This is because I added code to check to see if the embedded apps were still running every time you click. I base this check on the info supplied in the GPS Application field in setup. When you use the routislauncher it launches Routis and then is gone. Every time you click the GPS button my program see's that the routislauncher program isn't loaded and thinks it needs to reload the GPS application. Not sure how I will fix this one... First thing I would try is to rename the routislauncher.exe to routis.exe and place in another folder, if that's possible. This might fix the problem.
david
