Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 07-15-2005, 11:58 AM   #76
m00ie is on a distinguished road
Quote: Originally Posted by Quattro
I'm getting a weird problem with my floppy drive. When I have Centrafuse running, it does a disk read from the floppy drive about every 10 seconds. When I close the app, the disk reads stop as well.
Aslo, when you hold down the forward and rewind buttons, the time will flash to 00:00 after a while and then go back to the correct time. I don't think this affects the actual forward and rewind process, though.
I managed to fix the floppy drive problem, i think i changed something in the settings but i can't remember what. Have a fiddle
m00ie is offline   Reply With Quote
Old 07-15-2005, 11:58 AM   #77
Cheekz185 will become famous soon enough
Random/Repeat does not work. Song just stops when its finised, it doesnt even go to the next track....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 07-15-2005, 11:59 AM   #78
GReeToZ is on a distinguished road
No floppy problems here! but the thing that really sets me of it the not advancing to the next song its also in normal mode not just in repeat and ramdom i also hope the random is better this time as it used to be quite crappy (playing song 1 then 4 and then 1 again lol) . the other bugs i can live with
my destinator map resource down permanently
GReeToZ is offline   Reply With Quote
Old 07-15-2005, 12:00 PM   #79
A-Z
A-Z's Avatar
A-Z is on a distinguished road
Having problem with video play, any time I try 2 skip to the next video I get "Centrafuse.exe has encountered and error and needs 2 close".
A-Z is offline   Reply With Quote
Old 07-15-2005, 12:02 PM   #80
Mbai2 is on a distinguished road
Quote: Originally Posted by AMDJetta
When i play a song it plays ok, but when it ends the music totally ends, there is no more sound coming, it is not playinf the next track..
also DIM mode 3 has some color issues..
Otherwise looking good..
I have this problem too. At the end of every song, the music just stops.
Mbai2 is offline   Reply With Quote
Old 07-15-2005, 12:17 PM   #81
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Is anyone else expericening problems with memory useage. Centrafuse is using a extreme amount of memory on my desktop.
Heres a screen shot.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 07-15-2005, 12:32 PM   #82
jeeplaw is on a distinguished road
holy memory leak! I don't think it was like that for me, i'll try mine out in a little bit. I'm having the floppy disk ping as well..
jeeplaw is offline   Reply With Quote
Old 07-15-2005, 01:06 PM   #83
rickster's Avatar
rickster is on a distinguished road
mine fluctuates at 75000K whilst playing a divx movie
rickster is offline   Reply With Quote
Old 07-15-2005, 01:32 PM   #84
Another problem I noticed that was also present in 1.2 is the fact that embedded apps don't receive the hibernate/resume signal. For example, I use FrodoSatelliteRadioX which reinitializes the XMDirect module after a resume when it is run on its own. However, when I embed the program into Centrafuse, it will not receive the hibernate/resume signal and will not reinitialize the XMDirect module. This results in no response from the XMDirect until I manually close FrodoSatelliteRadioX and reopen it.
Old 07-15-2005, 01:50 PM   #85
Mr. Wiggles
shakes's Avatar
shakes is on a distinguished road
Quote: Originally Posted by Jay2001
OK, I don't know if this is me being silly or if this is bizzare behavior, but...
If you go to your library and click on "directories", select a folder with an album in it and click "load" then the files load up in file order. Great for me as all of my album tracks are called
01 - title.mp3
02 - title.mp3
etc...
However if I go to the library and click "Albums", select one and click "load", they appear to load in a completely random order (sometimes, 2 out of the three I tried this applies to). It can't be "random" as it is always the same order but I can't figure out the pattern. All of the files have the track numbers as the first characters of the file name, and in the ID3 tags, and in the ID3v2 tags.
Any ideas?
In settings under the Audio/Video tab there is a 'Track Sorting' option you can turn on to make them sort properly. This should be on by default IMO ... but at least it's an option in this version!
I am also having the issue where it stops after every song. I'm just trying this on my laptop for now ... I'll have to try it in the car in a bit.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
shakes is offline   Reply With Quote
Old 07-15-2005, 01:55 PM   #86
Have any of you guys tried using the cd player? I just tried popping in a music cd (both real/burnt) and i got to media manager / Library and click CD and it keeps saying "No Tracks Present"....
Same problem here.
Old 07-15-2005, 02:01 PM   #87
Dexter is on a distinguished road
Working fine for me, install was a breeze. Love the skin!
Couple things:
Not sure if I have the floppy problem. (You guys still use floppy drives? (lol) )
I have to press NEXT to make the next track play.
When I Exited out of Centrafuse, I get an exception error. "Could not write" or something to that effect. (Sorry for the sketchy details, I will try to reproduce).
What happened to the "Play All" button in the Manager? I usually like to just hit that and skip through all my tracks that way. Is there any way to reproduce this in the current version of Centrafuse or will it require a code change.
Love the speed! Its tons faster. Really great work david, dont be discouraged by these bugs, its a huge release, especially if you rewrote the entire app especially, so for the most part, I think its doing great.
Mazdaspeed Car Computer
gotta redo it all
Dexter is offline   Reply With Quote
Old 07-15-2005, 02:33 PM   #88
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
When adding a song to favorites it will continue to add it over and over again as many times as you hit favorite
i think if possible it should toggle favorite status
hit it once it adds the song to favorites and hit it again it should then remove it
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 07-15-2005, 02:36 PM   #89
TRONiC is on a distinguished road
BUG Custom OSK Keyboard doesnt work
I made my own OSK Keyboard layout.
Just made a copy of US.xml (\keyboards) and renamed it to SE.
And edited "[" to "å" and ";" to "ö" and ' to ä.
I get a centrafuse error message.
TRONiC is offline   Reply With Quote
Old 07-15-2005, 02:40 PM   #90
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
I am really confused about the next track problem everyone is having. Not sure why the event isn't firing and why it works on my two dev machines... I will figure this out asap.. I am checking into all the display problems, clock, date, etc..
I will get some wma's and test... I actually never tested them...
The top right button is "suppose" to work as follows... When it sees you have an internet connection it should say "Disconnect", which will execute the hangup on your default internet connection (if connected with lan it just does nothing)... when you are not connected to the internet it should say "Connect", which dials your default internet connection... In 1.2 it was status label so it was backwards... It's a button now with actions, not status...
I am unsure about the licensing problems, but we will get them all sorted out.. I am BETA testing that also... It mainly appears some email clients are messing up the lic file... I might switch to use serial numbers instead...
The play/pause, even though they are buttons, work like status... It shows you > to say something is playing and shows pause when something is paused...
The CD problem... Make sure you have your CD letter specified in setup or it will not work...
I can't believe the floppy error followed me to 1.3.... Try to disable autoplay and see if it stops...
"Play All" functionality can easily be accomplished by clicking Load when Artist, Album, or Genre is highlighted... It will play everything...
I will compile all these erros and get to work this weekend... I will hopefully be able to make an update release within a week to fix most of the major issues... This BETA is a complete rewrite and this is the first time it's ever been run on machines outside my DEV enviroment, so I expected there to be bugs...
david
veetid is offline   Reply With Quote
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
Bugs so far in 1.3 BETA GReeToZ Centrafuse 11 07-17-2005 09:00 PM
preview centrafuse 1.3 ... TheKingPlaza Centrafuse 5 06-19-2005 05:59 PM
Releasedate of Centrafuse 1.3 superbowl Centrafuse 18 06-15-2005 02:19 AM
