Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 07-15-2005, 06:53 AM   #1
rickster's Avatar
rickster is on a distinguished road
Centrafuse 1.3 Bugs
Post your bugs for the new release of Centrafuse 1.3 here.
Only post bugs - not requests
Some of the bugs have been fixed below.
#1. Your licence file gets emailed as an attachment. It should be emailaddress@domain.com_centrafuse.lic - If you did not receive it, check to make sure it was not stripped off with a virus/spam scanner
#2. GPS is not integrated in 1.3 - to use gps set up the software in the external.xml file. Example thanks to StevieG:
Code:
<APP1> <PATH>C:\DestinatorApps\Map Monkey\MapMonkey.exe</PATH> <WINDOWNAME>Map Monkey - [GPS]</WINDOWNAME> <DISPLAYNAME>GPS</DISPLAYNAME> <PAUSEMUSIC>False</PAUSEMUSIC> <LINECONTROL>NONE</LINECONTROL> <STARTFULLSCREEN>False</STARTFULLSCREEN> </APP1>
#3. The torn paper icon in the corner is actually voice control. If you have Sapi set up then this will activate/deactivate voice control
#4. to watch a movie on the second screen, add the movie to your queue and press play. then click the thumbnail and it will play on the second screen
#5. If any of the cf system files are deleted/corrupt the installer automatically runs when you click centrafuse.exe and they are installed again automatically
#6: Here is the problem with the CD not reading:
Quote:
Heres whats causing it... In the screenshot I see the CD Letter setting says D:\ this is wrong... this should just say D It is only suppose to be the letter.. you will need to change it in the config.xml in the system folder...
the :\ is what is causing it to fail... That is a bug from my setup populating the wrong thing from the dialog.. I will get that fixed...
#7. This is how to save radio stations. Thanks to cheekz185.
Quote:
Click the numbers for your radio statiom for example : 97.10 Then click on tune.
When the station is displayed up top click the preset and hold it for 3 seconds and it will save it. But if you hold it for 5 seconds it will come up with the OSK and ask for the station name. You can name it hot 97 ect...whatever the namve of the radio station is.
#8. This is the fix for the font errors:
Quote:
I replaced the font at the last minute and didn't realize it didn't support bold and when you hold down the listview it takes the mainpanel font from the page and trys to bold it... I will get this fixed... for now you can replace 'GE Drover' in your skin.xml with a font that supports bold
Thanks to StevieG - there is a skin that is in creation. You can get it here
Warning: If you are browsing the media directories and you click the remove icon (to remove something from your playlist) you will infact delete the file off of your computer. Make sure you only use the "-" button in the queues.
rickster is offline   Reply With Quote
Old 07-15-2005, 06:57 AM   #2
paran0id is on a distinguished road
Cut and quickly edited from the "CF 1.3 Update" thread:
#1: Getting the clock thing aswell..
#2: Disconnect doesn't work as previously stated
#3: Neither does the green button in the low right corner.. Looks like a torn piece of paper
#4: The GPS tab is clickable but the settings doesn't appear..
#5: Just now listened to another song that stopped one second AFTER finish..
i.e. 4:57 when song stops at 4:56
The time it stops seems to have nothing to do with the song itself as the song
finishes as it is supposed to.. Have listened to a few with "noise" to the end..
Not a lot of them, but there a few bugs..
Compare to Windoze and your product is as near perfection as could be wanted..
Cheers
/p
paran0id is offline   Reply With Quote
Old 07-15-2005, 06:59 AM   #3
Jay2001's Avatar
Jay2001 is on a distinguished road
Another one.
If I load a folder of WMA files, not only do they refuse to play but the album art doesn't load either, have tried it on three different albums and none worked.
A folder full of MP3 files plays, but as I said before it stops at the end of each track.
Jay2001 is offline   Reply With Quote
Old 07-15-2005, 07:05 AM   #4
Jay2001's Avatar
Here is a screen shot showing both the messed up time display and the track stopped at the end of playing.
Old 07-15-2005, 07:05 AM   #5
#6: No way to set up external apps..
#7: System info shows up empty..
Edit: Added screen of my messed up time..
Note that the song being played is actually 3:58 but the time stops early
Note also that the song itself plays until end, only the ticker stopping..
The Aerosmith song above stops at 4:57 when it is 4:56....
Old 07-15-2005, 07:06 AM   #6
rickster's Avatar
Cheers
/p
I believe the disconnect button is a label to show if your phone is connected or not. You can't press it. It shows connected when your phone is hooked up.
Old 07-15-2005, 07:07 AM   #7
CavityCr33p's Avatar
CavityCr33p
License does not work, reinstalled, deleted folder, put license back into root CEntrafuse folder, and still "No License Found" error.
How is your licenses supposed to be named?
2000 Sunfire build 100%, or is it ever really 100%?
CavityCr33p is offline   Reply With Quote
Old 07-15-2005, 07:08 AM   #8
Jay2001's Avatar
And another showing the missing album art and refusal to play WMA files.
Old 07-15-2005, 07:08 AM   #9
CavityCr33p
Don't think so, I thought it was to signify you were online, mine says connected and I have no phone.
Old 07-15-2005, 07:12 AM   #10
GReeToZ posted this in another thread..
I've gotten this aswell, though not while pressing the eye button.. Just idleing..
http://www.mp3car.com/vbulletin/centrafuse/54836-bugs-so-far-1-3-beta.html
Old 07-15-2005, 07:14 AM   #11
Jay2001's Avatar
I should also state that although the screenshot shows "Unknown Artist" for all my WMA files, the artists are definately in the files as both MWP and WinAmp display it fine.
Old 07-15-2005, 07:17 AM   #12
m00ie is on a distinguished road
Cheers
/p
I'm getting the same problems.
m00ie is offline   Reply With Quote
Old 07-15-2005, 07:26 AM   #13
rickster's Avatar
I am online and mine says disconnected. Who knows
Old 07-15-2005, 07:28 AM   #14
8: Cant play WMA files
9: Can't properly read WMA tags.
I.e. Unknown Artist - Wig Wam - In my dreams (Wig Wam IS the artist)
10: No cover art for WMA, when trying to play it resets the vis to coverart
Try it by setting your vis to anything but coverart and try playing a WMA
it will change to coverart and the time will stay still at ~0:27-0:28 (can't remember)
Edit:
11: Just noticed that the date is not properly shown either
Check the screenshots that are posted in this thread..
/p
Old 07-15-2005, 07:29 AM   #15
rickster's Avatar
#4 is not included in this release. you need to set up gps as an external app. Use the config files to configure it.
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
Bugs so far in 1.3 BETA GReeToZ Centrafuse 11 07-17-2005 09:00 PM
preview centrafuse 1.3 ... TheKingPlaza Centrafuse 5 06-19-2005 05:59 PM
Releasedate of Centrafuse 1.3 superbowl Centrafuse 18 06-15-2005 02:19 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
