Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 07-31-2005, 09:33 PM   #61
DaRacerz is on a distinguished road
I have an album loaded in the playlist and playing. Then another application takes focus. When this happens, centrafuse looses the playlist (or so it seems) and stops playing. Exited with an error.
Heres whats in the error log:
Quote:
7/31/2005 9:25:09 PM
The field is too small to accept the amount of data you attempted to add. Try inserting or pasting less data.
at System.Data.OleDb.OleDbCommand.ExecuteCommandTextE rrorHandling(Int32 hr)
at System.Data.OleDb.OleDbCommand.ExecuteCommandTextF orSingleResult(tagDBPARAMS dbParams, Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteCommandText( Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteCommand(Comm andBehavior behavior, Object& executeResult)
at System.Data.OleDb.OleDbCommand.ExecuteReaderIntern al(CommandBehavior behavior, String method)
at System.Data.OleDb.OleDbCommand.ExecuteNonQuery()
at centrafuse.id3reader.readid3(String rpath)
Mark
Website: http://www.geocities.com/daracerz83/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
DaRacerz is offline   Reply With Quote
Old 07-31-2005, 09:51 PM   #62
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Quote: Originally Posted by inniss777
Is the video stream piggy backing of windows media player. As far as the bass and treble sliders are you saying that they also have no effect on video as well?
nothing uses windows media player...
move the bass/treble and then go back to your EQ.. moving the bass/treble sliders is no different than moving the second lowest frequency and the second highest frequency on the EQ...
the EQ does not work with DVD or video...
david
veetid is offline   Reply With Quote
Old 07-31-2005, 11:03 PM   #63
ryuandwings's Avatar
ryuandwings is on a distinguished road
DB Problem?
I'm having problem with DB.
When I try to build DB for first time, it adds 0 songs.
When I try to rebuild by update library, it adds 0 songs.
All of thses file worked fine with 1.3.
Do you know what I'm doing worng?
ryuandwings is offline   Reply With Quote
Old 07-31-2005, 11:04 PM   #64
CavityCr33p's Avatar
CavityCr33p
When I installed mine, right after filling the serial out, it made the little startup noise and boom, .Net error.
Now, everytime I open it, same error after the intro music with the nice little red X on white background display. Sucks ***.
2000 Sunfire build 100%, or is it ever really 100%?
CavityCr33p is offline   Reply With Quote
Old 07-31-2005, 11:07 PM   #65
VENDOR - Centrafuse
veetid's Avatar
do you have any more information other than it gives an error?
david
Old 07-31-2005, 11:45 PM   #66
Jahntassa's Avatar
Jahntassa is on a distinguished road
Quote: Originally Posted by Cheekz185
David,
IN System Info, under CPU Temp, it never says the temp all it says is °C. I have mbm5 running but never can get the temp. Also how would I change it to Farenheit?
Yeah, that's very dependant on the motherboard itself. Only two of my machines will respond to temp info. Two of them won't..
Jahntassa is offline   Reply With Quote
Old 08-01-2005, 02:45 AM   #67
SOS
SOS is on a distinguished road
Quote: Originally Posted by veetid
how does this sound for singleclick...
that sound about right?
It sound right, this is definately a difficult thing, but eventhough I was very much fond of the single-click thing, the the way selection is working in CF 1.3+ is growing on me :-)
It takes time for people to try out new things, and you did think a lot about how to make selection work.
So I agree, try to implement single-click everywhere it woun´t break some of "your" concept, and let´s give a try....
If something then works really really bad, we´ll take it up in 1.5 requests thread
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
SOS is offline   Reply With Quote
Old 08-01-2005, 04:49 AM   #68
Vchat20's Avatar
Vchat20 is on a distinguished road
i had this same problem when installing 1.31 over 1.3 . just uninstall CF altogether (it should show 2 instances in add/remove. remove both) and reinstall. should work.
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 08-01-2005, 04:57 AM   #69
CavityCr33p
I did uninstall 1.3 before installing 1.4, and deleted the dir.
Also, my resolution was at 800 x 600, but when I started centrafuse and before I was getting the error, I couldnt see about 1/4" of the right side of the screen.
Old 08-01-2005, 05:03 AM   #70
Vchat20's Avatar
really odd. cuz i got the same exact problems as you. whit screen with a red x, .net errors, the works. and the uninstall/reinstall worked. are you sure its not howing more than one instance of CF in the add/remove programs?
only other wild guess suggestion i have is to redownload CF again. might have somehow got corrupted.
Old 08-01-2005, 07:40 AM   #71
djmickyg's Avatar
djmickyg is on a distinguished road
when i running map monkey embeded then i close map monkey via the map monkeys menu. it closes both MM and the laucher and there is no way for it to re open.. aarrg
djmickyg is offline   Reply With Quote
Old 08-01-2005, 07:48 AM   #72
Jahntassa's Avatar
Did you set it to a different skin? Older skin files WILL NOT WORK with 1.4. Set it to the Blue Ice skin until people start rebuilding other skins.
I had the same problem when I tried to switch to my old 1.3 skin.
Old 08-01-2005, 08:50 AM   #73
CavityCr33p
I didnt even get to pick another skin, this was a completely fresh install, happened during installation.
Old 08-01-2005, 09:59 AM   #74
Jahntassa's Avatar
Happened during installation? Like when you ran the setup file, or after CF was installed, and you had to 'enter setup'?
I had to manually delete the 'Flux Media' directory in Program Files after the uninstall, because it left my setup files in there..
Old 08-01-2005, 11:26 AM   #75
Zac
Zac is on a distinguished road
Now I can't seem to recreate it but I've had the single click option turn off magically when browsing through media a few times in a row. Of course now that I'm trying to recreate it I can't get it to do the same thing... Just wanted to throw it out there to see if anyone else had this happen...
Zac is offline   Reply With Quote
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Release 1.4 CENTRAFUSE BETA 2 veetid Centrafuse 32 08-02-2005 11:20 AM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
New Release CENTRAFUSE 1.1 veetid Centrafuse 89 01-18-2005 10:17 AM
[OFFICIAL THREAD] NMC 0.7 alpha.1 bugs netsuo NeoCar Media Center 46 11-09-2004 06:02 PM
