Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 07-31-2005, 03:16 AM   #1
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Centrafuse 1.4 Bugs
post all the 1.4 bugs here...
Here is an updated list of the known bugs in 1.4...
Change initial check from get processes to find window (performance counter problem)
Embedded apps don’t’ receive power mode change event
Rear/sub/center need to increase with the master volume
Scrolling arrows and single click
When auto play is enabled it constantly tries to play DVD
Hold and jump screws up with single click
When single click is enabled it only needs to work on directories/upper level selections
Display file type instead of MP3 in the play mode label
Unicode tags are improperly read
Scrolling through list changes song focus, messes up next song and pause
Add music shows no update when scanning folders with files already in the DB
If no video folder is specified and you enter this section, you can’t get rid of “invalid directory” message
DVD player shows radio buttons when entered while in radio mode
Data CD doesn’t properly clear playlist
Remove temp measurement when no temp can be read
Singleclick doesn’t update listcount properly when items are selected
Check search results selection when in single click mode
Database fields are too small
External apps don’t full screen on initial load
Auto play causing problem with wmiprvse.exe
Visualization doesn’t properly scale
Cross fade not working when playlist advances tracks
Maintitle does not update properly (shows old song sometimes)
david
veetid is offline   Reply With Quote
Old 07-31-2005, 03:24 AM   #2
OriginalNick2 is on a distinguished road
Only one character missing from time now!! got 08:2 thats all so far!!
OriginalNick2 is offline   Reply With Quote
Old 07-31-2005, 03:28 AM   #3
Tim97rs is on a distinguished road
all my numbers are there... im in 800x600 on a 7" xenarc...
Tim97rs is offline   Reply With Quote
Old 07-31-2005, 03:31 AM   #4
camsgs3 is on a distinguished road
my tags seeem all messed up now when i browse , there where working great in 1.3....i didnt change anything
1-12 are tagged ok, 13-32 look like this
camsgs3 is offline   Reply With Quote
Old 07-31-2005, 03:38 AM   #5
VENDOR - Centrafuse
veetid's Avatar
I am reading the tags completly different in this version... 1.3 only supported ID3V1... 1.4 supports just about every tag format there is... Is it only with those particular files? can you send me a file that is messing up?
david
Old 07-31-2005, 04:02 AM   #6
david
ok its seems that all my tagges are off now, from 1-12 they have the artist names but for example when i click on jay-z there should be 13 albums, only 1 is showing, with one song that looks like this
Old 07-31-2005, 04:06 AM   #7
this is what my nas directory looks like...... anyone else getting tagg problems
Old 07-31-2005, 04:17 AM   #8
inniss777's Avatar
inniss777 is on a distinguished road
Mine is working fine. What file format are you using?
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
inniss777 is offline   Reply With Quote
Old 07-31-2005, 04:18 AM   #9
VENDOR - Centrafuse
veetid's Avatar
camsgs3: if you can send me a handful of files zipped that are reading improperly to support@fluxmedia.net I will figure out what's going on... Appears like some type of encoding issue, not sure... What format are the files, mp3?
david
Old 07-31-2005, 04:20 AM   #10
david
yea mp3, seems my wma are reading right...ill send you some
Old 07-31-2005, 04:24 AM   #11
TimmyM's Avatar
TimmyM is on a distinguished road
I am also.
http://www.mp3car.com/vbulletin/atta...id=17572&stc=1
What it looks like in my directory
http://www.mp3car.com/vbulletin/atta...id=17577&stc=1
The tag as seen from the Properties tab.
http://www.mp3car.com/vbulletin/atta...id=17578&stc=1
TimmyM is offline   Reply With Quote
Old 07-31-2005, 04:42 AM   #12
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
no DVD audio
audio works fine for music and videos but no dice on DVDs
also,
this is on a laptop here
nothing really special as far as audio goes, one thing to note this laptop does not have an audio IN (other than a mic) a little weird if you ask me.
I havent tested on any other desktop pcs yet or my car which dosent have a dvd player.
liquid_smoke is offline   Reply With Quote
Old 07-31-2005, 04:44 AM   #13
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by TimmyM
I am also.
whats the difference in the "losing grip" file compared to the others? It is the only one that showed up correctly... Send me a couple of those files and I will look into it...
david
Old 07-31-2005, 04:45 AM   #14
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by liquid_smoke
no DVD audio
volume can sometimes be really low on some DVD's... Does it not work with all DVD's? does the audio work with DVD's in WMP? what codec are you using?
david
Old 07-31-2005, 04:50 AM   #15
SMKFree
david
just edited my post,
the volume isnt low, its not there at all, i have it cranked up to 100%
audio works fine in wmp, power dvd, and MCE2k5
The audio codec is from Nvidia for the 6800Ultra
also, dosent matter what dvd i load
another thing i noticed is when i turn on autoplay dics, it automaticly started playing the dvd in my drive when i load CF (disk was not just inserted) and after clicking the X to close the dvd and go back to music, about 2 min later it started playing the dvd again on its own. This happened about 5 times till i turned off autoplay.
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Release 1.4 CENTRAFUSE BETA 2 veetid Centrafuse 32 08-02-2005 11:20 AM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
New Release CENTRAFUSE 1.1 veetid Centrafuse 89 01-18-2005 10:17 AM
[OFFICIAL THREAD] NMC 0.7 alpha.1 bugs netsuo NeoCar Media Center 46 11-09-2004 06:02 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
