07-31-2005, 02:06 PM
#31
Raw Wave
If Video folder not set, 'invalid directory error' throughout app!
I have not set a video folder in settings. I dont have/need/want one
So, if I happen to click on VIDEOS in the 'Browse By...' dialog, I get an error 'Invalid Directory'. This is OK. But now if I click on any other place (ALbums, Artist, etc.) I get the same error...
07-31-2005, 02:08 PM
#32
VENDOR - Centrafuse
Quote: Originally Posted by justintime
If I do not touch anything, the dialog stays on screen, no progress shown. When finished, it does show the total songs added.
Note: I am selecting my 'Music' folder root, because as I understood it, this is the way to update the new files added (instead of doing a full rebuild).
basically the status only shows files that have been added... so when you select your main music library it is going through all the files and deciding not to add them because they are already added, so you see no progress update... I will fix this... It does work like you think and will only add the new songs... Also I noticed if you try to hit close, it will not function, but once completed it will close really quick... I will fix this too...
david
07-31-2005, 02:11 PM
#33
david any update on the tagging problem, i cant upload more then 2MB on my email client to send you some files
I hope I dont have to redo my taggs again, do you think its def. a bug or are my taggs just messed up
07-31-2005, 02:19 PM
#34
VENDOR - Centrafuse
I will look into it... I just got some files emailed to me... what paran0id said was interesting... not sure why it would read improperly for some... I am just hoping the files I get read improperly, if they read fine then it's got to be some type of encoding/localization thing...
david
07-31-2005, 02:25 PM
#35
Quote: Originally Posted by veetid
m-ruiter: It can't read one of your config files... you have something invalid in your config.xml or it's not valid xml... Did you manually edit any of these files? It could also be a corrupt or improperly edited language file or externalapps.xml...
david
I did a clean install of 1.4. I did not have 1.3 installed. Just clean XP with KLite codecs, PhoneControl, Freedrive and sorry  Road Runner.
I will try to install 1.3 and run 1.4 over it. Maybee that will solve it.
Reason: Update
07-31-2005, 02:36 PM
#36
VENDOR - Centrafuse
you don't need to install 1.3...
david
07-31-2005, 02:38 PM
#37
david
I cant download 1.3 anymore stuppid me. 1.4 is it now.
But i guess it is something that i took out with nlite ? to shrik and speed up my XP. The only extra thing i took out was COM+. Could this be the problem ?
07-31-2005, 02:41 PM
#38
VENDOR - Centrafuse
most likely... I do interop a couple of com's....
david
07-31-2005, 02:43 PM
#39
david
Dawn, that sucks. It speeded up 1 second of my boot process
Thats gona be one week of roadrunner and a reinstall next week
07-31-2005, 03:15 PM
#40
Some Label Issues
Misc label probs:
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
07-31-2005, 03:17 PM
#41
DVD Buttons
When switching to DVD mode (no disc loaded) from any other mode, the buttons don't load correctly:
07-31-2005, 03:24 PM
#42
Problem reading APE Tags
Doesn't seem to read APE tags correctly, it comes up with a bunch of "unknown". I have re-tagged the file but it still doesn't work, these tags do read correctly in other applications. First image is MP3 with ID3v1, second image is MPC with APEv2... the MPC file is the same one I emailed you before, if you want to test it.
07-31-2005, 04:22 PM
#43
VENDOR - Centrafuse
Quote: Originally Posted by lifeboat
Misc label probs:
what resolution are you running?
david
07-31-2005, 04:28 PM
#44
what resolution are you running? It appears you shrunk the width too much for my current skin...
david
It's 800x600. I just resized the images for posting here...
07-31-2005, 04:36 PM
#45
VENDOR - Centrafuse
you sure that's 800x600? I run 800x600 fine and the images you have posted don't appear to be 800x600... Here is a screenshot if it running 800x600 on my machine... I also loaded it up in 640x480 and looks good to... everything fit... not sure whats going on, but something's not set or working like it should for you...
david
| Thread Tools |
| Display Modes |
Linear Mode
