07-16-2005, 03:56 AM
#151
that did it thanks
anyone mentioned the clock no mins
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return The car
07-16-2005, 04:10 AM
#152
Quote: Originally Posted by skydiver
that did it thanks
no the minutes are not showing here either but it is with some peeps so maybe a time setting (like US and European :P?)
my destinator map resource down permanently
07-16-2005, 04:25 AM
#153
VENDOR - Centrafuse
yes... I feel the clock problem has something do with localization...
david
07-16-2005, 04:31 AM
#154
just got netstumbler working in CF but have a prob.
works great first in fullscreen and small screen and i can switch between fine .
BUT when i start map monkey and go back to net stumbler i lose the switching i get the noise but nothing happens.
MM still switches fine.
maybe it is because netstubler uses windows within windows ?
also MM still runs after closing down CF
07-16-2005, 04:39 AM
#155
Raw Wave
i observed similar behavior with FrodoSatRadX and iGuidance.
Once I launch FSRX, I can't switch between fullscreen/window mode for iGuidance; iG just stays in window mode (and CF beeps at me) when i click the titlebar to maximize it.
07-16-2005, 04:56 AM
#156
If there is no ID3v1, only v2 then you'll get something like this:
"Unknown Artist - Stevie Wonder - I just called to say I love you"
Edit the tag to be the same in both v1&v2 and rebuild and it works ok..
Same thing if there is no tag at all.. Then it should just display the filename..
Not "Unknown Artist" + %filename%
Don't know if this has been covered.. Didn't feel an extreme urge to read through 11 pages..
So if it has already been reported, I second that...
/p
07-16-2005, 05:04 AM
#157
EQ, Tone (Treb/Bass) and Balance does not have any effect when playing videos.
Works fine for MP3's but not video, regardless of format.
/M
07-16-2005, 07:36 AM
#158
A really small one here:
If you have a song that contains a ' in the tag it will be "doubled"..
I.e. Tag = "Hard to say I'm sorry" shows as "Hard to say I''m sorry"
/p
07-16-2005, 09:18 AM
#159
/p
David,
You had said something about getting a program called "THe GoDFather" I Downloaded it but I do not understand how to use it. How do you use it to put tags on all your mp3's.
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-16-2005, 09:46 AM
#160
Raw Wave
Seems to have stopped for me after rebooting.
I wonder if there is 'something' that triggers this all of a sudden. I'm not convinced it will have stopped forever now.
Quote: Originally Posted by veetid
I never found that floppy problem in 1.2... That narrows it down atleast.. I know it's in some of the code I pulled from 1.2... I have one computer that still has a floppy drive and it doesn't happen on that machine... I need to find a setup that causes the problem so I can debug...
The only code I have that queries windows for drive status is the autoplay... and some say it still happens when autoplay is disabled... What about if you disable autoplay and reboot... does it still do it when you come back up?
david
07-16-2005, 10:51 AM
#161
Saving play-status
veetid:
At some point there was a discussion about how much info CF should save about the current queue. At that time you said that you would save both the current song in the queue and the exact location within a song, so that when CF was restartet it would not start from 0:00 of the current song (or from the start of the playlist as CF 1.2 did).
CF 2.0b1 doesn´t do this with either video nor mp3. mp3´s are not that bad, but running a 2 hour video which is restarted from scratch is annoying :-)
Could you also save the status when you save playlists? Like, when I hit a car-queue I start up a movie, watch 47mins, when the car-queue dissolves, I save the playlist, and the next time I load, it knows to start from 47min?
BTW, those quick-buttons I suggested at some point in the playlist save area(4-6 pre-defined playlist buttons with configurable names for fast-save/load of playlists) could still be cool, example:
* Video (for the current video I´m watching)
* Audiobook
* <Music genre 1>
* <Music genre 2>
* Show-off (Getaway in Stockholm for car shows or whatever :-) ).
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
07-16-2005, 11:17 AM
#162
OSK keyboard
Made a Danish version of the keyboard, but the "\" (back-slash) character shows up as a "|" (pipe) on the keyboard, also tried the xml code, didn´t help.
/SOS/
07-16-2005, 11:38 AM
#163
@david
just to let you know when playing videos it WILL go to the next video by it's self
so the problem is just with audio
07-16-2005, 12:14 PM
#164
But if you are watching a video and then click on dvd, once you leave the dvd the video starts over fromt the beginning, instead of the spot where it left off like music.
07-16-2005, 12:23 PM
#165
cant seem to get it to remember the radio stations.
i am using radiator and i am doing the same as the old version (holding down the preset button).
i get a prompt up asking me to give it a name but it wont remember it
| Thread Tools |
| Display Modes |
Linear Mode
