07-15-2005, 08:34 PM
#121
Quote: Originally Posted by tj!2k4
Win2k or XP? I'm having the same issue on a 2k PC I installed it on.
Both computers are running 2k. I tried the install first, then copied the folder and just replaced all the files on the carputer, with the ones from the desktop. Both comps have the same .net installed, so I'm still kinda lost as to what to do next.
07-15-2005, 09:13 PM
#122
David specified that XP is required on his website. You make have to upgrade windows.
07-15-2005, 09:41 PM
#123
Quote: Originally Posted by krog
- if I disable the "cover art", the icon should be gone in the music screen. It takes room for nothing.
Agree 100% with that. I'm a big fan of wider playlist display area so you can fit more of the songname in the screen since I don't browse my songs by artist/albums like most people do.. I end up seeing only the band name and album then it gets cut off.. Even then it probably won't make it to the song name.. I should probably start making ID3 tags and such if I ever want to use most of the softwares that are made now beacuse they all have very little width for text..
On a side note, if you click on the cover art image, it changes between 2 different graphic eq thingys..
07-15-2005, 09:52 PM
#124
But it works just fine on one 2k machine and not on another.
07-15-2005, 09:55 PM
#125
Raw Wave
i think it's required to be there for the time-being, because you now also play video through the "media" section; when you select videos to play, it shows the video in that little area, and you click that to make it fullscreen.
#126
I don't know what to tell you. There could be an issue with some builds of 2k, that's why David requires XP. I'm at work right now and have it running on 2k myself. It seems to work fine, but I'm sure there's a reason xp is required.
07-15-2005, 09:59 PM
#127
Ah well, it's not a big deal.. It's probably alot of work to just remove it from the screen with a click in the settings anyway.. Doesn't bother me all that much now since I was just informed that Centrafuse won't display the full band/album/track by filename anyway.. That's pretty cool what you mentioned though.
#128
Same version on both machine. Same disc even. I'm gonna just reformat the carputer and start over from scratch. I need to do that anyway. There has to be something that I'm missing.
07-15-2005, 10:10 PM
#129
Quote:
The CD problem... Make sure you have your CD letter specified in setup or it will not work...
David, have you figures anything out to why this is happening? I did assign the drive letter....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-15-2005, 10:30 PM
#130
VENDOR - Centrafuse
not sure about this... I can't reproduce this problem.. CD's play fine.. Do you have autoplay enabled? Does anything happen when you insert a CD. What about when you insert a DVD? Try a data CD that contains some music files just to see...
david
07-15-2005, 10:35 PM
#131
Mr. Wiggles
Quote: Originally Posted by justintime
I loaded CF and on when it scanned through my music files/tags it gave me an error message several times in a row (I assume it gave me one error per affecting OGG file).
The error message screenshot is attached:
I am seeing this same error when I rebuild my files.
My JeepPC Install
"there are no stupid questions, just stupid people."
"it's been agreed the whole world stinks so no one's taking showers anymore"
07-15-2005, 10:43 PM
#132
Mr. Wiggles
I get this error as well when playing OGG files
Got the following error when attempting to load one of my albums (occured when hitting LOAD button). So I close the app, and upon relaunching I get a huge long error (sorry, don't have it captured as it is in a dialog, not copy-able), and I cannot start the app. Only workaround was to delete the MAIN.DAT file which seems to force partial re-install of missing components when launching the app...
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at centrafuse.Music.visTick(Boolean forceupdate)
at centrafuse.Music.minivisTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
centrafuse
Assembly Version: 1.3.2021.30940
Win32 Version: 00001.00003.02021.30940
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/centrafuse.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
ReflectionCleaner
Assembly Version: 1.0.0.0
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
cfplayback
Assembly Version: 2.1.0.5
Win32 Version: 2.1.0.5
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/cfplayback.DLL
Xheo.Licensing
Assembly Version: 2.1.5000.0
Win32 Version: 2.1.5000.26c
CodeBase: file:///c:/windows/assembly/gac/xheo.licensing/2.1.5000.0__798276055709c98a/xheo.licensing.dll
System.Web
Win32 Version: 1.1.4322.2037
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
System.Web.Services
CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
Microsoft.DirectX.AudioVideoPlayback
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/Microsoft.DirectX.AudioVideoPlayback.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Freedb
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/Freedb.DLL
RegexAssembly1_0
Assembly Version: 0.0.0.0
Win32 Version: n/a
CodeBase:
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
My JeepPC Install
07-15-2005, 10:45 PM
#133
Mr. Wiggles
Flux guys ... I will say though, that this app is absolutely awesome so far. It's not usable yet because of the OGG and next track bugs ... but damn am I impressed! I even love the skin, and I didn't think I would.
This release is amazing ... it's exactally what all the other front ends have been lacking.
My JeepPC Install
07-15-2005, 10:48 PM
#134
VENDOR - Centrafuse
Do the OGG tags get read into the database properly? I actually added the OGG support, but never ran it... I don't have any OGG files... I added so much and was so behind with the release, I pretty much just stopped where I was programming and released... It won't take me long to use all this feedback and release an update...
david
07-15-2005, 11:07 PM
#135
Mr. Wiggles
it seems they do. However I've noticed the files that crash my car don't crash my desktop. i'm installing dotnet sp1, wmp 10, and a bunch of otehr patches to bring my car closer to my desktop. everything except SP2 really Is SP2 needed?
I do get the rebuild error on both machines tho.
My JeepPC Install
| Thread Tools |
| Display Modes |
Linear Mode
