07-15-2005, 05:55 PM
#106
wonderful job
Wonderful job David and eBomb.
As you mentioned, big releases will result in big bugs
It should satisfy many of us to know that you are on the major bugs.
Thanks once again for a wonderful product.
-defsquad
#107
Raw Wave
if browsing media and holding down the left mouse button over a song causes a jit debugger error and creates a whitebox with red "x" in it
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
07-15-2005, 06:02 PM
#108
http://www.mp3car.com/vbulletin/show...2&postcount=45
07-15-2005, 06:42 PM
#109
David, if by chance the advance to next track bug is the first one you tackle (maybe this weekend  ), do you think you could release an update just for that bug. The rest of the bugs are relatively minor IMHO and I think most of us would be able to wait on those for a week or two.
07-15-2005, 06:51 PM
#110
same here, thats the bug that keeps me from using it in the car, but i'm sure david will take care of it
my destinator map resource down permanently
#111
Raw Wave
Error message upon first load... Problem with OGG tags?
I loaded CF and on when it scanned through my music files/tags it gave me an error message several times in a row (I assume it gave me one error per affecting OGG file).
The error message screenshot is attached:
07-15-2005, 06:59 PM
#112
found a skin error when displaying in 800x600
07-15-2005, 07:18 PM
#113
Raw Wave
Error when loading a music folder
Got the following error when attempting to load one of my albums (occured when hitting LOAD button). So I close the app, and upon relaunching I get a huge long error (sorry, don't have it captured as it is in a dialog, not copy-able), and I cannot start the app. Only workaround was to delete the MAIN.DAT file which seems to force partial re-install of missing components when launching the app...
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at centrafuse.Music.visTick(Boolean forceupdate)
at centrafuse.Music.minivisTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
centrafuse
Assembly Version: 1.3.2021.30940
Win32 Version: 00001.00003.02021.30940
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/centrafuse.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
ReflectionCleaner
Assembly Version: 1.0.0.0
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
cfplayback
Assembly Version: 2.1.0.5
Win32 Version: 2.1.0.5
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/cfplayback.DLL
Xheo.Licensing
Assembly Version: 2.1.5000.0
Win32 Version: 2.1.5000.26c
CodeBase: file:///c:/windows/assembly/gac/xheo.licensing/2.1.5000.0__798276055709c98a/xheo.licensing.dll
System.Web
Win32 Version: 1.1.4322.2037
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
System.Web.Services
CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
Microsoft.DirectX.AudioVideoPlayback
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/Microsoft.DirectX.AudioVideoPlayback.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Freedb
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/Freedb.DLL
RegexAssembly1_0
Assembly Version: 0.0.0.0
Win32 Version: n/a
CodeBase:
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
07-15-2005, 07:26 PM
#114
Raw Wave
White line on cover art ?
I get a white line to the right of ALL cover art album images. The folder.jpg files do not have this white line, so it appears CF is putting it there?
see attached image...
07-15-2005, 07:43 PM
#115
Raw Wave
When loading an OGG album, previous title/cover are not refreshed
If I load MP3 albums all is fine and dandy. As soon as I load an OGG album, the previously loaded Cover Art and Album title are NOT overwritten... so you end up with the OGG music loaded, but it shows the previously loaded title and cover art!
#116
When I try to embed iGuidance it looks like the first pic.
If I click where the track info is it goes to full size and looks perfect! second pic. Except the keyboard button and the close button are shifted off to the right!
If I click the track info again it goes back down in size but looks perfect. pic 3.
This is my external.xml settings...
<APP1>
<PATH>C:\Program Files\iNav\iGuidance\iGuidance.exe</PATH>
<WINDOWNAME>iGuidance</WINDOWNAME>
<DISPLAYNAME>GPS</DISPLAYNAME>
<PAUSEMUSIC>False</PAUSEMUSIC>
<LINECONTROL>NONE</LINECONTROL>
<STARTFULLSCREEN>false</STARTFULLSCREEN>
07-15-2005, 07:52 PM
#117
07-15-2005, 07:57 PM
#118
david, i also get the floppy drive error, CF trys to access my floppy every 10 seconds and ALSO when i exit out of CF, my floppy drive is still going off every 10 seconds........
07-15-2005, 08:01 PM
#119
VENDOR - Centrafuse
camsgs3: If you disable autoplay does the floppy problem stop?
I fixed the track not advancing bug... The event was gone... I must have accidently removed it when I was cleaning up the code for release... It was late
I am going to work through as many of these bugs as I can and get an update out soon... Hopefully by the end of the weekend or so...
david
07-15-2005, 08:09 PM
#120
@David: As most of us is probably mostly after a fix for the "next track" bug
You don't suppose you could release a 1.31 update?  please?
Well, no matter what you decide, I, as stated in other threads,
will be happy waiting for an update to the greatest thing since sliced bread
Cheers
/p
| Thread Tools |
| Display Modes |
Linear Mode
