The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 05-04-2008, 11:30 AM   #1
My Photos: (0)
hdradio bug
till having problems with my hdradio to work with CF i have all the way up too framework 3.0 on the macine and all that and still i can here cf turning it on and or off cuaes i here clicking when i push the radio button. but after that i cant control it at all and hear no static or anything??
nadforever is offline   Reply With Quote
Sponsored Links
Old 05-15-2008, 08:38 PM   #2
My Photos: (0)
BUG HDRadio volume extremely low with CF RC2
Can you try cranking up the volume?
RC2 seems to set the Directed HDRadio volume very low.
I can hear it if I turn the volume way up.
If I first let the normal Directed controller bring up the radio, and then plug the audio in to my sound card, the volume is fine.
golffnut is offline   Reply With Quote
Old 05-18-2008, 07:48 AM   #3
My Photos: (0)
my problem is that cf is not controling the HDRADIO at all if i click tune up or tuen down the numbers do not move... that and for some reason cf will not unmute the line in. i go and unmute it manualy but if i exit the hdradio go back to my playlist then go back into hdradio line in is muted again so its CF that is muting the line in.
Old 05-18-2008, 09:53 PM   #4
MySQL Error
veetid's Avatar
My Photos: (0)
check your settings, if you turn off buffer it will not mute your playback line, if you want to use buffer make sure to set the recording input and it should mute playback line so it will record and playback through the recorded file on the system...
not sure why not controlling system, try hard coding the COM port...
"C:\Documents and Settings\David\Local Settings\Application Data\Centrafuse\RadioModules\HDRadio\HDRadio.xml"
you can set volume levels and COM port in this file and restart Centrafuse...
david
veetid is offline   Reply With Quote
Old 05-22-2008, 06:19 AM   #5
My Photos: (0)
i already have gone to the XML and changed it to the correct com port and still dead in the water, i heard disabling will stop the muting of the line in. havnt been able to test that part of it yet though. not shure what else could be the problem when the standalone app for hdradio works fine but in centrafuse cant get anything..
Old 05-22-2008, 05:27 PM   #6
My Photos: (0)
Exclamation HDRadio.xml file not there
Such a path does not exist on my XP SP2 machine.
I do not have a login.
The 'Administrator' has no "Local Settings" directory.
PLEASE move this config data to a central place.
These are Car PCs, not general-use PCs.
No need for individual users!!
Old 05-22-2008, 09:50 PM   #7
MySQL Error
veetid's Avatar
My Photos: (0)
these are rules, you have to store files you can write into LocalAppData, or they will not run on Vista...
replace /David/ with the name of the user you have logged in with, and make sure show hidden files is visible...
we have removed most all cases where you need to go here, only a couple things left...
david
Old 05-23-2008, 07:18 AM   #8
My Photos: (0)
back when i had rc2 i had radiomodules and a HDradio folder now when i go to radiomodules there is no HDradio folder.
Old 05-23-2008, 09:24 AM   #9
My Photos: (0)
C:\Program Files\Flux Media\Centrafuse\RadioModules\HDRadio
thats where the module is for me, always has been on 2.x
the config files are right in the the RIGHT place too!
also, HDradio works quite good in RC3, there are a few little things to clean up
but its basicly there
mitch
-Thanks
Mitch
www.rush2112.net
mitchjs is offline   Reply With Quote
Old 05-23-2008, 09:29 AM   #10
My Photos: (0)
i dont believe anywhere in eaither of them has an area to tell it what com port u are using. te original was and XML file
Sponsored Links
Old 05-23-2008, 06:42 PM   #11
My Photos: (0)
sure does
in my install (VISTA)
C:\Users\mitchjs\AppData\Local\Centrafuse\RadioMod ules\HDRadio
there is a file
HDRadio.xml
and the contents of the file
Code:
<HDRADIO> <VOLUME>75</VOLUME> <COMPORT>3</COMPORT> </HDRADIO>
are you running XPE of compact flash?
mitch
-Thanks
Mitch
www.rush2112.net
Old 05-23-2008, 07:26 PM   #12
My Photos: (0)
i am running xp pro on my computer i had it on the last RC (rc2) just dont have the folder this time for some reason.
Old 05-31-2008, 12:06 PM   #13
smeesseman's CarPC Specs
smeesseman's Avatar
Vehicle: http://www.fluxmedia.net/
My Photos: (0)
ANd do you have Windows explorer to show hidden files and folders? LocaAppData is a hidden location by default, but you probably already knew that, just making sure...
smeesseman is offline   Reply With Quote
Old 06-02-2008, 05:01 PM   #14
My Photos: (0)
Thanks.
I did not realize that there could be hidden folders as well as files.
Anyway, I enabled "Hidden Files and Folders" in Windows Explorer, edited the HDRadio.xml so the volume is 80 instead of 35, and all is well with the volume issue now.
Old 06-02-2008, 05:06 PM   #15
My Photos: (0)
Exclamation
Quote: Originally Posted by mitchjs View Post
sure does
there is a file
HDRadio.xml
Code:
mitch
Mitch,
I have radio Buffering OFF.
Did you ever have trouble in RC3 with CF failing to UNMUTE the Playback Line-IN (line-in on my sound card) when moving from Music to HDRadio?
I start CF in HDRadio. The first time I move from HDRadio to Music, CF mutes the playback line-in as it should so I can hear the WAV output.
But I then move back to HDRadio from Music, and line-in stays muted.
Sponsored Links
vB code is On
Trackbacks are Off
Gesture based bug recorder/tracker Iceman_jkh Road Runner 2 12-25-2007 09:28 PM
StreetDeck Bug Reporting System RedGTiVR6 StreetDeck 0 12-10-2007 02:07 PM
Bug Tracking (sorry long but please read) liquid_smoke Software & Software Development 23 04-22-2005 03:12 PM
RR 2-20-05 ... Bug Fixes ... guino Road Runner 123 03-01-2005 01:27 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
