Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 07-15-2005, 08:46 AM   #46
SOS
SOS is on a distinguished road
Dual-screen / Video problems
CF install detected my 2 screens (expanded desktop), and video is showing on display 2, but only a small windows, not full screen. Then moved video back to display1, still appeared on display2, deactivated display 2 in windows completely, no video at all on display1, the video plays and sound is OK; but no picture.
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
SOS is offline   Reply With Quote
Old 07-15-2005, 08:47 AM   #47
m00ie is on a distinguished road
Quote: Originally Posted by stevieg
GPS is working fine for me using external.xml and map monkey. I have moved my GPS button to the main menu (see buttonactions.xml) and the mixer into the main menu folder. It works well. I have tried FreeDrive and that works well too. Only issue is full-screen the 'keyboard' and 'exit' buttons are in the wrong place (800x600)
'Disconnect' button doesn't work, but how is it supposed to unplug my LAN connection (LOL) so I never expected it to. I will check this in the car using GPRS. The button worked fine in 1.2 so I doubt it will be any different.
The "torn piece of paper" is actually a face looking right. See the nose and mouth? I remember david saying this is the switch for SAPI to turn it on and off. I don't have a mic to hand so I cannot test it yet.
I confirm I do have the time problem.
Could you paste your external.xml for the mapmonkey part? I've tried it myself but i just get a grey area where the GPS should be.
m00ie is offline   Reply With Quote
Old 07-15-2005, 09:05 AM   #48
CavityCr33p's Avatar
CavityCr33p
CavityCr33p@hotmail.com_centrafuse.lic
In the Fluxmedia/Centrafuse/ directory, not working, have uninstaleld, deleted folder, and reinstalled, nothing.
2000 Sunfire build 100%, or is it ever really 100%?
CavityCr33p is offline   Reply With Quote
Old 07-15-2005, 09:11 AM   #49
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
try a dash instead of an underscore?
My license attachment looked like this: =_iso-8859-1_Q_notmyrealaddress@isp=2Ecom=5Fcentrafuse=2Elic_ = So I guessed, and saved it with a dash instead of an underscore, and it works for me..
Can you open the file in notepad, and does it look like XML?
tj!2k4 is offline   Reply With Quote
Old 07-15-2005, 09:17 AM   #50
rickster's Avatar
rickster is on a distinguished road
set cf to display the video to the second screen. play the movie and the thumbnail starts playing. then click it once. the movie jumps to the second screen
rickster is offline   Reply With Quote
Old 07-15-2005, 09:26 AM   #51
rickster's Avatar
i think there is a bug with system dates.
My computer had the wrong date. I changed it and then centrafuse said no licence found. I re-installed the licence and cf but it still said no licence.
If i now change my date to the 30th july 05 it works fine. What gives?
Old 07-15-2005, 09:35 AM   #52
krog
- if I disable the "cover art", the icon should be gone in the music screen. It takes room for nothing.
- one click-option is gone (really bad for in-car-use).
- crossfading doesn't take stuff like 1,5 (or 1.5). If I set it to 1 there is no fading at all when manually changing the song (should be 0.5s).
- sometimes CF stops at the end of a song.
- personally I dislike the new "fancy" look... it looks kinda cheap to me. Also it was waaaay easier to read while driving in CF1.2
krog is offline   Reply With Quote
Old 07-15-2005, 09:40 AM   #53
Jay2001's Avatar
Jay2001 is on a distinguished road
Good point, hadn't noticed that. (Hadn't gone looking for it yet)
Can you spot a pattern for the ones that work as mine stops at the end of EVERY track.
Jay2001 is offline   Reply With Quote
Old 07-15-2005, 09:44 AM   #54
anky1's Avatar
anky1 will become famous soon enough
the xml in your .lic file probably said that the start date is the 30th of july... i'm not sure if you can edit the .lic manually or if you have to get a new one...
RIP 1993 civic sedan
RIP 1993 civic Del Sol
Hello! VW Golf 1.8t
anky1 is offline   Reply With Quote
Old 07-15-2005, 09:45 AM   #55
Jahntassa's Avatar
Jahntassa is on a distinguished road
I agree that the new look, while cool, is definitely overboard.
I also have the 800x600 keyboard bar issue.
As a suggestion, can you make it so we can enable/disable the keyboard bar for an application in the settings files? For instance, it shows up for iNav, but it doesn't show up for Firefox. I'd like it so we can do like... /KEYBOARDSHOW/ Yes (or no) per application.
- Also, is it just me, or is everything bigger? I like being able to embed my iNav window, but it seems like it's smaller to accomodate the larger new buttons? Would this be solved by doing a different 'skin'?
- And, the startup screen is nice, but is there a way to turn off the happy little 'the audio is working!' sound?
- As for the integrated GPS, as it's been said in other threads, I hope you're not assuming that everyone is going to use that instead of their preferred programs. I already have Inav, and I'm already using iGSkinner..and i'd like to keep it that way...
Jahntassa is offline   Reply With Quote
Old 07-15-2005, 09:45 AM   #56
rickster's Avatar
@anky1: no it says 15 july in the lic file. i was tinkering around and now it works again. dunno what i did
Old 07-15-2005, 09:48 AM   #57
krog
You are right... Seems to stop at the end of every track. I must have skipped manually all the other times
Old 07-15-2005, 09:49 AM   #58
anky1's Avatar
well at least it is working
side-note maybe you should edit first post and put in kinda like a FAQ to the things that we've already answered... i have a feeling this thread is going to get long
Hello! VW Golf 1.8t
Old 07-15-2005, 09:52 AM   #59
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
part of external.xml
Code:
<APP1> <PATH>C:\DestinatorApps\Map Monkey\MapMonkey.exe</PATH> <WINDOWNAME>Map Monkey - [GPS]</WINDOWNAME> <DISPLAYNAME>GPS</DISPLAYNAME> <PAUSEMUSIC>False</PAUSEMUSIC> <LINECONTROL>NONE</LINECONTROL> <STARTFULLSCREEN>False</STARTFULLSCREEN> </APP1>
and small changes to buttonactions.xml for GPS to show on sidebar and main menu, with mixer moved to main menu:
Code:
<BUTTONACTIONS> <GLOBAL1> <ACTION>MUSIC</ACTION> </GLOBAL1> <GLOBAL2> <ACTION>RADIO</ACTION> </GLOBAL2> <GLOBAL3> <ACTION>APP1</ACTION> </GLOBAL3> <GLOBAL4> <ACTION>DVD</ACTION> </GLOBAL4> <GLOBAL5> <ACTION>APPS</ACTION> </GLOBAL5> <MAIN1> <ACTION>TOOLS</ACTION> </MAIN1> <MAIN2> <ACTION>MIXER</ACTION> </MAIN2> <MAIN3> <ACTION>APPS</ACTION> </MAIN3> <MAIN4> <ACTION></ACTION> </MAIN4> <MAIN5> <ACTION></ACTION> </MAIN5> <MAIN6> <ACTION></ACTION> </MAIN6>
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 07-15-2005, 09:56 AM   #60
CavityCr33p
Mine says starts 15, tried with dash instead of underscore, this is crap.
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
Bugs so far in 1.3 BETA GReeToZ Centrafuse 11 07-17-2005 09:00 PM
preview centrafuse 1.3 ... TheKingPlaza Centrafuse 5 06-19-2005 05:59 PM
Releasedate of Centrafuse 1.3 superbowl Centrafuse 18 06-15-2005 02:19 AM
