The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 04-07-2005, 11:55 AM   #1
My Photos: (0)
Volume Problem
When you turn the sound down with centrafuse it turns down fine then after a few seconds it will turn itself up and down, sometimes it will go all the way to 100% and back down again, other times it will only move a few % each way. Works fine in windows. Also now and then it sounds like the songs skip ? Even when i am parked !!!
Please help if you can
Mark
vwpc is offline   Reply With Quote
Sponsored Links
Old 04-07-2005, 12:11 PM   #2
MySQL Error
veetid's Avatar
My Photos: (0)
The volume problem is a known issue and has been discussed many many times... It is already fixed in my in progress version and will be in the next release... Not sure why your mp3's would skip, did you install a codec pack by any chance? If so then uninstall it because they are horrible...
david
veetid is offline   Reply With Quote
Old 04-07-2005, 02:59 PM   #3
My Photos: (0)
I did install a nimo dodec pack but promptly removed it when it messed the system up. The only codec now runnig is from DIVX.com. It is only the DIVX codec, should this be removed as it was a solution to video not playing
Many Thanks
Old 04-07-2005, 03:21 PM   #4
silencery's Avatar
Vehicle: 2001 Toyota MR-S
My Photos: (0)
try ffdshow instead of divx. Its generally more stable.
I probably won't solve your mp3 issues though.
Stealth OEM spyder
1204 dot net!
silencery is offline   Reply With Quote
Old 04-19-2005, 01:57 PM   #5
koolaidkitten's CarPC Specs
Vehicle: 2001/Isuzu/Rodeo
My Photos: (0)
OMG!!!!!!!!!!!
i spent all day reinstalling, changing, moving, untightening, calling xenarc, retightening my lower left portion of my LCD touchscreen thinking it was a problem with the sensitivity of the lower left corner of it ^^
koolaidkitten is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
DVD volume much quieter than mp3 volume bosskong Centrafuse 1 02-26-2005 10:53 PM
Volume control question.. Kamakazie2 Software & Software Development 3 10-07-2004 06:16 PM
is it possible to change the volume increment amount? fasternfaster MediaCar 0 08-28-2004 10:30 PM
Sound Volume Issues ether Media Engine 2 08-02-2004 12:24 PM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-03-2003 11:00 PM
Sponsored Links
Ad Management by RedTyger
