option to put it back to pause like it was before...
also adding all these settings to the settings screen so no file editing will be neccesary...
david
Sponsored Links
vB code is On
Trackbacks are Off
wave volume problem carputer1 Road Runner 1 09-28-2007 02:41 PM
Radio Extreme Volume Problem L-U-R-C-H Centrafuse 1 07-26-2006 08:31 PM
Satnav volume? Leegsi Software & Software Development 5 09-27-2005 08:24 AM
Volume problem Lord_Pall FrodoPlayer 13 07-19-2005 10:55 PM
MedicaCar Volume Problem -- Need Help BrUTaL MediaCar 1 11-09-2004 08:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
