07-15-2005, 11:09 PM
#136
Mr. Wiggles
spoke too soon. just opened CF on my desktop again and got the dotnet error like in the car ... oh well.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
07-15-2005, 11:14 PM
#137
Mr. Wiggles
I'm attaching a screenshot of the error. You'll notice at the top the artist and song title show up properly. so the tags are being read.
also the file is playing, but I can't get into the media section at all. the error pops up.
My JeepPC Install
07-15-2005, 11:24 PM
#138
VENDOR - Centrafuse
good to know the ogg tags get read... I wrote that and never ran it... I will grab some OGG files and fix all the related problems..
david
07-15-2005, 11:28 PM
#139
Mr. Wiggles
great. let me know if you need me to upload any for you.
My JeepPC Install
07-15-2005, 11:49 PM
#140
ok. ive just been playing with it for a few minutes. heres what ive noticed:
> lack of web browser (did you just plan on letting people use their own as embedded apps or what?)
> multichannel support? i dont know if its because of the current configuration, but i couldnt get any sound either from the music or videos to come out of the rear speakers. and the rear slider in the mixer refuses to slide up as well as the sub slider. my current configuration on the sound card is quad as that's how my 4.1 speaker system is set up (the sub derives the bass from the 4 speakers).
no dvd and no cd playback. cd letter is assigned correctly.
Your everyday carpc geek and tech guru at your service. *bow*
07-16-2005, 01:38 AM
#141
Here is My Cd drive setup: David you said that there is nothing you can do about it. But hopefully it will work in my carPC rite now im testing it on my laptop. I also tried using CD on my desktop but nothing....
Settings...........:
Clicking on CD:
Message I get after: (yes cd is in drive)
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-16-2005, 02:34 AM
#142
Raw Wave
It doesn't even attempt to access the CD drive, if that helps..
07-16-2005, 02:44 AM
#143
I have the same problem as Cheekz185... D: set as CD, but get the "no tracks present prompt".
DVD works fine. I am running XP SP2. If I click on disk from Windows desktop Media Player 10 opens and works fine. I have tried autoplay off and on,.... no joy.
This was also a problem in V1.2... changed to V1.3 hoping that it would be solved.
07-16-2005, 02:45 AM
#144
wow you got much on your hands already, here is another:
When you click play in the MEDIA, the status bar displays Pause, when it should be saying "Playing" ;if i confused u ask me to further explain.
Great new look,many things fixed compared to 1.2
DICE Los Angeles
07-16-2005, 03:02 AM
#145
VENDOR - Centrafuse
I got the solution to CD player problem...
Heres whats causing it... In the screenshot I see the CD Letter setting says D:\ this is wrong... this should just say D It is only suppose to be the letter.. you will need to change it in the config.xml in the system folder...
the :\ is what is causing it to fail... That is a bug from my setup populating the wrong thing from the dialog.. I will get that fixed...
david
07-16-2005, 03:10 AM
#146
Hi David, your fix worked 100%! Thanks, it was driving me nuts.... gonna try rip a CD now...
By the way the CPU utilisation is far better on this version... runs a consistant 2-3% with no media playing. Ver 1.2 ran 35% in idle....
Nice work, I really love the simplicity of this program.... later.
07-16-2005, 03:17 AM
#147
cd works, but resuming music after ejecting seems to take quite a while. had about 10-15 seconds of silence. also, dvd playback still refuses to work. i also cant bring the video library up either (which iirc, was part of the dvd section)
07-16-2005, 03:19 AM
#148
Raw Wave
Mine started doing the same all of a sudden. Its driving me crazy LOL!
I have AutoPlay set to OFF.
Quote: Originally Posted by camsgs3
david, i also get the floppy drive error, CF trys to access my floppy every 10 seconds and ALSO when i exit out of CF, my floppy drive is still going off every 10 seconds........
07-16-2005, 03:35 AM
#149
ever since i installed it my A drive hase been going mad even if the program isnt running
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return The car
07-16-2005, 03:40 AM
#150
VENDOR - Centrafuse
I never found that floppy problem in 1.2... That narrows it down atleast.. I know it's in some of the code I pulled from 1.2... I have one computer that still has a floppy drive and it doesn't happen on that machine... I need to find a setup that causes the problem so I can debug...
The only code I have that queries windows for drive status is the autoplay... and some say it still happens when autoplay is disabled... What about if you disable autoplay and reboot... does it still do it when you come back up?
david
| Thread Tools |
| Display Modes |
Linear Mode
