Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 12-06-2004, 04:49 AM   #1
C4M
C4M's Avatar
Re-Opening NM Destinator 3
Once I figured out to point at the EXE rather than at the shortcut (DUH!), no dramas embedding GPS in Centrafuse.
BUG: If I open Dest3, then close Dest 3, and attempt to restart Dest 3 without restarting Centrafuse, then Dest won't start again.
Once I exit and restart Centrafuse, all is OK again.
While we're looking at the GPS screen, can we work some simple noise controls into that screen? It's nice to kill the noise when you're frantically navigating through an unfamiliar patch of town.
Have a screen shot!
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Old 12-06-2004, 11:29 AM   #2
ShawJohn's Avatar
anychance you can send me the config.xml file as I can't get this to work, no matter what I try...
It just will not embed D3 at all!
John
ShawJohn is offline   Reply With Quote
Old 12-06-2004, 12:34 PM   #3
MySQL Error
veetid's Avatar
C4M: If you just click the title bar and get out of fullscreen mode you have all the noise controls...
I made the assumption that you would generally only load GPS once and then always leave it open... Why would you close D3 once it was embedded? My app will close it out for you when you close CENTRAFUSE and it doesn't use much more memory... Currently it just runs the app the first time you click it, but I will add a check to see if its running and re-load if its not there..
david
veetid is offline   Reply With Quote
Old 12-06-2004, 05:51 PM   #4
C4M
C4M's Avatar
I thought about that after I made the post, and realised that it stays open in the background, and you make a good point. Now that I understand that, it would be redundant to close NMDest!
I guess the check and re-load is more an idiot-proofing thing.
C!
Old 12-07-2004, 02:34 AM   #5
C4M
C4M's Avatar
You realise that there is a thread for this specific issue? Your issue isn't related to this thread.
Code:
<GPSPATH>C:\DestinatorApps\Frontend_PREV\Destinator3.exe</GPSPATH> <GPSWINDOWNAME>Destinator 3 - [Dest3.1]</GPSWINDOWNAME>
C!
Old 02-13-2005, 09:10 AM   #6
DjBac's Avatar
When I exit centrafuse destinator will remain open!!!
Is there something I am doing wrong?
DjBac is offline   Reply With Quote
Old 02-13-2005, 11:27 AM   #7
DjBac's Avatar
There is a problem some times.... CF suddenly closes MapMonkey!!!
Is this a common bug??
CD opening 'felt' thingie? Alphared General Hardware Discussion 1 03-13-2004 10:24 PM
Can 7" touchscreen fit in double DIN opening? RDaneel LCD/Display 22 02-26-2004 01:53 PM
Winamp5 opening "open file" dialog... deadweasel Software & Software Development 0 12-22-2003 03:02 AM
New opening mp3car.com page grandamp3 Mp3car Forum Suggestions/Comments 21 08-12-2003 01:22 AM
LCD Text Display for Din opening --Please Help... prerunnerv6 LCD/Display 9 09-24-2002 03:27 PM
