Quote: Originally Posted by veetid
You can move from section to section in Centrafuse and the embedded app will stay loaded... not really any reason to even have close...
This is actually a problem. If you use DUAL Screen Setup, the "video window" will not close, the video overlay stays on top of the second screen and say you go and select an album, and have cover art on screen 2, it will not be displayed because of the "video" is still active.
However, you said you used power dvd as mpg2 codec, I tried that and the only way I can get video on the second monitor with the cyberlink codec is to put my radeon 9600 card in theater mode for the second screen (I havent tried with any gforce or matrox cards, does dvd controls on second screen work then with the cyberlink codec ? what GFX card are you using David ?). the way the 2 screen setup works in CF now causes loads of problems because all the embedded apps stays loaded.
The easiest way to solve this is probably to have a setting in CF that says:
embedded app stays loaded: 1 yes or 2 no
DVD playback controlls set to 2nd screen (no go with cyberlink codec, dvd wount even start) Controlls to 1 screen, Theatre mode on second screen (dvd player frezzez CF when you try to close it. dvd playback starts however)
Any Playback that incudes FFDSHOW outputting ac3 through spdif causes CF to crash if video are set to second screen (ac3 streams or any real time rencoded stream) Say you are playing one video, everything works fine, you are skipping to the next video, the audio of the video that was playing continues, and the new video starts displaying on both screens.
Please look into the dual screen problems, it just wount work at all if you are using SPDIF. When configured for analog output, it runns for a while then crashes because it opens like 9999999 ffdshows one for each video played (.net error accurs, If CF had closed its embedded players for each thing this would probably not have happend when using ANALOG setup)
Windows Media Video problems (I am not very concerned about this, I just thought I'd mention it): WMV that uses the 9.1 insted of 9.0 for decoding audio can not be played back correctly, video skipps audio skipps. WMV files always resizes to full screen at all resoultions for example (800x600 which is a 4:3 resolution, but since most people probably use 800x600 7" ws this might have been done by purpose, since the aspect ratio on an anamorphic 16:9 wmv file will look good and not "crunched" like it acctually should have been since the screen setup is not 800x480)
If i use WMP 10 to playback files, the system works exactly like I want it to, WMV plays correctly regadless of 9.0 or 9.1 decoding (aspect is correct on both screens) Mp3 files and Video files get real-time encoded to 5.1 with FFDSHOW and sendt out as AC3 on spdif. So FFDSHOW if configured correctly. When using Central Fuse, Video files get realtime encoded to 5.1, but not Mp3 files.
