Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Bug Reports
Old 11-01-2005, 06:36 PM   #61
Frankino's Avatar
Frankino is on a distinguished road
at 800*600 in embedded apps the keyboard - close - maximize buttons are messed up
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Old 11-01-2005, 06:55 PM   #62
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Just a tip for those weary to replace 1.4 on their systems:
Don't uninstall 1.4 and just make sure you select a different install directory for 1.5 (e.g. C:\Program Files\Flux Media\Centrafuse 1.5) when you install 1.5.
This will give you the ability to beta test the latest version, but retain the stability of 1.4.
tj!2k4 is offline   Reply With Quote
Old 11-01-2005, 10:07 PM   #63
Raw Wave
justintime's Avatar
justintime is on a distinguished road
BUG Pause icon switches over
Description: Pause icon siwtches from one image to another under certain conditions
Reproduce:
1)Start playing a song, and go to HOME.
2) While in HOME, press the Pause button
3) Switch to MEDIA
4) Pause button has now refreshed... and displays the 'other' image.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 11-01-2005, 10:10 PM   #64
Raw Wave
justintime's Avatar
BUG Scrolling text doesn't always 'blank' before refresh
Quote:
scrolling main title clears before it displays truncated text
That worked for me initially, but all of a sudden, the 'clearing' has ceased. It behaves like CF 1.4
Also, can you increase the scrolling speed? Twice faster at least! It takes forever to stare and watch the whole thing scroll through. While driving, no less!
Thanks a bunch.
2002 Honda CR-V
Old 11-01-2005, 11:21 PM   #65
P3rv3rt B3ar's Avatar
P3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud ofP3rv3rt B3ar has much to be proud of
Plugin specific languages are broken!!!!
(atleast this is the case on destinator plugin)
instead of fetching plugin specific languages... centrafuse fetches available languages for plugins from main language directory meant for core centrafuse. Now this could be feature instead of bug, like microsoft likes to comment. But then why the hell there is language selection separately for each plugin.
P3rv3rt B3ar is offline   Reply With Quote
Old 11-01-2005, 11:33 PM   #66
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
Quote: Originally Posted by Dhaark
my volume stat goes from 100% to 30% never below like kbyrd's.
I think urosbe is trying to say that when he jumps from media to anywhere (Mixer, Apps, DVD...) when he returns to media the volume is on 30% and when he left it was higher.
the volume does not go below 30%(2) asmentioned on top of post and the mute button is green but i can hear sound and the "mute" word (1) is off so the sound is on.
I think you will know what i mean.
your right.. that is a bug... it really is at 0, just a percent calculation problem...
david
veetid is offline   Reply With Quote
Old 11-01-2005, 11:34 PM   #67
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by urosbe
I was just playing with my Powermate...
by default settings in Powermate program are set that Powermate (right, left and click) control Windows volume. In this case, in CF if you have volume set to about 70% and you slowly move it to the left, in next moment volume shows 30%... but this can be changed... in Powermate program, change that Rotate Left/Right means sending keys "Control+Alt+Up" and "Contrl+Alt+Down", but changing volume from 30-100 then takes about 3 or 4 circles of Powermate rotating Unusefull.
And I also noticed a bug - in Windows if you increase volume from min to max, everything goes linear, but in CF 1.5, volume starts at 30% and at 52% reaches maximum! At 53% is minimum again and 100% is maximum. I have Via Epia SP with default (latest) drivers.
For now I am staying at 1.4, hopefully in next release it will be possible to manual set linear/logaritmic increasing of volume.
Best regards!
Uros
I set my powermate to send ctrl-alt-up and at the fastest rate and it seems fine to me...
david
Old 11-01-2005, 11:36 PM   #68
VENDOR - Centrafuse
veetid's Avatar
Quote: Originally Posted by defsquad
Guys, I know exactly what David is referring to. I had mentioned this "annoyance" yesterday to him, but after his explaination, it makes total sense. We are used to seeing volume represented by a 0-100% slider, whereas, high end audio gear, specifically for the house, gauges volume by the dB level, which is what David has coded into the application. I think if he were to remove the "%" sign from after the integer it would make less confusion, or even better if he would have the integer divided by a specific amount to get the lowest (30db in this case) to display as 0dB, however, this would mean 100 as we know it (being a percentage) would now be something like 60-70db and would max out there.
I hope that makes sense. Unfortunately we have the mindset of volume being represented as a percentage of 0-100%, so we're confusing our selves with his new representation of volume level.
exactly... I use DB now, but still converted to percent and their is just some math problems with the display... will be easy to fix and properly represent...
david
Old 11-01-2005, 11:39 PM   #69
VENDOR - Centrafuse
veetid's Avatar
Reproduce:
3) Switch to MEDIA
if another song that is not the current playing song is highlighted in the list, the icon changes to play because that is the action it will perform... if you click to go back to home, then the action of the button again becomes pause...
basically it always should show what it will do...
david
Old 11-01-2005, 11:41 PM   #70
VENDOR - Centrafuse
veetid's Avatar
yep... that is a bug... will get it fixed... had a path wrong
david
Old 11-01-2005, 11:43 PM   #71
VENDOR - Centrafuse
veetid's Avatar
I am testing CF 1.5 on two computers..
1. In my car with Via Epia SP and there are problems:
-buttons stays in green color after clicked... in case you are searching media library, and you press m-a-r-r-i-a-h, all letters pressed stays in green color. The same problem with MUTE and other buttons.
-I also have a problem mention before (one scale of volume 30-52%, another 53-100%).
-When plugging in USB 1 GB key with 20 music videos (I turned off Windows autoplay as recommended in 1.5 release notes), a message box appears (reading tag information) of first song and nothing moves. I have to press "Cancel" to return to CF, but videos from USB are not loaded. I tried the same on my home machine with the same USB with the same videos, everything works perfect... it reads tag information of all music videos and load new playlist.
-I am still searching "older" drivers for my Via Epia SP, because I cannot control sub/rear channels in CF.
-comparing to previos release, 1.4 seems to be more stable and faster
2. On my home machine (915G chipset), everything is cool... there was a problem that everytime I came from DVD, Mixer or some other sections to MEDIA, volume decreased to 30%... but after reinstalling, problem disappeared.
Best regards!
Uros
The tag reader update display isn't properly closing sometimes... I will check it out, but I did reproduce it...
david
Old 11-02-2005, 02:33 AM   #72
urosbe's Avatar
urosbe is on a distinguished road
david
Do you use Powermate on Via Epia or some "stronger" computer? I use it on Via and I also have Powermate set to highest sensitivity, but when you move Powermate fast, you can look volume changing (decreasing/increasing) for another second on the screen Maybe it is a problem as you mentioned of using CF 1.5 on slower computers as Via.
About 30-52%...53%-100% problem... which version of drivers for Epia do you have?
Uros
urosbe is offline   Reply With Quote
Old 11-02-2005, 03:47 AM   #73
lazy_g's Avatar
lazy_g is on a distinguished road
When i switch off album-art, it doesnot swith it off!!!
Is there actually a way to get that Dr Dolittle 2 icon away which appears when you have a album without a picture in it?
Check out my website!!!
Check out my company site!!!
lazy_g is offline   Reply With Quote
Old 11-02-2005, 10:03 AM   #74
Mbai2 is on a distinguished road
Dr. Dolittle 2? I get a CD icon. Make sure you don't have a Dr. Dolittle picture file in the same directory as your unknown songs.
Mbai2 is offline   Reply With Quote
Old 11-02-2005, 10:05 AM   #75
lazy_g's Avatar
ok i will check again... but i do not recal having it... But maybe i did not look wel enough
New Release Centrafuse 1.20 veetid Centrafuse 89 10-10-2007 08:12 PM
Centrafuse SDK Information veetid CF SDK 24 11-03-2005 04:18 AM
New Release Centrafuse 1.5 veetid Centrafuse 95 11-02-2005 01:48 PM
Centrafuse 1.4 Bugs veetid CF Bug Reports 270 09-27-2005 10:58 PM
Centrafuse 1.3 Bugs rickster CF Bug Reports 330 07-26-2005 08:51 PM
