The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Thread Tools Display Modes
Old 04-14-2005, 10:47 PM   #1
My Photos: (0)
multiple drives for music path?
I have my C drive and also a usb drive and would like to include music from each in the library. It appears that only one drive can be accepted for the path. How can I include both drives in the library?
thanks
glenn
glennwoudenberg is offline   Reply With Quote
Sponsored Links
Old 04-15-2005, 11:35 AM   #2
Frankino's Avatar
Vehicle: Peugeot 206 HDi 2003
My Photos: (0)
I hope david will include this feature, maybe configuring multiple roots (eg DVD-ROM, HDD1, USB ecc)
EDITT
by the way you could map your USB device partition under a NTFS folder using disk administrator, I never did it but I know it is possible
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Sb Live 5.1 w/ KXProject Drivers
Opus 150w WTF
8" Lilliput TS LCD
40% installing (monitor ok, pc KO, audio KO)
damn car accident
Frankino is offline   Reply With Quote
Old 04-17-2005, 10:17 AM   #3
My Photos: (0)
could someone walk me through the above mentioned process?
Old 04-18-2005, 04:17 AM   #4
Frankino's Avatar
My Photos: (0)
Well I use xp in italian, by the way the function should be under Administrative Tools, computer management, disk management (I guess).
here you see a list of all the disks (removable or not). plug your usb storage and under disk management you'll find it, right mouse click on the disk and select "remove/add drive letter" or somthing like this; here you'll find "map under NTFS folder". simply create a new folder and the drive into it, it should work. remember that my indication may be wrong, i don't use windows in english
hope it helps
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 04-18-2005, 04:36 AM   #5
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Trouble with that is, you may have to do that each time you insert the USB stick.
That's what seemed to happen when I just tried it.
Enforcer is offline   Reply With Quote
Old 04-18-2005, 04:48 AM   #6
Frankino's Avatar
My Photos: (0)
not for me
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 04-18-2005, 09:47 PM   #7
My Photos: (0)
I tried those steps and it would not let me check the ntfs file option. sounds like a solution though. any ideas?
just figured it out-need to hit "add" in the screen prior to the assignment screen
Old 04-19-2005, 02:13 AM   #8
Frankino's Avatar
My Photos: (0)
you can choose ntfs folder only if the partition is not write protected, e.g. a CD cannot be mounted on a ntfs folder, but my usb stick works
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Old 04-19-2005, 11:12 PM   #9
My Photos: (0)
i have an 80 gb laptop drive in an externalcase. I mapped it through an ntfs folder in my C drive, then listed the C drive in the music path in settings. the CF did not pick up the songs on the external drive.
Old 04-20-2005, 05:40 AM   #10
Frankino's Avatar
My Photos: (0)
I admit I never tried with CF, I'll try asap
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Opus 150w WTF
8" Lilliput TS LCD
damn car accident
Sponsored Links
vB code is On
Trackbacks are Off
Multiple CD/DVD drives ??? << Newbie!! dashusa.com Media Engine 0 01-07-2005 12:27 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 12:25 AM
FS: 704MB IDE Solid State Drives dj2fast Classified Archive 54 05-09-2004 04:19 PM
mpxf multiple playlist path redscar Software & Software Development 0 08-17-2002 03:03 PM
Using WinAmp or other across multiple drives? Tony S Software & Software Development 3 04-13-2001 06:59 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
