08-02-2005, 01:17 AM
#106
VENDOR - Centrafuse
I updated the initial post with a list of known bugs... now I'm off to work on an update...
david
08-02-2005, 09:54 AM
#107
Raw Wave
Aspect ratio of Album Art in fullscreen vis is not correct
When in fullscreen visualization mode, the aspect ratio of the album art is way off. It is not 1:1 square. I am referring to the 'small' album art that appears in the bottom left, not the large one one in the middle of the screen.
I tried at 800x480 and 848x480, and in both modes aspect ratio is off -- looks like a tall rectangle.
08-02-2005, 11:06 AM
#108
Quote: Originally Posted by veetid
load loads whatever is selected... it is like play now... after you add both albums to your "queue", simply click queue on the left and then hit load...
when load is clicked while browsing in the library it auto clears the queue and loads the current selection... this is to allow easy music browsing to simply just play what you have selected... Otherwise simply add to the queue and click queue on the left before you hit load...
david
OK!! Now it worked! didn't know I was supposed to do so. sorry for the confusion! And thanks again  David
Jonas
Hardware: (95%) Paintjob is killing me. A good shutdown controller would be nice. Voicecontroller??
Software: Beta testing for the gods!
08-02-2005, 02:01 PM
#109
VENDOR - Centrafuse
np... I don't have a manual yet...
david
08-02-2005, 03:33 PM
#110
the DVD problem is usually always related to a codec issue of some kind... uninstall your dvd software / mpeg 2 decoder and try to reinstall it... make sure c:\windows\system32\mswebdvd.dll is in your car... if not copy it from your home computer to your car and run regsvr32.exe mswebdvd.dll....
Is it the same music files on the computer in your car? try to delete the music and copy it again from your house.....
david
David,
i removed all dvd software, loaded WMP 10, loaded powerdvd 6.0, i have the mswebdvd.dll file and still no DVD playack in car.
any other ideas...please...
08-02-2005, 03:49 PM
#111
VENDOR - Centrafuse
Quote: Originally Posted by Tim97rs
David,
currently I'm out of ideas... reinstall windows maybe? sorry...
david
08-02-2005, 03:52 PM
#112
im in the same boat here. no dvd playback whatsoever. ill try loading up an instance of xp in vmware and see if anything changes there.
Your everyday carpc geek and tech guru at your service. *bow*
08-02-2005, 07:10 PM
#113
Raw Wave
shift AND caps KEYS on the OSK behave oddly
I reported this one back in 1.3, but it seems did not get fixed.
If you hit your SHIFT key while in OSK (hit shift on your real keyboard and leave it pressed) you will see that the OSK will alternate rapidly between upper and lower case.
Same effect with the CAPS key.
Not a real problem unless you are using a real keyboard, but still...!
08-02-2005, 09:45 PM
#114
(APE/MPC only support ID3V1 tags)
I currently can only read ID3V1 tags from APE/MPC files... both of those file formats do support ID3V1 tags... There are programs you can get that can add ID3V1 tags to these formats for you...
david
Ok. I hope you can add the APE tag support in a future version. Thanks.
Tim
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
08-02-2005, 10:57 PM
#115
Raw Wave
Tim
Get a program called The Godfather. It ROCKS!
08-02-2005, 11:06 PM
#116
David: first off great job.
I've notice a bug that has not been mentioned.
If a song is playing and the system is placed into hybernation (have not tested standby) when the system resumes from hybernation and the song starts playing there is a clicking sound. If I pause and then unpause the song after system resumes from hybernation then the clicking goes away. If I pause the song before the system is placed into hybernation then there is no problem when the system resumes.
Also for a feature: When browsing the media library can the up and down buttons perform like the volume buttons. When you hold them down they will continue scrolling. Thanks.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
08-03-2005, 12:17 AM
#117
When using voice, the "play" voice command does not work. I've tried changing the phrase assigned to play but nothing works. I can pause without problems though.
08-03-2005, 06:19 AM
#118
maybe this should NOT be called a bug, but in V1.3, it works good, in V1.4 it disappeared....
the CD selection on the media maneger.
08-03-2005, 07:05 AM
#119
I know when my songs crossfade into each other, the song playing stops well before the end (15-20 sec) of the song and just goes into the next. I think this is a known bug tho.
2000 Sunfire build 100%, or is it ever really 100%?
08-03-2005, 10:14 AM
#120
Blank screenon hibernation-on
veetid:
Hey, I had this problem on 1.3 also, but was hoping for an automatic fix, but 1.4 has the same problem (both original and other skin).
When I wake up from hibernate in CF (where it was left off) the screen is just blank. Nothing wrong with the hardware, because I see the boot process, it just when the OS is up and CF takes over the screen blanks. The music plays in the background, I can use the touch feature of the screen and skip forward (because I know where the buttons are). Some times after 5 minutes and some times after 30 minutes or more the screen wakes up. I also tried pushing stuff to see if I could make it work, but havent found a good combination.
Im running on a Epia V10000 board with and NVidia PCI board as the primary board....
What kind of debugging can I do to help you find this "bug"?
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
| Thread Tools |
| Display Modes |
Linear Mode
