Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 08-04-2005, 10:01 PM   #151
Raw Wave
justintime's Avatar
justintime is on a distinguished road
BUG Double-Clicking an Album when in Single-Click mode -> issues
1) Set CF to enable Single-CLick mode.
2) Go to Media Manager / Library / Artist ... and choose an Artist
3) DOUBLE-CLICK an album picture
4) Click LOAD button to load entire album
5) Problem: CF complaints "Nothing Selected"
I guess there is no reason to double-click when in single click mode, but it does happen every now and then with touchscreen monitors by mistake
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Advertisement Sponsored links
Old 08-05-2005, 11:43 AM   #152
inniss777's Avatar
inniss777 is on a distinguished road
Quote: Originally Posted by justintime
Don't know if this has been reported, but if I hibernate while playing music (mp3 files), when I wake up from hibernation the music continues playing where it left off, but the sound is all jumpy and jittery for the first several seconds.
In one instance, the only way to resolve the problem was to PAUSE and UNPAUSE... then everything was normal.
Is it just me?
I fix the studder music problem when the system resumes from hybernation.
It's some sound cards causing the problem. That's why everyone does not experience it.
What you have to do is turn down the sound hardware acceleration. To do this go into control panel => sounds and devices => audio => sound playback advance => performace. Bring down the slider to basic acceleration.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
inniss777 is offline   Reply With Quote
Old 08-05-2005, 11:45 AM   #153
inniss777's Avatar
Quote: Originally Posted by S7347H
to run a program before or after hibernate, i use a program called suspendtrigger. I pair this with executing frodo's setvolume program through a batch file. It works best if i set it to execute the batch file before hibernation, otherwise it doesn't run it soon enough on resume to actually start at the set volume when centrafuse starts playing.
Here is the link for suspendtrigger. Suspend Trigger
Is it possible with this program to have it execute an internet connection when the system resumes from hybernation.
Old 08-05-2005, 11:48 AM   #154
inniss777's Avatar
Quote: Originally Posted by SOS
veetid:
Hey, I had this problem on 1.3 also, but was hoping for an automatic fix, but 1.4 has the same problem (both original and other skin).
When I wake up from hibernate in CF (where it was left off) the screen is just blank. Nothing wrong with the hardware, because I see the boot process, it just when the OS is up and CF takes over the screen blanks. The music plays in the background, I can use the touch feature of the screen and skip forward (because I know where the buttons are). Some times after 5 minutes and some times after 30 minutes or more the screen wakes up. I also tried pushing stuff to see if I could make it work, but havent found a good combination.
Im running on a Epia V10000 board with and NVidia PCI board as the primary board....
What kind of debugging can I do to help you find this "bug"?
This was a problem for me as well in other front ends. It's not CF causing this problem it your graphic card. Try playing with the video and 3D acceleration levels. Most likely they are to high.
Old 08-05-2005, 01:49 PM   #155
Jahntassa's Avatar
Jahntassa is on a distinguished road
So it's basically the sound/video caches causing the problems. I'll deal with it as I really don't want to turn off the hardware accelleration..
Jahntassa is offline   Reply With Quote
Old 08-05-2005, 02:22 PM   #156
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
Pause only temporary
Howdy David,
if I pause a video file to say go out for tea, I find that CF un-pauses and continues to play the file, without a STOP button the only way to truly stop a playing file is to clear the playlist & queue list. Or exit CF.
IIRC it will pause for about 5mins then it re-starts...
ShawJohn is offline   Reply With Quote
Old 08-05-2005, 02:46 PM   #157
S7347H is on a distinguished road
you would have to find a program that would automatically do that. The suspendtrigger program will only execute a program before hibernate and or after hibernate resumes.
S7347H is offline   Reply With Quote
Old 08-05-2005, 02:55 PM   #158
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Quote: Originally Posted by Tuned Vitesse
Howdy David,
if you pause audio does it stay paused? I will look into the video pause problem...
david
veetid is offline   Reply With Quote
Old 08-05-2005, 07:02 PM   #159
inniss777's Avatar
you would not notice any difference endless your are using your system for intence gaming and fiber optic sound.
Old 08-06-2005, 04:14 AM   #160
OriginalNick2 is on a distinguished road
When dragging and the letters pop up (auto seek) is Cf supposed to jump into the first album of the letter selected?
I.E Scroll to R - and it will jump into the first album begginning with R, which is really annoying if i want the second album beggining with R...
Can it just display results??
OriginalNick2 is offline   Reply With Quote
Old 08-06-2005, 08:56 AM   #161
Raw Wave
justintime's Avatar
It is supposed to jump to first item on list starting with that Letter.... but if you have SingleClick enabled, it selects the item too, and 'opens' it.
It's annoying, but it is a bug that David has been made aware of already.
2002 Honda CR-V
Old 08-06-2005, 12:57 PM   #162
Raw Wave
justintime's Avatar
BUG Releasing MUTE emits no click sound
1) Play music
2) Click on MUTE button, you hear the 'click/beep sound'
3) Click mute again, to unmute. No Click/Beep sound is emmited.
Clearly, the problem is that since the system sound is muted, you can't hear the beep upon unmuting.
Suggestion: As an exception to the rule, emit a beep AFTER the button is released when un-muting. (i.e., unmute first, and THEN send sound).
Not a huge deal, but would be nice to know you are hitting the button with audible feedback. If you don't hear any click/beep confirmation sounds, then you will be left wondering wehether you actually hit it, or missed it...
2002 Honda CR-V
Old 08-07-2005, 08:23 AM   #163
Raw Wave
justintime's Avatar
BUG Switching to Radio via Speech, causes speech problems
1) Enable speech
2) "Computer Music"
3) "Computer Radio"
4) "Computer Music" -> does not work
Problem: Seems that after switching to Radio, no other speech items work. DIsbling/enabling speech is the only way to make it work all over again...
2002 Honda CR-V
Old 08-07-2005, 11:08 AM   #164
Mbai2 is on a distinguished road
Two new bugs:
1. When speech recognition is enabled, it plays what the microphone hears through the speakers no matter what the playback mixer setting is for the microphone. This immediately goes away ONLY when you disable speech altogether in the settings menu.
2. When embedding certain programs (I can only remember FrodoSatelliteRadioX), CF will starting using 100% CPU after a while and become slow.
Mbai2 is offline   Reply With Quote
Old 08-07-2005, 01:19 PM   #165
inniss777's Avatar
1) Enable speech
2) "Computer Music"
3) "Computer Radio"
I notice this too. When ever the radio is launch it then disables speech.
Also if you say pause. You can not unpause the system from speech. It seems like a hot key issue.
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Release 1.4 CENTRAFUSE BETA 2 veetid Centrafuse 32 08-02-2005 11:20 AM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
New Release CENTRAFUSE 1.1 veetid Centrafuse 89 01-18-2005 10:17 AM
[OFFICIAL THREAD] NMC 0.7 alpha.1 bugs netsuo NeoCar Media Center 46 11-09-2004 06:02 PM
