Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 11-30-2005, 10:14 PM   #151
OoNikFraleyoO's Avatar
OoNikFraleyoO is on a distinguished road
Quote: Originally Posted by Lum
Searched this thread but couldn't find this fault already.
If you set your PC to hibernate on a press of the power switch, then do this with CentraFuse running. The next time you start the system, you will get a blank screen and the only way to get out of it is to press one of the side buttons to change screen, then everything is redrawn and it works fine.
I have tried this with the startup screen set to Media, Home and Previous
I hibernate several times everyday and have never had this issue.
OoNikFraleyoO is offline   Reply With Quote
Old 11-30-2005, 11:36 PM   #152
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
I hibernate & she comes back fine.... but no sound in cf... have to exit & come back in.....
I think I'm noticing a pattern with the freezes.... seems when I have a really large playlist loaded it's much more likely to freeze & lock up, than if I have a normal playlist of 20-30 songs or so...... is this possible.....
when I have a playlist of over 20,000 songs it is almost certain to lock-up... only a matter of a few clicks away alot of the time.....
turbocad6 is offline   Reply With Quote
Old 12-01-2005, 05:57 AM   #153
Lum
Lum's Avatar
Lum is on a distinguished road
It happens to me every time without fail. It is not a windows problem as if I quite centrafuse and hibernate, it comes back to the desktop just fine.
Could it be because I have not set Centrafuse as my startup shell?
Lum is offline   Reply With Quote
Old 12-01-2005, 02:27 PM   #154
Now you might be on to something as I do have Centrafuse running as shell.
Old 12-01-2005, 07:07 PM   #155
donde's Avatar
donde is on a distinguished road
Centrafuse is not my shell and I can hibernate fine
donde is offline   Reply With Quote
Old 12-01-2005, 08:11 PM   #156
Lum
Lum's Avatar
Well it doesn't work for me, *shrug*
I know CF detects that it's going in and out of hibernate, because when you come out of hibernate it plays it's little startup tune (how do you get rid of that BTW?)
Actually it's worked correctly exactly once, it came out of hibernate and instead of the startup tune, a voice said "GPS not found" or similar, this was just afted I'd disabled the Destinator plugin
Also, is there any documentation for CF, as the playlist editor is as confusing as hell.
Old 12-01-2005, 08:35 PM   #157
donde's Avatar
To turn off the startup sound, go to settings->audio/video tab. The last option on the page is to turn the startup sound on and off.
Old 12-02-2005, 06:35 PM   #158
Frankino's Avatar
Frankino is on a distinguished road
same problem here, but only with a SB Audigy, using my old sb live I have no problems...
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Old 12-03-2005, 01:27 AM   #159
Floatingpi is on a distinguished road
I have been noticing with the GPS plugin that it routes incorrectly at times... Mainly when I choose some street that has E W or some direction that isn't the one highlighted after the street search is completed... It hangs on the first item it highlighted not mine.
Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
Floatingpi is offline   Reply With Quote
Old 12-03-2005, 11:38 PM   #160
kbyrd's Avatar
kbyrd is on a distinguished road
Feature/Bug about GPS POI selection
This could be considered a bug or a needed feature:
I've been mucking around with the GPS plugin, actually using it to get places (when my BU-353 doesn't go all crazy on me). In any case I find the POI searching annoying. I can see how someone would want fine-grained categories. But I almost always want an "all". I'm out somewhere and I want the nearest "Staples" office supply store, how do I find that using the current system? Let's say I don't want the nearest one, I want the one on El Camino Real. If there are two, sort them by distance from "here".
I would like it to work a little like this:
1) Choose POI
2) Choice between start punching in letters to find my list from "all" POIs or to filter my category or location
3) location filter could be by zipcode/city/street etc.
In the service of a vengeful God.
My worklog.
Status: First carPC installed, uninstall, and selling off parts soon.
kbyrd is offline   Reply With Quote
Old 12-28-2005, 06:01 PM   #161
techeros's Avatar
techeros is on a distinguished road
Quote: Originally Posted by Mbai2
When I press the DVD button with no DVD in the drive, Centrafuse freezes and CPU load goes to 100%. I have to exit through task manager.
same here... I am using the demo and when you load the taskmanager, it looks like cf has a memory leak...
03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
Carputer Planning |---------*|
Overall Implementation |---------*-|
(Stereo complete)
Computer installed and working
techeros is offline   Reply With Quote
Old 01-08-2006, 12:37 AM   #162
When using multiple displays and the visual it doesn't change on the second display as it should. It will only display the album art and not change to the spectrum visuals.
Old 01-14-2006, 08:03 PM   #163
Found another dual screen bug today. If you have two screens and you don't set the second screen to "extend my desktop..." so it displays the same screen as the main screen. When viewing a video full screen it will only display on one screen and not both. Where when not being displayed full screen it CF is displayed on both screens.
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Centrafuse SDK Information veetid CF SDK 24 11-03-2005 04:18 AM
New Release Centrafuse 1.5 veetid Centrafuse 95 11-02-2005 01:48 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
